[snappyHexMesh] snappy works but does not add layers...why?
Old   May 28, 2013, 10:03
Default snap
  #21
sh.d is on a distinguished road
is it right:?
1:run blockMesh
2:snappyhexMeshDict -overwite
3:extrudeMesh
sh.d is offline   Reply With Quote
Old   May 28, 2013, 10:06
is it right?
1:run blockMesh
2:run snappyHexMeshDict -overwrite
3:run extrudeMesh
Old   May 28, 2013, 10:57
sandy
sandy13 is on a distinguished road
Originally Posted by sandy13 View Post
Dear searcher,
Sorry I can not help you that much about this error, and I did not use extrudeMesh before, sorry again and good luck with your research.
Sandy,
Dear nimasam,
Could you please help me with something.. I am trying to do simulation for a swirl atomization with OF 2.1.1, interFoam solver. My geometry is like in the attached picture, I want to use blockMesh to construct the mesh but I have a problem in defining the internal walls for the mixing region.
Sandy,
sandy13 is offline   Reply With Quote
Old   May 28, 2013, 11:00
sandy
Originally Posted by nimasam View Post
did you try to use extrudeMesh ?
Hi nimasam,
this is my geometry
https://www.dropbox.com/home/openfoam-shear
Sandy,
Old   May 29, 2013, 07:42
Nima Samkhaniani
nimasam is on a distinguished road
Originally Posted by sh.d View Post
Hi nimasam
yes i use the extrudMesh
please look at the my testcase
Hi
i saw your test case, good job , whats the problem?
its 2D now and there are several layers around airfoil.
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   May 29, 2013, 07:45
Nima Samkhaniani
is it right:?
1:run blockMesh
3:extrudeMesh
yep its right
1- blockMesh
make your base mesh
2- snappyHesMesh -overwrite
extract your airfoil in it
3- extrudeMesh
you can derive one cell thick geometry
Old   May 29, 2013, 07:48
Nima Samkhaniani
Hi nimasam,
this is my geometry
Sandy,
Dear Sandy
i guess, you need to make a public link in dropBox, then i would access your link
now i can not see any thing
Old   May 30, 2013, 07:17
sandy
Dear Sandy
Dear nimasam,
I am sorry, this the link again and hope it is working
https://www.dropbox.com/s/9o0bpfehxpp2cwz/img007.jpg
Sandy,
Old   May 30, 2013, 08:12
Nima Samkhaniani
dear sandy i suggest to use snappyHexMesh, you can create your mesh in a CAD software, then easily with snappyHexMesh you can mesh your geometry
Old   May 30, 2013, 09:15
Default blockMesh
  #30
sandy
Dear nimasam,
Thank you for your advice. So as you suggested there is no way to use blockMesh and the only way is CAD and snappy . It is impossible or possible but very difficult by blockMesh?
Sandy,
Old   May 30, 2013, 09:20
Nima Samkhaniani
i guess its possible, you should define several blocks, but it would not be easy tasks and you need to be patient enough
Old   May 30, 2013, 10:04
Default blockMesh
  #32
sandy
Thank you so much, I will try to do it by blockMesh, can I ask you If I stuck or had a problem in it?
Sandy,
Old   May 30, 2013, 10:11
Nima Samkhaniani
you can post your problems here, forum users will try to help you
Old   November 19, 2020, 16:23
Default Try this...it should work
  #34
mp717 is on a distinguished road
In snappHexMeshDict, do not forget to add this part otherwise snappyHexMesh will work but still layers wont be added.
features
file "yourcase.eMesh";
level yourinput;
Example:
features
file "motorbike.eMesh";
level 6;
The thread is too old still posting if someone got stuck like I was due to this.
Hope it helps
Thank you !
mp717 is offline   Reply With Quote
[snappyHexMesh] Impossible to add layers in SnappyHexMesh knightwalker OpenFOAM Meshing & Mesh Conversion 4 March 27, 2019 18:09
[OpenFOAM] Checking layers generated by snappy with paraview bentkj ParaView 1 February 22, 2018 04:32
[snappyHexMesh] snappy does not add layer to whole body 5tern OpenFOAM Meshing & Mesh Conversion 0 October 20, 2016 11:09
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh Elise OpenFOAM Meshing & Mesh Conversion 1 April 22, 2013 03:32
[snappyHexMesh] Add layers and deformation Prosiaczek OpenFOAM Meshing & Mesh Conversion 0 April 11, 2012 19:27
