[snappyHexMesh] SnappyHexMesh for airfoil 2D case: High computational effort for low quality mesh |
October 31, 2014, 12:25 |
#21 | |
Srsh
Rep Power: 12 |
Thank you for your helpful comment. Actually I used writeMeshObj command to transfer mesh to .obj file and after that I wrote a code to change it to plot3d file. Right now I am dealing with reducing the amount of refinement levels in some part of mesh. I used 4 level of refinement to have fine grids but in some parts having fine mesh is redundant and computationally is time consuming. Do you think SHM has the option to reduce some level of refinement for cut cells? I upload a picture to show what exactly I mean. Thank you so much. Best regards, Srsh |
December 8, 2014, 15:09 |
#22 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Srsh,
Sorry, my to-do list is getting longer and I'm not finding the time needed to answer everyone Could you provide a schematic of the mesh you're trying to achieve? Because from that image, my best guess is that you should be meshing in smaller parts and then merging+stitching the various parts together. To try and see what I'm referring to, have a look at the images and descriptions on this subsection: http://openfoamwiki.net/index.php/Sn...sBetweenLevels Best regards, Bruno
February 17, 2015, 13:35 |
#23 | |
Srsh
Rep Power: 12 |
Thank you very much for your response. Actually after generating mesh, in next level I am trying to merge blocks in regions that are not necessary and lower the computational time. I am trying to merge blocks to larger blocks in the regions that I don't care about. For example I attached two pictures which the second one is somehow a desired mesh that I am looking for. I was wondering if SHM have this option to let me merge blocks to larger blocks after I generate initial grids? Thank you again, Srsh |
February 20, 2015, 16:17 |
#24 | |
Bruno Santos
Rep Power: 128 |
Hi Srsh,
Uhm... be very careful with what kind of mesh refinement transitions you're aiming for... because you're seriously risking having something even worse than this example: http://www.cfd-online.com/Forums/ope...tml#post446350 - read post #17. Quote:
The best you can achieve is doing some strategic refinements by using first refineHexMesh or refineMesh and then use snappyHexMesh to remove the cells you don't need. Best regards, Bruno
meshing a 2d, snappyhexmesh 2d |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
[ANSYS Meshing] High quality unstructured hybrid mesh around ship | flinde | ANSYS Meshing & Geometry | 2 | March 3, 2015 19:04 |
2d irregular grid | Remy | Main CFD Forum | 1 | December 22, 2008 05:49 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 13:24 |
