June 26, 2013, 11:41 |
snappyHexMesh
Mitchell Long
Hey Everyone,
I am currently running the blockMesh-snappyHexMesh combo, but I need some help. I'm trying to get the mesh around my imported object to have a finer mesh. As of now, the gradient of mesh fineness quickly turns the mesh into rather large cells. Is there a way to make the mesh generated around the object to expand to the entire blockmesh or at least a direction? |
June 26, 2013, 12:52 |
Daniel P. Combest
In snappyHexMesh, you can do some distance refinement from the .stl surface doing something like
refinementRegions { sphere.stl { // refinement level 5 within 1.0 m mode distance; // refinement level 3 within 2.0 m levels ((1.0 5) (2.0 3)); // levels must be ordered nearest first } } |
blockmesh, mesh, snappyhexmesh |
[CAD formats] Creating waterproof STL using snappyHexMesh or salome | Tobi | OpenFOAM Meshing & Mesh Conversion | 58 | May 13, 2020 07:01 |
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing | peterhess | OpenFOAM Meshing & Mesh Conversion | 2 | January 3, 2018 03:54 |
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. | jasv | OpenFOAM Meshing & Mesh Conversion | 4 | May 10, 2016 03:55 |
[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? | klausb | OpenFOAM Meshing & Mesh Conversion | 1 | March 7, 2015 12:55 |
[snappyHexMesh] stitchMesh and snappyHexMesh | gdbaldw | OpenFOAM Meshing & Mesh Conversion | 0 | December 23, 2009 03:09 |
