[mesh manipulation] Smoothing a mesh from blockMesh
Old   December 22, 2012, 07:01
Default Smoothing a mesh from blockMesh
Paulo Vatavuk
vatavuk is on a distinguished road
I created a mesh using blockmesh but I'm not happy with the result in the boundary between blocks. In this region the lines sudenly change direction (See the picture below). Is there any free tool that can improve the mesh by relocating the vertexes?
Merry Christmas and Happy Holidays to all
Paulo
vatavuk is offline   Reply With Quote
Old   December 23, 2012, 05:27
Karl-Johan Nogenmyr
kalle is on a distinguished road
I am not aware of any tools for OpenFOAM to smooth blockMesh-meshes. However, there is a branch in 1.6-ext called "feature/mesquiteHexPrismSupport". The 3rd party Mesquite code can do this as far as I understood. It should be possible to use the code in that branch to build a new blockMesh application, which could have more input in blockMeshDict to control the Mesquite code, and let it do the smoothing. This should not be too much coding, but I have not had the time to implement it. If people are interested, and believes in the idea, we could maybe start up a joint effort. (I would also like to rewrite blockMesh to do surface snapping, using mesh motion solvers, but that is a different story)
K
kalle is offline   Reply With Quote
Old   December 23, 2012, 09:49
Paulo Vatavuk
Hi Karl,
I've been looking in the Mesquite documentation and it really seems to do smoothing. But this code does not work by itself it needs a kind of interface to work with OpenFoam. It seems this had been already done, as is mentioned in this thread http://www.cfd-online.com/Forums/ope...smoothing.html.
In the above thread, we see that there is an example of smoothing, but I would need more precise instructions to be able to do this in my case.
Thanks and Happy Holidays
Old   December 24, 2012, 14:18
Retired Super Moderator
Bruno Santos
Greetings to all!
@Paulo: There are two applications in OpenFOAM that I can think of:
  • modifyMesh - very tricky to use, but it provides the basic tools for mesh manipulation.
  • moveDynamicMesh - you can create an interface (of faceSets?) in the faces/cells that need to be moved... there are a few examples I can think of for dynamic meshes that might come in handy as references:
Best regards,
Bruno
blockmesh, mesh smoothing
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[ICEM] Problem with exporting mesh after smoothing Wroobs ANSYS Meshing & Geometry 2 January 4, 2018 17:12
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 12:14
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
