[blockMesh] Problem with blockMesh on 3D WING |
August 14, 2013, 03:34 |
Pepe Perez
Rep Power: 13 |
Hello, i'm trying to mesh a wing, and a model body-wong in 3D with blockMesh, but after dealing and struggling with it i'm getting quite upset. I can't get "OK" with checkMesh, since always got orthogonality and aspect ratio problems. i shouldn't decrease grading too much cause i need low y+
Could anybody help me out with both meshes? |
August 14, 2013, 03:58 |
Miro
Rep Power: 13 |
BlockMesh is not an easy tool to create mesh with, it is possible but it takes a lot of time... There are matlab scripts that make dictionaries (that can be found online) for BM but you can never know how correct they are, and if they would work with your airfoil. So, You should use snappyHexMesh, there is wingmotion tutorial in /incompressible/pimpleDyMFoam/wingMotion, there is a dictionary that will be usefull. Also, you should make your stl as fine as possible. Ask if you have further questions, - miro Last edited by miro2000; August 14, 2013 at 04:01. Reason: to much words |
Ffd_control_point_2d | feiyi | SU2 | 4 | September 30, 2019 12:42 |
Optimization Problem of ONERA M6 wing in SU2 | lbfhappy | SU2 Shape Design | 0 | November 10, 2017 08:31 |
[blockMesh] Problem using C in blockMesh | DeAldeEiam | OpenFOAM Meshing & Mesh Conversion | 3 | November 7, 2017 16:30 |
[blockMesh] Wing Flap Mesh - BlockMesh | kyounes | OpenFOAM Meshing & Mesh Conversion | 0 | November 29, 2016 21:31 |
blockMesh problem | shangzung | OpenFOAM | 5 | December 9, 2009 08:18 |
