[Other] plot3DToFoam: converting backstep grids from NASA's website |
November 4, 2013, 07:39 |
Samuele Z
Rep Power: 19 |
Dear All,
I am trying to convert some Plot3D meshes into the OpenFOAM format. What I am doing is to download some meshes from, for example, HTML Code:
http://turbmodels.larc.nasa.gov/backstep_grids.html Code:
plot3dToFoam name-of-the-mesh Code:
zampini@pc-zampini:~/Documenti/PhD/corsi/physicsAndNumericalModellingOfTurbulentFlows/test$ plot3dToFoam backstep5_1levdn.p2dfmt /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0 Exec : plot3dToFoam backstep5_1levdn.p2dfmt Date : Nov 04 2013 Time : 12:30:12 Host : "pc-zampini" PID : 22448 Case : /home/zampini/Documenti/PhD/corsi/physicsAndNumericalModellingOfTurbulentFlows/test nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Reading 4 blocks block 0 nx:257 ny:257 nz:97 block 1 nx:257 ny:385 nz:449 --> FOAM FATAL IO ERROR: wrong token type - expected int, found on line 4 the doubleScalar -130 file: backstep5_1levdn.p2dfmt at line 4. From function operator>>(Istream&, int&) in file primitives/ints/int/intIO.C at line 68. FOAM exiting zampini@pc-zampini:~/Documenti/PhD/corsi/physicsAndNumericalModellingOfTurbulentFlows/test$ Code:
zampini@pc-zampini:~/Documenti/PhD/corsi/physicsAndNumericalModellingOfTurbulentFlows/test$ plot3dToFoam backstep5_0levdn.p2dfmt /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0 Exec : plot3dToFoam backstep5_0levdn.p2dfmt Date : Nov 04 2013 Time : 12:25:43 Host : "pc-zampini" PID : 22264 Case : /home/zampini/Documenti/PhD/corsi/physicsAndNumericalModellingOfTurbulentFlows/test nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Reading 4 blocks block 0 nx:513 ny:513 nz:193 block 1 nx:513 ny:769 nz:897 new cannot satisfy memory request. This does not necessarily mean you have run out of virtual memory. It could be due to a stack violation caused by e.g. bad use of pointers or an out of date shared library Annullato zampini@pc-zampini:~/Documenti/PhD/corsi/physicsAndNumericalModellingOfTurbulentFlows/test$ Thanks a lot, Samuele |
December 18, 2014, 17:04 |
Mateus Peixoto
Rep Power: 12 |
Hi Samuele,
Did you solve the problem? |
January 2, 2015, 17:51 |
Samuele Z
Rep Power: 19 |
Dear Adoledin,
indeed, what I did was to generate a new mesh similar to the one available in the link I post in my first message. Sorry! |
Purpose and Map of this forum | Tobi | OpenFOAM Community Contributions | 0 | September 19, 2017 06:52 |
NASA's grids not working on SU2 | gittagawa | SU2 | 4 | August 12, 2017 20:41 |
How to get su2 meshes from NASA's plot3D/cgns grids | OVS | SU2 | 4 | February 29, 2016 13:07 |
Does the grids topology matters? | Anna Tian | Main CFD Forum | 11 | August 19, 2014 03:20 |
