[Other] orient and/or flip face normals
Old   July 3, 2013, 07:54
Default orient and/or flip face normals
hfs
hfs is on a distinguished road
How can we orient or flip face normals? I have an internal patch .. some of its faces have reverse normals so I have to flip them. Any ideas?
Regards
hfs is offline   Reply With Quote
Old   July 3, 2013, 07:56
hfs
I have got the internal patch after using snappyHexMesh .. and then createBuffles ..
Old   July 3, 2013, 08:05
hfs
Originally Posted by hfs View Post
Regards
ScreenShots:
Old   July 3, 2013, 09:55
hfs
Detailed description of the problem is posted here:
http://www.cfd-online.com/Forums/ope...tml#post437560
Old   August 14, 2015, 09:46
Default Hi hfs
Manjunath Reddy
manju819 is on a distinguished road
You can use the flip option to revert the normals.
for example this is my cyclic patch
cyclicFaces1
type faceZone;
zoneName jetFan1;
patches
master
name jetFan1_half0;
type cyclic;
featureCos 0.9;
neighbourPatch jetFan1_half1;
slave
name jetFan1_half1;
type cyclic;
featureCos 0.9;
neighbourPatch jetFan1_half0;
which get the directions by default from the mesh orientation. Now If want to revert I put the option flip true; as shown below
cyclicFaces1
type faceZone;
zoneName jetFan1;
flip true;
patches
master
name jetFan1_half0;
type cyclic;
featureCos 0.9;
slave
name jetFan1_half1;
type cyclic;
featureCos 0.9;
and then if you run createBaffles it will revert the normals.
manju819 is offline   Reply With Quote
Old   February 15, 2018, 05:33
Sam
anufagbemi is on a distinguished road
how can you tell if your normals have been flipped or wrong orientation in openfoam/paraview.
anufagbemi is offline   Reply With Quote
Old   May 24, 2018, 15:34
Jaydeep
jaydeep is on a distinguished road
Open your stl/surface in paraview -
sources >> search >> generate surface normals
then
sources >> glyph >> select normals under vectors
jaydeep is offline   Reply With Quote
Simulating fire in a tunnel luca1992 OpenFOAM 14 August 16, 2017 14:50
Error message: 8 face(s) not in face lists of adjacent cells jyoung79 FLUENT 0 November 10, 2012 17:09
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
Error Orient Face incorrect MK Siemens 5 January 19, 2009 09:46
WARNING: non-positive face area exist. Alan Main CFD Forum 4 August 17, 2006 08:33
