[snappyHexMesh] snappyHexMesh, complex geometry |
October 14, 2012, 12:47 |
#1 | |
Romain
Rep Power: 16 |
since a few days I was using snappyHexMesh without any problem, but since I tried to switch to a more complex geometry it is not working anymore. I have an error when I use splitMeshRegion -cellZonesOnly. My error is the following one : Code:
--> FOAM FATAL ERROR: Face 20096 fc:(-0.0031125 -0.0015 -0.027975) in zone solid1 is in patch air_out and in patch solid1 I do not understand how a cell could be outside a cell zone since the air outside of the other solids is obtained by cutting all of the solid from a box which is of the domain of calculation size. If I do not use the option cellZonesOnly, I something like 500 domains, which is not acceptable. I use the Allrun from snappyMultiRegionHeater Code:
runApplication blockMesh runApplication surfaceFeatureExtract -includedAngle 150 constant/triSurface/Region1.stl Region1 mv log.surfaceFeatureExtract log.surfaceFeatureExtract.Region runApplication surfaceFeatureExtract -includedAngle 150 constant/triSurface/Region2.stl Region2 mv log.surfaceFeatureExtract log.surfaceFeatureExtract.Region2 runApplication surfaceFeatureExtract -includedAngle 150 constant/triSurface/Region3.stl Region3 mv log.surfaceFeatureExtract log.surfaceFeatureExtract.Region3 runApplication surfaceFeatureExtract -includedAngle 150 constant/triSurface/Region4.stl Region4 mv log.surfaceFeatureExtract log.surfaceFeatureExtract.Region4 runApplication snappyHexMesh -overwrite runApplication splitMeshRegions -cellZonesOnly -overwrite Code:
FoamFile { version 2.0; format ascii; class dictionary; location system; object snappyHexMeshDict; } castellatedMesh true; snap true; addLayers true; geometry { air_out.stl { type triSurfaceMesh; name air_out; } Region1.stl { type triSurfaceMesh; name Region1; } Region2.stl { type triSurfaceMesh; name Region2; } Region3.stl { type triSurfaceMesh; name Region3; } Region4.stl { type triSurfaceMesh; name Region4; } } castellatedMeshControls { features ( { file "Region1.eMesh"; level 1; } { file "Region2.eMesh"; level 1; } { file "Region3.eMesh"; level 1; } { file "Region4.eMesh"; level 1; } { file "air_out.eMesh"; level 1; } ); refinementSurfaces { Region1 { cellZoneInside inside; cellZone Region1; level (3 3 ); faceZone Region1; } air_out { cellZoneInside inside; cellZone air_out; level (1 1 ); faceZone air_out; } Region2 { level (3 3 ); cellZoneInside inside; cellZone Region2; faceZone Region3; } Region3 { level (3 3 ); cellZoneInside inside; cellZone Region3; faceZone Region3; } Region4 { cellZoneInside Region4; cellZone Region4; level (1 1 ); faceZone Region4; } } refinementRegions { } locationInMesh (0 0 0); maxLocalCells 10000000; maxGlobalCells 20000000; minRefinementCells 1; nCellsBetweenLevels 2; resolveFeatureAngle 30; allowFreeStandingZoneFaces false; } snapControls { nSolveIter 30; nSmoothPatch 3; tolerance 4.0; nRelaxIter 5; nFeatureSnapIter 10; } addLayersControls { layers { } relativeSizes true; expansionRatio 1.0; finalLayerThickness 0.3; minThickness 0.2; nGrow 1; featureAngle 60; nRelaxIter 5; nSmoothSurfaceNormals 1; nSmoothNormals 3; nSmoothThickness 10; maxFaceThicknessRatio 0.5; maxThicknessToMedialRatio 0.3; minMedianAxisAngle 130; nBufferCellsNoExtrude 0; nLayerIter 50; nRelaxedIter 20; } meshQualityControls { maxNonOrtho 65; maxBoundarySkewness 20; maxInternalSkewness 4; maxConcave 80; minFlatness 0.5; minVol 1.00E-13; minTetQuality -1e30; //1e-30 ; minArea -1; minTwist 0.05; minDeterminant 0.001; minFaceWeight 0.05; minVolRatio 0.01; minTriangleTwist -1; nSmoothScale 4; errorReduction 0.75; } debug 0; mergeTolerance 1E-6; Quote:
If someone could spot what I am doing wrong it will be greatly appreciated. Thanks for you help, Romain Last edited by nakor; October 14, 2012 at 15:49. |
June 7, 2013, 02:35 |
Jose Rey
Rep Power: 18 |
Hi Nakor,
Did you solve the problem here? Thanks |
[snappyHexMesh] Refinement regions with complex geometry | federicabi | OpenFOAM Meshing & Mesh Conversion | 6 | July 7, 2016 06:03 |
[mesh manipulation] Create patches from a very complex geometry | CoSponge | OpenFOAM Meshing & Mesh Conversion | 4 | October 9, 2015 13:32 |
[mesh manipulation] Create patches from a very complex geometry | CoSponge | OpenFOAM Meshing & Mesh Conversion | 5 | June 9, 2015 09:51 |
[GAMBIT] About creating complex geometry | cdoferreira | ANSYS Meshing & Geometry | 16 | September 17, 2012 03:29 |
How to construct complex 3D geometry using GAMBIT? | Feng | FLUENT | 5 | October 11, 2005 05:13 |
