[surface handling] Basic surfaceFeatureExtract test |
September 24, 2013, 10:58 |
anonymous
Rep Power: 13 |
Hi there,
I'm trying to get a grip on controlling sMH (OpenFOAM 2.1.0) to do what I want and so far I'm failing . My goal was:
You see the edge object, the mesh and the stl geometry in the enclosed picture. Also the surfaceFeatureExtract doesn't fix the messy mesh which is created when the snapping feature is turned on. With which i'm not bothered to much but still if there is a clear reason for this I'm missing it. Last edited by Hekky; September 24, 2013 at 10:59. Reason: forgot some information |
September 24, 2013, 11:33 |
anonymous
Rep Power: 13 |
Ah didnt have the nFeaturesnapIter set, this is what did not allow the feature command to "fix" the mess caused by the snapping procedure on the edges.
Fact remains that it is an asymmetrical refinement on a symmetric geometry. This still does not make sense to me. |
[OpenFOAM.com] Installing on Ubuntu 18.04 | samiam1000 | OpenFOAM Installation | 11 | April 27, 2020 01:01 |
[OpenFOAM.com] Issue configuring ./makeParaView - Ubuntu 16.04 | bjdarrer | OpenFOAM Installation | 2 | April 20, 2020 14:50 |
Fan performance curve: Deviation to test results depending on initial values | Wolfram | CFX | 19 | January 25, 2019 05:36 |
Dynamic Smagorinsky model- Filtering Concept | saeedi | Main CFD Forum | 34 | November 29, 2015 23:43 |
Basic Blade Design Code | apoorv | Main CFD Forum | 0 | April 5, 2010 07:37 |
