[Commercial meshers] Import mesh with internal face from Fluent to openfoam 2.1.1
Old   April 26, 2013, 03:46
Default Import mesh with internal face from Fluent to openfoam 2.1.1
neeraj's Avatar
OpenFoam
neeraj is on a distinguished road
Hi all,
I have a closed loop flow problem. I want to model a pressure drop(to simulate forced convection) across a internal face using "fan" boundary condition in openfoam 2.1.1. I am using Gambit to generate mesh and then "FluentMeshToFoam" command to import it to OF. The steps given in openfoamwiki is not working with OF 2.1.1. How to import a mesh with internal face in OF 2.1.1?
neeraj is offline   Reply With Quote
Old   April 29, 2013, 04:54
Nima Samkhaniani
nimasam is on a distinguished road
its fluentMeshToFoam not FluentMeshToFoam (F is not capital :P)
however, your case is 2D or 3D? if it is 3D cases, you should use fluent3DMeshToFoam
if there is an error, you should post your error here, then any one would help you
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
fan type, fluentmeshtofoam, internal faces
[snappyHexMesh] Help with Snappy: no layers growing GianF OpenFOAM Meshing & Mesh Conversion 2 September 23, 2020 09:26
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
