December 12, 2012, 09:19 |
SnappyHexMesh cell removal
Ali
Rep Power: 14 |
Hi
I have a triangulated surface in STL format. SnappyHexMesh generates a mesh outside the surface and removes the cells that are located inside like Fig.5-12 in OpenFoam user guide. However since I need to do the simulation inside I want to retain the cells there and remove the ones outside the surface. I wonder if someone knows how to do that. Thanks in advance |
December 12, 2012, 10:22 |
stephane sanchi
Rep Power: 18 |
edit your system/snappyHexMeshDict file and modify the following line: locationInMesh (-1.0 0.0 3.5 ); The location must be where you want to keep the cells. Regards, Stephane. |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 03:36 |
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! | divergence | OpenFOAM Meshing & Mesh Conversion | 0 | January 23, 2019 05:17 |
[snappyHexMesh] Problem with SnappyHexMesh Cell Removal | MoeCFD | OpenFOAM Meshing & Mesh Conversion | 0 | July 7, 2017 13:55 |
[snappyHexMesh] Problem with snappyhexMesh: modelling a pore chamber and pore throat model | Saideep | OpenFOAM Meshing & Mesh Conversion | 5 | May 10, 2015 15:46 |
Journal file error | magicalmarshmallow | FLUENT | 3 | April 4, 2014 13:25 |
