[blockMesh] Graded Mesh Calculator
Old   November 12, 2012, 15:51
Default Graded Mesh Calculator
Nikunj Raithatha
Nikunj.R is on a distinguished road
Hello All!
I wanted to determine the size of cells when using grading. In the example that I am running, the length of the block is 1.2 m, with 20 cells in the direction where grading is applied and 0.05 is the ratio (between the first cell and the last cell). How can i know the length of each cell in the graded direction. I know that gradind calculator has been presented here, but extracting it is giving errors.
Thanks for your help.
Regards,
Nikunj.
Nikunj.R is offline   Reply With Quote
Old   November 12, 2012, 18:06
Retired Super Moderator
Bruno Santos
Greetings Nikunj,
I'm sorry to say I can't help you with this (no time to test), but I know that the plug-in SwiftBlock for Blender might help you: http://openfoamwiki.net/index.php/SwiftBlock
I say this because of this post: http://www.cfd-online.com/Forums/ope...tml#post390786 - post #48
Best regards,
Bruno
Old   November 14, 2012, 11:09
Nikunj Raithatha
Thanks for your reply Bruno! It was really helpful.
Regards,
Nikunj.
[Other] conformed FSI mesh for unstructured fluid region ashish.svm OpenFOAM Meshing & Mesh Conversion 10 August 2, 2019 09:40
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 18:16
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 05:17
[ICEM] 2D hybrid mesh (unstructured mesh highly dependent on structured mesh parameters) shubham jain ANSYS Meshing & Geometry 1 April 10, 2017 06:03
[snappyHexMesh] Snappyhex mesh: poor inlet mesh Swagga5aur OpenFOAM Meshing & Mesh Conversion 1 December 3, 2016 17:59
