[Other] OpenFOAM mesh generation of an aerofoil
Like Tree21Likes
Old   June 19, 2015, 13:21
Romania
yrganiri is on a distinguished road
Thank you for the help.
I have tried exactly that but I cannot make gmshToFoam to work with what I have and I really don't know what I'm doing wrong.
So, I am using the data points of RAE2822 and surround it with a C-type grid.
It looks like this: Selection_139.png
Now, my problem is that in order to make it look like that, I used many line loops and plane surfaces and I don't know how to name the physical surfaces:
Physical Surface("back") = {1042,1020,1064,1108,1125,1086};
Physical Surface("front") = {50,52,54,55,53,51};
I am attaching the .geo file naca5012_step3_structured.txt
The gmshToFoam output is:
Mapping region 2 to Foam patch 0
Mapping region 1 to Foam patch 1
Mapping region 4 to Foam patch 2
Mapping region 5 to Foam patch 3
Mapping region 3 to Foam patch 4
Cells:
    total:0
    hex  :0
    prism:0
    pyr  :0
    tet  :0
--> FOAM FATAL IO ERROR:
No cells read from file "naca5012_step3_structured.msh"
Does your file specify any 3D elements (hex=5, prism=6, pyramid=7, tet=4)?
Perhaps you have not exported the 3D elements?
yrganiri is offline   Reply With Quote
Old   June 19, 2015, 13:35
Hassan Kassem
hk318i is on a distinguished road
I had a quick look
Physical Volume("internal") = {50,52,54,55,53,51};
This definition is wrong because you don't have these volumes.
It should be
Physical Volume("internal") = {1,2,3,4,5,6};
Try it again and see if you have another problem.
It looks like this: Attachment 40246
I am attaching the .geo file Attachment 40247
Cells:
    total:0
    hex  :0
    prism:0
    pyr  :0
    tet  :0
yrganiri likes this.
hk318i is offline   Reply With Quote
Old   June 19, 2015, 13:45
Romania
Ok, so now the checkMesh fails (when I use transfinite)
Checking geometry...
    Overall domain bounding box (-7.07107 -5 0) (5 5 1)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Mesh (non-empty) directions (1 1 1)
    Boundary openness (1.63561e-17 9.81367e-18 -1.21481e-14) OK.
 ***High aspect ratio cells found, Max aspect ratio: 2729.23, number of cells 396
  <<Writing 396 cells with high aspect ratio to set highAspectRatioCells
    Minimum face area = 1.11556e-05. Maximum face area = 0.26532.  Face area magnitudes OK.
    Min volume = 1.11556e-05. Max volume = 0.0248775.  Total volume = 114.187.  Cell volumes OK.
    Mesh non-orthogonality Max: 88.9723 average: 40.767
   *Number of severely non-orthogonal (> 70 degrees) faces: 10057.
    Non-orthogonality check OK.
  <<Writing 10057 non-orthogonal faces to set nonOrthoFaces
    Face pyramids OK.
    Max skewness = 2.08422 OK.
    Coupled point location match (average 0) OK.
Failed 1 mesh checks.
It works wonderfully if I comment all the transfinite lines and just let gmsh do its meshing work.
Originally Posted by hk318i View Post
I had a quick look
It should be
Old   June 19, 2015, 13:54
Hassan Kassem
It isn't easy to get the right mesh from the first trial. You can check the location of these high aspect ratio cells in paraView
@HIKassem | HassanKassem.me
Old   June 23, 2015, 15:08
adhi makayasa
makayasa is on a distinguished road
Hello all. After converting gmsh to foam and I run , why the results in the show is not like the one in the tutorial ? I run simplefoam for airfoil2d case . Location of faults where ? How do I fix it ? This is my final project. Please advise. Thank you very much
File Type: jpg Screenshot from 2015-06-24 01:13:14.jpg (41.5 KB, 49 views)
File Type: jpg Screenshot from 2015-06-24 01:13:21.jpg (41.0 KB, 40 views)
makayasa is offline   Reply With Quote
Old   June 23, 2015, 16:20
Romania
Did you properly edit the 0/p 0/U ... and system/controlDict files with the same patch names as your mesh? Look at this example: https://community.dur.ac.uk/g.l.ingr...torial2012.pdf
Old   June 23, 2015, 16:28
Hassan Kassem
It looks like the initial conditions, zero time.
Old   November 4, 2015, 15:16
bernardo
bfigueroae is on a distinguished road
Originally Posted by MadsR View Post
Thanks for the kind words
I made it some years ago - it has its flaws I am sure, but seems to be used quite a bit. You are of course most welcome to send me feedback.
Mads
hi MadSr. How do I cite http://hvirvel.dk/airfoilmesher/ (in a PhD thesis) ?
bfigueroae is offline   Reply With Quote
Old   March 15, 2018, 11:56
Lennart
elmo555 is on a distinguished road
Just to clarify: there is nothing to download from http://hvirvel.dk/airfoilmesher/ . You just upload your airfoil x,y data and you get a blockMeshDict thrown back in your face
Mads
Hey Mads,
I just tried to use your mesher with default settings (also no airfoil data file), and unfortunately the generated blockMeshDict seems to be broken:
	Basic statistics
		Number of internal faces : 4
		Number of boundary faces : 16
		Number of defined boundary faces : 16
		Number of undefined boundary faces : 0
	Checking patch -> block consistency
--> FOAM FATAL ERROR:
Block mesh topology incorrect, stopping mesh generation!
    From function void Foam::blockMesh::check(const Foam::polyMesh&, const Foam::dictionary&) const
    in file blockMesh/blockMeshCheck.C at line 228.
FOAM exiting
elmo555 is offline   Reply With Quote
Old   March 31, 2019, 19:38
sibo
sibo is on a distinguished road
Mads
Hi Mads,
I'm wondering which format should we use for the coordinates file when generating a different airfoil?
Thanks!
sibo is offline   Reply With Quote
Old   March 31, 2019, 19:51
sibo
Mads
Hi Mads,
Firstly, thanks for the mesher you provided. I'm just wondering when we submit the airfoil coordinates, which format should we use?
Because I tried .dat, .txt and .rtf, they don't work.
Thanks a lot for the help!
Sincerely
Old   April 1, 2019, 10:48
sibo
Hi Niels,
I'm wondering which format should we use when submitting a file?
Thanks a lot!
aerofoils
[snappyHexMesh] OpenFOAM mesh generation for irregular open channel ksmithgall OpenFOAM Meshing & Mesh Conversion 2 June 22, 2017 21:16
On body-fitted cartesian mesh generation sbaffini Main CFD Forum 0 October 21, 2016 11:32
[Salome] Mesh conversion Salome to OpenFOAM VMartinez OpenFOAM Meshing & Mesh Conversion 11 April 21, 2014 03:54
[Workbench] Aerofoil mesh generation problem elebelly ANSYS Meshing & Geometry 1 February 26, 2014 09:53
salome, openfoam and moving mesh prhlava OpenFOAM Running, Solving & CFD 8 November 9, 2009 09:59
