[snappyHexMesh] Internal layers in snappyHexMesh
Old   April 16, 2013, 12:00
Default Internal layers in snappyHexMesh
RDG
onyir is on a distinguished road
Hi.
I'm trying to use sHM to produce a mesh of an aircraft. For that purpose I use 2 stls file: one for the aircraft geometry and another one for the wake.
The stl for the wake is a non-closed surface.
What I want is snappy to produce layers of cells in the wake as it does on the aircraft surface.
By doing that I end up with a new wall patch for the wake that I'm not able to get rid off.
Does anyone have a working solution for that?
Thanks.
onyir is offline   Reply With Quote
[snappyHexMesh] Multi Layers SnappyHexMesh cutmountain OpenFOAM Meshing & Mesh Conversion 1 March 28, 2019 11:03
[snappyHexMesh] First try at snappyHexMesh... jaggies, weirdness and missing boundary layers :( KarenRei OpenFOAM Meshing & Mesh Conversion 4 October 15, 2016 20:42
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 23:38
[snappyHexMesh] snappyHexMesh and blockMesh for internal flow (leaking geometry?) vaina74 OpenFOAM Meshing & Mesh Conversion 10 November 20, 2014 10:14
[snappyHexMesh] SnappyHexMesh doesn't succeed in adding several layers eti0123456789 OpenFOAM Meshing & Mesh Conversion 5 April 9, 2013 03:36
