[snappyHexMesh] bumpy on the surface of 3D wing in addlayer step with snappyHexMesh |
October 16, 2013, 01:58 |
Kim sung hwan
Dear cfd-users,
i have tried making external mesh by running snappyHexMesh for simulating a OneraM6 wing. but i meet a problem the addlayer processing in snappyHexMesh. Until snapping, i got reasonable snapping results on the wing surface. however, after addlayer step, i found some bumps between upper and lower level of refinement level. when i got uniform cells near a surface using distance refinement, i could resolve this problem. but it makes too many total cells so, it's not efficient. I have tried many parametric study, but i can't find the solution about this issue. I attached four screenshots and below there's my snappyHexMeshDict. I would appreciate any help for solve this problem. Code:
/*--------------------------------*- C++ -*----------------------------------*\ | o | | | o o | HelyxOS | | o O o | Version: v1.0.3 | | o o | Web: http://www.engys.com | | o | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location system; object snappyHexMeshDict; } castellatedMesh true; snap true; addLayers true; geometry { M6.stl { type triSurfaceMesh; name M6; } box1 { type searchableBox; min (-0.5 0.0 -0.5 ); max (2.0 1.5 0.5 ); } } castellatedMeshControls { features ( { file "M6.eMesh"; level 8; } ); refinementSurfaces { M6 { regions { } level (7 8 ); } } refinementRegions { box1 { mode inside; levels (( 1E5 3 )); } } locationInMesh (3.0 3.0 1.0 ); maxLocalCells 1000000; maxGlobalCells 2000000; minRefinementCells 0; nCellsBetweenLevels 5; resolveFeatureAngle 5; allowFreeStandingZoneFaces false; } snapControls { nSolveIter 300; nSmoothPatch 3; tolerance 1.0; nRelaxIter 5; nFeatureSnapIter 10; implicitFeatureSnap false; explicitFeatureSnap true; multiRegionFeatureSnap false; } addLayersControls { layers { M6_ascii_io_exported_from_Pointwise { nSurfaceLayers 2; } } relativeSizes false; expansionRatio 1.1; finalLayerThickness 2.0E-4; minThickness 1.0E-5; nGrow 0; featureAngle 60; slipFeatureAngle 30; nRelaxIter 3; nSmoothSurfaceNormals 1; nSmoothNormals 3; nSmoothThickness 10; maxFaceThicknessRatio 0.8; maxThicknessToMedialRatio 0.3; minMedianAxisAngle 90; nBufferCellsNoExtrude 0; nLayerIter 50; nRelaxedIter 20; } meshQualityControls { maxNonOrtho 65; maxBoundarySkewness 20; maxInternalSkewness 4; maxConcave 80; minFlatness 0.5; minVol 1.00E-13; minTetQuality -1e30; minArea -1; minTwist 0.02; minDeterminant 0.001; minFaceWeight 0.02; minVolRatio 0.01; minTriangleTwist -1; nSmoothScale 4; errorReduction 0.75; } debug 0; mergeTolerance 1E-6; |
April 20, 2015, 23:06 |
Bumpy surfaces on snappyhexMesh
Lavanya
Rep Power: 11 |
Has this problem been resolved? I have done 2 things to remove the protruded surfaces. 1. Make the "allowfreestandingZonefaces" as true in snappyHexMesh Dict 2. On moving to higher number of cells, I could still see the bumpy surfaces , so I went to increase the "minTetQuality " in the meshQualitycontrols . I am not sure if this the right point of looking at the problem. Is there any another better way of doing this ? |
April 21, 2015, 03:51 |
Artur
Rep Power: 20 |
Have you tried playing around with the snapping distance tolerance parameter? I've found it to be quite crucial for getting good mesh on and very near the body surface. Sadly I've had problems in getting the quality I want with different refinement levels as was the case in the original post... Can you comment on the effect of the changes you've made? All the best, A |
addlayer, bumpy, refinement level, snappyhexmesh 3d, wing |
Ffd_control_point_2d | feiyi | SU2 | 4 | September 30, 2019 12:42 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
[snappyHexMesh] Bumpy Wing with snappyHexMesh | aeir1976 | OpenFOAM Meshing & Mesh Conversion | 9 | June 20, 2012 05:30 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
