[snappyHexMesh] AMI-interface "cuts" water jet
Old   February 15, 2013, 08:08
Default AMI-interface "cuts" water jet
Anon
jrrygg is on a distinguished road
Hi!
I am working on simulating the flow in a Pelton bucket numerically, but I am having some trouble with the AMI-interface. I think this is related to the meshing in the AMI-patches, as they seem to not be perfectly circular as I want them to be.
I wonder if anyone has some tricks that may help me improve the representation of the flow over the interface? The AMI-patches should be circular, but how can I refine them?
My case is originally based on the propeller-tutorial, but I use the interDyMFoam-solver.
The water jet is cut in the AMI-interface:
AMI1:
AMI2:
My snappyHexMeshDict:
|  \\    /   O peration     | Version:  2.1.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap            true;
addLayers       true; //Originally false
// Geometry. Definition of all surfaces. All surfaces are of class
// searchableSurface.
// Surfaces are used
// - to specify refinement for any mesh cell intersecting it
// - to specify refinement for any mesh cell inside/outside/near
// - to 'snap' the mesh boundary to the surface
geometry
    jetinlet.obj
        type        triSurfaceMesh;
        name        jetinlet;
      regions
          jetinlet
                name       jetinlet;
    jetwalls.obj
        name        jetwalls;
         regions
             jetwalls
                  name       jetwalls;
    BBC.obj
        name        BBC;
         regions
             BBC
                  name       BBC;
    MBC.obj
        name        MBC;
         regions
             MBC
                  name       MBC;
    TBC.obj
        name        TBC;
         regions
             TBC
                  name       TBC;
    statopening.obj
        name        statopening;
         regions
             statopening
                  name       statopening;
    rotif.obj
        name        rotif;
         regions
             rotif
                  name       rotif;
    rotopen.obj
        name        rotopen;
         regions
             rotopen
                  name       rotopen;
    rotsym.obj
        name        rotsym;
         regions
             rotsym
                  name       rotsym;
    statinlet.obj
        name        statinlet;
         regions
             statinlet
                  name       statinlet;
    statsym.obj
        name        statsym;
         regions
             statsym
                  name       statsym;
// Settings for the castellatedMesh generation.
castellatedMeshControls
    // Refinement parameters
    // If local number of cells is >= maxLocalCells on any processor
    // switches from from refinement followed by balancing
    // (current method) to (weighted) balancing before refinement.
    maxLocalCells 100000;
    // Overall cell limit (approximately). Refinement will stop immediately
    // upon reaching this number so a refinement level might not complete.
    // Note that this is the number of cells before removing the part which
    // is not 'visible' from the keepPoint. The final number of cells might
    // actually be a lot less.
    maxGlobalCells 1000000;
    // The surface refinement loop might spend lots of iterations refining just a
    // few cells. This setting will cause refinement to stop if <= minimumRefine
    // are selected for refinement. Note: it will at least do one iteration
    // (unless the number of cells to refine is 0)
    minRefinementCells 0;
    // Allow a certain level of imbalance during refining
    // (since balancing is quite expensive)
    // Expressed as fraction of perfect balance (= overall number of cells /
    // nProcs). 0=balance always.
    maxLoadUnbalance 0.10;
    // Number of buffer layers between different levels.
    // 1 means normal 2:1 refinement restriction, larger means slower
    // refinement.
    nCellsBetweenLevels 2;
    // Explicit feature edge refinement
    // Specifies a level for any cell intersected by its edges.
    // This is a featureEdgeMesh, read from constant/triSurface for now.
    features
            file        "jetinlet.eMesh";
            level       3;
            file        "jetwalls.eMesh";
            level       3;
            file        "statopening.eMesh";
            level       1;
            file        "rotif.eMesh";
            level       3;
            file        "BBC.eMesh";
            level       3;
            file        "MBC.eMesh";
            level       3;
            file        "TBC.eMesh";
            level       3;
//4 nye
            file        "rotopen.eMesh";
            level       1;
            file        "rotsym.eMesh";
            level       1;
            file        "statinlet.eMesh";
            level       1;
            file        "statsym.eMesh";
            level       1;
    // Surface based refinement
    // Specifies two levels for every surface. The first is the minimum level,
    // every cell intersecting a surface gets refined up to the minimum level.
