[Gmsh] MVG with Gmsh for OpenFOAM
Old   March 20, 2013, 05:00
Default MVG with Gmsh for OpenFOAM
Felipe Alves Portela
fportela is on a distinguished road
Hello OpenFOAMers!
I am trying to generate a mesh of a MVG like this one: http://www.hindawi.com/journals/mse/2011/934982/
I have tried using Gmsh, but the quality of the mesh on the sides near the sharp angle is always very bad. The good thing about Gmsh is that I could easily prescribe cyclic boundaries.
Does any one have any tips for this kind of situation? Or on how to go around this bad cells issue?
fportela is offline   Reply With Quote
Old   March 25, 2013, 17:44
Retired Super Moderator
Bruno Santos
Greetings Felipe,
Does it have to be Gmsh? I ask this because if you are going to use OpenFOAM, you can use a few other meshers and auxiliary applications, such as:
Best regards,
Bruno
Old   March 26, 2013, 04:57
Hi Bruno,
Thanks for the tips!
Indeed, there is no particular need to use Gmsh, it's just that I am more used to it.
I already tried using snappyHexMesh (with a procedure similar to that of SwiftSnap) but then I lose a bit of geometry detail... Also I got the feeling that the overall quality of the mesh decreases a lot (whilst when using Gmsh the problem is localized).
I will have a loop at SwiftBlock and see what I can manage!
Cheers
[Gmsh] Converting gmsh to OpenFoam Friendly OpenFOAM Meshing & Mesh Conversion 3 June 26, 2018 06:46
[Gmsh] Insatlling gmsh from the source code-issue? CFD-Lover OpenFOAM Meshing & Mesh Conversion 20 June 12, 2018 07:39
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
[Gmsh] gmshToFoam problem: not the same mesh in Gmsh vs. paraview zhernadi OpenFOAM Meshing & Mesh Conversion 8 July 7, 2011 03:28
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
