March 19, 2013, 15:50 |
snappyHexMesh error report
Sture Smidt
Rep Power: 13 |
I get the following error report when running sHM on a simple prism. I made the .stl file myself with Rhino 5.0. I do not understand why I get two zones, volume and volume (see further down)???? sture_ii@SturePCUbuntu:~/OpenFOAM/sture_ii-2.1.1/run/analyser/kanalLangSnappy$ snappyHexMesh -overwrite /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.1-221db2718bbb Exec : snappyHexMesh -overwrite Date : Mar 19 2013 Time : 19:40:41 Host : "SturePCUbuntu" PID : 6029 Case : /home/sture_ii/OpenFOAM/sture_ii-2.1.1/run/analyser/kanalLangSnappy nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Read mesh in = 0.02 s Overall mesh bounding box : (-0.1 -0.1 -0.1) (20.1 1.1 1.1) Relative tolerance : 1e-06 Absolute matching distance : 2.02712e-05 Reading refinement surfaces. Read refinement surfaces in = 0 s Reading refinement shells. Refinement level 2 for all cells inside refinementBox Read refinement shells in = 0 s Setting refinement level of surface to be consistent with shells. Checked shell refinement in = 0 s Reading features. Read features in = 0 s Determining initial surface intersections ----------------------------------------- Edge intersection testing: Number of edges : 8525 Number of edges to retest : 8525 Number of intersected edges : 0 Calculated surface intersections in = 0.01 s Initial mesh : cells(local):2500 faces(local):8525 points(local):3636 Initial mesh : cells:2500 faces:8525 points:3636 Cells per refinement level: 0 2500 Adding patches for surface regions ---------------------------------- Patch Type Region ----- ---- ------ Added patches in = 0 s Selecting decompositionMethod simple Refinement phase ---------------- Found point (0.5 0.5 0.5) in cell 1202 on processor 0 Surface refinement iteration 0 ------------------------------ Marked for refinement due to surface intersection : 0 cells. Determined cells to refine in = 0 s Selected for refinement : 0 cells (out of 2500) Stopping refining since too few cells selected. Removing mesh beyond surface intersections ------------------------------------------ Found point (0.5 0.5 0.5) in cell 1202 in global region 0 out of 1 regions. Keeping all cells in region 0 containing point (0.5 0.5 0.5) Selected for keeping : 2500 cells. --> FOAM Warning : From function polyTopoChange::addMesh(const polyMesh&, const labelList&,const labelList&, const labelList&,const labelList&) in file polyTopoChange/polyTopoChange/polyTopoChange.C at line 2365 Cell:2500 centre0 2.43164e-319 -0.1) is in two zones:volume and volume This is not supported. Continuing with first zone only. --> FOAM Warning : From function polyTopoChange::addMesh(const polyMesh&, const labelList&,const labelList&, const labelList&,const labelList&) in file polyTopoChange/polyTopoChange/polyTopoChange.C at line 2365 Cell:2501 centre0.02 0.02 -0.1) is in two zones:volume and volume This is not supported. Continuing with first zone only. --> FOAM Warning : From function polyTopoChange::addMesh(const polyMesh&, const labelList&,const labelList&, const labelList&,const labelList&) in file polyTopoChange/polyTopoChange/polyTopoChange.C at line 2365 Cell:2502 centre0.26 0.02 -0.1) is in two zones:#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigSegv::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::OSstream::write(Foam::word const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #4 Foam:perator<<(Foam::Ostream&, Foam::word const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #5 Foam:olyTopoChange::addMesh(Foam:olyMesh const&, Foam::List<int> const&, Foam::List<int> const&, Foam::List<int> const&, Foam::List<int> const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libdynamicMesh.so" #6 Foam:olyTopoChange:olyTopoChange(Foam:olyMes h const&, bool) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libdynamicMesh.so" #7 Foam::meshRefinement::doRemoveCells(Foam::List<int > const&, Foam::List<int> const&, Foam::List<int> const&, Foam::removeCells&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libautoMesh.so" #8 Foam::meshRefinement::splitMesh(int, Foam::List<int> const&, Foam::Vector<double> const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libautoMesh.so" #9 Foam::autoRefineDriver::removeInsideCells(Foam::re finementParameters const&, int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libautoMesh.so" #10 Foam::autoRefineDriver::doRefine(Foam::dictionary const&, Foam::refinementParameters const&, bool, Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libautoMesh.so" #11 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/snappyHexMesh" #12 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #13 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/snappyHexMesh" Segmentation fault (core dumped) |
March 21, 2013, 08:59 |
Vieri Abolaffio
Rep Power: 17 |
can you post the snappyHexMeshDict? without knowing what are you ring to do it is hard to give help.
March 22, 2013, 17:12 |
Problem solved
Sture Smidt
Rep Power: 13 |
Hi, I dleted everything except the essential files and then the problem went away. Now I have to figure out how to use it...
I am now struggling with naming surfaces in a .stl file and then assign mesh levels and boundary layers. SS |
[CAD formats] Creating waterproof STL using snappyHexMesh or salome | Tobi | OpenFOAM Meshing & Mesh Conversion | 58 | May 13, 2020 07:01 |
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing | peterhess | OpenFOAM Meshing & Mesh Conversion | 2 | January 3, 2018 03:54 |
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. | jasv | OpenFOAM Meshing & Mesh Conversion | 4 | May 10, 2016 03:55 |
[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? | klausb | OpenFOAM Meshing & Mesh Conversion | 1 | March 7, 2015 12:55 |
[snappyHexMesh] stitchMesh and snappyHexMesh | gdbaldw | OpenFOAM Meshing & Mesh Conversion | 0 | December 23, 2009 03:09 |