    // The second level is the maximum level. Cells that 'see' multiple
    // intersections where the intersections make an
    // angle > resolveFeatureAngle get refined up to the maximum level.
    refinementSurfaces
        BBC
            level       (2 3); //Originally (2 3) for all buckets
        MBC
            level       (2 3);
        TBC
            level       (2 3);
        rotif
            level       (2 2);
            cellZone    rotif;
            faceZone    rotif;
            cellZoneInside inside;
        statopening
            level       (1 1);
        jetinlet
            level       (2 3);
        jetwalls
            level       (2 3);
//4 nye
        rotopen
            level       (1 1);
        rotsym
            level       (2 2);
        statinlet
            level       (1 1);
        statsym
            level       (2 3);
    // Resolve sharp angles
    resolveFeatureAngle 30;
    // Region-wise refinement
    // Specifies refinement level for cells in relation to a surface. One of
    // three modes
    // - distance. 'levels' specifies per distance to the surface the
    //   wanted refinement level. The distances need to be specified in
    //   descending order.
    // - inside. 'levels' is only one entry and only the level is used. All
    //   cells inside the surface get refined up to the level. The surface
    //   needs to be closed for this to be possible.
    // - outside. Same but cells outside.
    refinementRegions
   /*     rotif
            mode        inside;
            levels      ((1E15 3));
        statinlet
            mode        inside;
            levels      ((1E15 0));
	  MBC
             mode        distance;
             levels      ((0.05 5));
	  TBC
             mode        distance;
             levels      ((0.05 5));
	  BBC
             mode        distance;
             levels      ((0.05 5));
	  jetwalls
             mode        distance;
             levels      ((0.01 5));
	  jetinlet
             mode        distance;
             levels      ((0.01 5));
    // Mesh selection
    // After refinement patches get added for all refinementSurfaces and
    // all cells intersecting the surfaces get put into these patches. The
    // section reachable from the locationInMesh is kept.
    // NOTE: This point should never be on a face, always inside a cell, even
    // after refinement.
   // locationInMesh (21 601.1 211.1);
   locationInMesh (-0.20545645 0.111378 0.202156456); //Originalt (0.37046464 0.111378 0.37046464)
    // Whether any faceZones (as specified in the refinementSurfaces)
    // are only on the boundary of corresponding cellZones or also allow
    // free-standing zone faces. Not used if there are no faceZones.
    allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
    //- Number of patch smoothing iterations before finding correspondence
    //  to surface
    nSmoothPatch 5; //Originally 3
    //- Relative distance for points to be attracted by surface feature point
    //  or edge. True distance is this factor times local
    //  maximum edge length.
    tolerance 4.0; // 1.0;
    //- Number of mesh displacement relaxation iterations.
    nSolveIter 20;
    //- Maximum number of snapping relaxation iterations. Should stop
    //  before upon reaching a correct mesh.
    nRelaxIter 6; //Originally 5
    //- Highly experimental and wip: number of feature edge snapping
    //  iterations. Leave out altogether to disable.
    //  Do not use here since mesh resolution too low and baffles present
    nFeatureSnapIter 20;
// Settings for the layer addition.
addLayersControls
    // Are the thickness parameters below relative to the undistorted
    // size of the refined cell outside layer (true) or absolute sizes (false).
    relativeSizes true;
    // Per final patch (so not geometry!) the layer information
    layers
    // Expansion factor for layer mesh
    expansionRatio 1.0;
    //- Wanted thickness of final added cell layer. If multiple layers
    //  is the
    //  thickness of the layer furthest away from the wall.
    //  Relative to undistorted size of cell outside layer.
    //  is the thickness of the layer furthest away from the wall.
    //  See relativeSizes parameter.
    finalLayerThickness 0.3;
    //- Minimum thickness of cell layer. If for any reason layer
    //  cannot be above minThickness do not add layer.
    minThickness 0.1;
    //- If points get not extruded do nGrow layers of connected faces that are
    //  also not grown. This helps convergence of the layer addition process
    //  close to features.
    // Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x)
    nGrow 0;
    // Advanced settings
    //- When not to extrude surface. 0 is flat surface, 90 is when two faces
    //  make straight angle.
    featureAngle 30;
    nRelaxIter 3;
    // Number of smoothing iterations of surface normals
    nSmoothSurfaceNormals 1;
    // Number of smoothing iterations of interior mesh movement direction
    nSmoothNormals 3;
    // Smooth layer thickness over surface patches
    nSmoothThickness 10;
    // Stop layer growth on highly warped cells
    maxFaceThicknessRatio 0.5;
    // Reduce layer growth where ratio thickness to medial
    // distance is large
    maxThicknessToMedialRatio 0.3;
    // Angle used to pick up medial axis points
    // Note: changed(corrected) w.r.t 17x! 90 degrees corresponds to 130 in 17x.
    minMedianAxisAngle 90;
    // Create buffer region for new layer terminations
    nBufferCellsNoExtrude 0;
    // Overall max number of layer addition iterations. The mesher will exit
    // if it reaches this number of iterations; possibly with an illegal
    // mesh.
    nLayerIter 50;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
    //- Maximum non-orthogonality allowed. Set to 180 to disable.
    maxNonOrtho 45; //Originally 65
    //- Max skewness allowed. Set to <0 to disable.
    maxBoundarySkewness 20;
    maxInternalSkewness 4;
    //- Max concaveness allowed. Is angle (in degrees) below which concavity
    //  is allowed. 0 is straight face, <0 would be convex face.
    //  Set to 180 to disable.
    maxConcave 80;
    //- Minimum pyramid volume. Is absolute volume of cell pyramid.
    //  Set to a sensible fraction of the smallest cell volume expected.
    //  Set to very negative number (e.g. -1E30) to disable.
    minVol 1e-13;
    //- Minimum quality of the tet formed by the face-centre
    //  and variable base point minimum decomposition triangles and
    //  the cell centre. This has to be a positive number for tracking
    //  to work. Set to very negative number (e.g. -1E30) to
    //  disable.
    //     <0 = inside out tet,
    //      0 = flat tet
    //      1 = regular tet
    minTetQuality -1; // 1e-30;
    //- Minimum face area. Set to <0 to disable.
    minArea -1;
    //- Minimum face twist. Set to <-1 to disable. dot product of face normal
    //- and face centre triangles normal
    minTwist 0.01;
    //- minimum normalised cell determinant
    //- 1 = hex, <= 0 = folded or flattened illegal cell
    minDeterminant 0.001;
    //- minFaceWeight (0 -> 0.5)
    minFaceWeight 0.05;
    //- minVolRatio (0 -> 1)
    minVolRatio 0.01;
    //must be >0 for Fluent compatibility
    minTriangleTwist -1;
    // Advanced
    //- Number of error distribution iterations
    nSmoothScale 6; //Originally 4
    //- amount to scale back displacement at error points
    errorReduction 0.75;
    // Optional : some meshing phases allow usage of relaxed rules.
    // See e.g. addLayersControls::nRelaxedIter.
    relaxed
        maxNonOrtho 45; //Originally 75
// Advanced
// Flags for optional output
// 0 : only write final meshes
// 1 : write intermediate meshes
// 2 : write volScalarField with cellLevel for postprocessing
// 4 : write current intersections as .obj files
debug 0;
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1e-6;
My createAMIFaces.topoSetDict:
|  \\    /   O peration     | Version:  dev                                   |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      topoSetDict;
actions
        name    rotif;
        type    cellSet;
        action  new;
        source  cylinderToCell;
        sourceInfo
            p1      (0 0 0);
            p2      (0 0.13908 0);
            radius  0.3477;
        name    outerCells;
        type    cellSet;
        action  new;
        source  cellToCell;
        sourceInfo
            set rotif;
        name    outerCells;
        type    cellSet;
        action  invert;
        name    rotif;
        type    cellZoneSet;
        action  new;
        source  setToCellZone;
        sourceInfo
            set     rotif;
        name    rotifFace;
        type    faceSet;
        action  new;
        source  cellToFace;
        sourceInfo
            set     rotif;
            option  all;
        name    rotifFace;
        type    faceSet;
        action  subset;
        source  cellToFace;
        sourceInfo
            set     outerCells;
            option  all;
        name    rotif;
        type    faceZoneSet;
        action  new;
        source  setsToFaceZone;
        sourceInfo
            faceSet     rotifFace;
            cellSet     rotif;
jrrygg is offline   Reply With Quote
mapField error rvl565 OpenFOAM Pre-Processing 1 September 6, 2018 17:13
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Fluid-Solid Interface Settings for a Rotating Water Container r.mojtaba CFX 4 October 14, 2013 20:01
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
