[Salome] Script for converting a mesh from Salome-Platform to OpenFOAM |
#81 |
Frédéric MR
Rep Power: 7 ![]() |
Thank you Gerhard,
I'm going to continue some test to solve it. If someone has a solution, or a similar problem, please detail your case. |
#82 |
Franco
Rep Power: 6 ![]() |
hello I tried to use the script to export a polyhedral mesh from salome but i am getting some errors and when i open .foam file in paraview i dont see the mesh
Number of nodes: 177085 Number of cells: 30000 Counting number of faces: total number of faces: 203647, internal: 203647, external 0 Converting mesh to OpenFOAM Finished processing boundary faces Traceback (most recent call last): File "<string>", line 304, in exportToFoam KeyError: (172547, 172548, 172581, 172665, 174509, 174510, 174511) During handling of the above exception, another exception occurred: Traceback (most recent call last): File "<string>", line 316, in exportToFoam KeyError: (172547, 172548, 172581, 172665, 174509, 174510, 174511) During handling of the above exception, another exception occurred: Traceback (most recent call last): File "<string>", line 667, in run File "<string>", line 341, in exportToFoam IndexError: list assignment index out of range Number of nodes: 177085 Number of cells: 30000 Counting number of faces: total number of faces: 203647, internal: 203647, external 0 Converting mesh to OpenFOAM Finished processing boundary faces Traceback (most recent call last): File "<string>", line 304, in exportToFoam KeyError: (172547, 172548, 172581, 172665, 174509, 174510, 174511) During handling of the above exception, another exception occurred: Traceback (most recent call last): File "<string>", line 316, in exportToFoam KeyError: (172547, 172548, 172581, 172665, 174509, 174510, 174511) During handling of the above exception, another exception occurred: Traceback (most recent call last): File "<string>", line 667, in run File "<string>", line 341, in exportToFoam IndexError: list assignment index out of range if anyone found themself with the same problem and solved it would be appreciated ![]() |
#83 |
Rep Power: 4 ![]() |
I tried script salomeToOpenfoam.py to import my mesh into openfoam which has pyramids.I get the following message in the console.Can you please help me
SalomeOutsideGUI: no selection mechanism available outside GUI You have to select a mesh object and then run this script. or run the export function directly from TUI import SalomeToOpenFOAM SalomeToOpenFOAM.exportToFoam(mesh, path) |
#84 | |
Franco
#85 |
believe me i did it 1000000 times.It still shows the same issue,First it showed some errors to update the script now after i debugged the script, it shows this message
#86 |
I did it but it is still the same issue
#87 |
Giovanni Fazzone
Rep Power: 5 ![]() |
mesh conversion, openfoam, salome meca |
[Salome] how to setFields in openFOAM when you have imported mesh from salome or other package | 13msmemusman | OpenFOAM Meshing & Mesh Conversion | 11 | May 18, 2022 07:30 |
[Salome] import mesh from salome to openfoam | dome90 | OpenFOAM Meshing & Mesh Conversion | 2 | April 20, 2016 23:58 |
[Salome] Step to export mesh from SALOME to OpenFoam for 3D MRF geometry | aminem | OpenFOAM Meshing & Mesh Conversion | 0 | September 16, 2014 10:18 |
[Salome] Mesh Salome 7.3.0 to OpenFoam | Ahadi | OpenFOAM Meshing & Mesh Conversion | 5 | July 1, 2014 10:11 |
Mesh conversion problem from Salome to openfoam | jishnusoni | OpenFOAM | 15 | March 3, 2010 01:53 |
