[Helyx OS] OpenFOAM mesh in Helyx-OS
Like Tree3Likes
  • 3 Post By chegdan
Old   September 18, 2013, 17:45
Question OpenFOAM mesh in Helyx-OS
Tom
RTom is on a distinguished road
Hi
I am looking to use an OpenFOAM mesh in Helyx-OS.
Is it possible to work with an existing OpenFOAM mesh in Helyx-OS?
And if is true, how can I import the mesh.
So far I know, It may be possible if I change the mesh file from the case directory. But I don't know how or which files to substitute
RTom is offline   Reply With Quote
Old   September 19, 2013, 14:31
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
In the near future you should be able to import meshes from other cases directly, but until the release you can
  1. create a new case using HELYX-OS
  2. copy the entire polyMesh directory form an existing OpenFOAM mesh to this new case
  3. Reload the new case in HELYX-OS and start setting things up
If you want to import a mesh from say FLUENT, its very similar
  2. through the command line, navigate to your new case directory and import the mesh withe the appropriate command e.g. fluentMeshToFoam car.msh .
JR22, RTom and marauder like this.
chegdan is offline   Reply With Quote
Old   September 19, 2013, 23:48
Thumbs up
Tom
Thanks a lot!!
It works!
Old   October 11, 2017, 10:59
Aryames
aryames is on a distinguished road
Thank you! It helped me.
aryames is offline   Reply With Quote
case directory structure, helyx-os, import mesh
Tool to convert OpenFoam mesh to SU2 mesh (2D and 3D) Combas SU2 45 October 16, 2024 18:26
[Salome] Script for converting a mesh from Salome-Platform to OpenFOAM nsf OpenFOAM Meshing & Mesh Conversion 86 February 8, 2023 11:30
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 09:51
[Salome] Mesh conversion Salome to OpenFOAM VMartinez OpenFOAM Meshing & Mesh Conversion 11 April 21, 2014 03:54
