[Other] An appropriate Mesher for creating sliding interface
Old   May 5, 2013, 08:08
Default An appropriate Mesher for creating sliding interface
Sasan Ghomi
sasanghomi is on a distinguished road
Hi foamers,
I have a big problem for creating sliding interface for engine simulation.I created the mesh by using GAMBIT several times and unfortunately I couldn't succeed to run the case.I have an error :
Starting time loop
Courant Number mean: 0 max: 0 velocity magnitude: 0
deltaT = 5.55556e-05
Crank angle = 0.5 CA-deg
CG:  Solving for motionUx, Initial residual = 0, Final residual = 0, No Iterations 0
CG:  Solving for motionUy, Initial residual = 0, Final residual = 0, No Iterations 0
CG:  Solving for motionUz, Initial residual = 0.300902, Final residual = 0.000253697, No Iterations 57
CG:  Solving for motionUz, Initial residual = 0.000128037, Final residual = 1.20295e-07, No Iterations 66
Volume: new = 1.48807e-05 old = 1.48706e-05 change = 1.00444e-08
Motion continuity errors : sum local = 2.23621e-15, maximum = 3.88355e-14
Floating point exception (core dumped)
I know this error comes from setting the sliding interface and I think GAMBIT can't create a good mesh for using sliding interface!!!
Do you know any meshers that can create a good mesh for using sliding interface?
I appreciate your help.
Thanks and best regards,
Sasan.
sasanghomi is offline   Reply With Quote
Old   May 5, 2013, 16:23
Default GAMBIT mesh test on checkMesh
JR22's Avatar
Jose Rey
JR22 will become famous soon enough
Can you run the checkMesh utility on your converted mesh? It might give some clues. What does it say?
JR22 is offline   Reply With Quote
Old   May 5, 2013, 16:24
Sasan Ghomi
thanks for your reply jose ,
checkMesh is Ok.
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Large velocity error near sliding mesh interface davidrobinson50 CFX 2 November 6, 2013 07:46
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
[Other] Sliding interface tutorial davidmd OpenFOAM Meshing & Mesh Conversion 0 May 16, 2013 07:46
