[CAD formats] How to convert an IGES hull surfaces to an OF mesh
Old   September 10, 2013, 14:57
Question How to convert an IGES hull surfaces to an OF mesh
sreibisch
Ingenieur5 is on a distinguished road
Hi all,
I have to state that I am new to OF as well as to Linux
I managed to get through some tutorials including the Wighley hull but have no clew how to convert my own hull surface (Iges format out of NAPA and modified in Rhino3D) to a format usable instead of the wighley hull. To be honest I even cannot check the tutorial input as I do not know how to get to the original wighley hull file as everything is zipped in gz-files....
Do anyone know where to find such instruction or can give it directly???
Thanks
Sönke
Ingenieur5 is offline   Reply With Quote
Old   September 10, 2013, 18:09
Joachim Herb
jherb is on a distinguished road
The Allrun script copies $FOAM_TUTORIALS/resources/geometry/wigley-scaled-oriented.stl.gz to in constant/triSurface/ your case directory.
see https://github.com/OpenFOAM/OpenFOAM...leyHull/Allrun
It is in the STL file format (compressed by gzip) https://en.wikipedia.org/wiki/STL_%28file_format%29
You can uncompress it by ungzip scaled-oriented.stl.gz
You can view it in a CAD program like FreeCAD (http://www.freecadweb.org/)
Then a mesh is created using snappyHexMesh (also see the Allrun script).
The blockMeshDict has to be adapted that your hull fits into the surrounding block mesh. Then your snappyHexMeshDict has to be modified correspondingly (e.g. for different names/sizes of the surfaces).
So I guess you have to learn how to use snappyHexMesh.
jherb is offline   Reply With Quote
Old   September 11, 2013, 05:11
colinB is on a distinguished road
Dear Soenke,
if you have Rhino you can export your iges file to stl (ascii)
and use this together with snappyHexMesh and blockMesh
to create an openfoam-mesh.
How to do this I recommend you to go through the motorbike
and the damBreak tutorials (motorbike for snappyHexMehs
and damBreak for multiphase) both of them are also briefly
explained in the user guide.
I hope this helps you
regards
Colin
colinB is offline   Reply With Quote
Old   September 13, 2013, 15:15
Question
sreibisch
is there a description for the single steps of the mentioned motorbike tutorial? I fear just to run the allrunn command doesn't help to learn and understand snappyhexmesh, or?
regards
Sönke
Old   September 13, 2013, 17:22
Joachim Herb
Look inside the Allrun script to see what programs are called. The configuration for snappyHexMesh is system/snappyHexMeshDict
A documentation of snappyHexMesh can be found e.g. here: http://openfoamwiki.net/index.php/Sn...als_and_Guides
conversion, iges, mesh, rhino3d
Tool to convert OpenFoam mesh to SU2 mesh (2D and 3D) Combas SU2 45 October 16, 2024 18:26
y+ = 1 boundary layer mesh with snappyHexMesh Arzed23 OpenFOAM Running, Solving & CFD 6 November 23, 2022 16:15
[snappyHexMesh] Disturbance in the mesh after the addition of layers Dorian1504 OpenFOAM Meshing & Mesh Conversion 0 June 13, 2017 03:27
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 01:27
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
