[mesh manipulation] ExtrudeMesh and autoPatch, need help! |
September 13, 2012, 12:33 |
Rep Power: 15 |
I used extrudeMesh to create a 3d mesh from the inlet patch of another mesh. It worked well, then I used autoPatch 90 to get 6 individuals patches, but the bottom patch is a complex geometry so the angle between it and a given wall is not 90deg (see attached pic). AutoPatch refuses to separate this wall from the bottom patch.
I tried to extract the faces of that wall using faceSet since I know the normal to this wall, but faceSet also gives me faces inside the mesh, and I don't want them. So I have no way to identify the faces of that wall in order to manually modify the boundary file of polyMesh. PLEASE HELP! |
September 13, 2012, 14:46 |
Problem Solved!
Rep Power: 15 |
Problem solved!
I misinterpreted the feature angle used by autoPatch, it's calculated from the outside surface of the mesh! |
July 16, 2019, 02:06 |
autoPatch feature angle explanation
R Adhithya
I want to understand more about how this feature angle is calculated and how changing this affects the number of patches created.
I used the autoPatch for the flange problem (one of the tutorials in snappyHexMesh folder in OpenFOAM tutorials) and I got 5 automatically generated patches but I couldn't open them from paraview. I get the mesh but when i switch to viewing only the patches I get a blank space. Can anyone help me with understanding featureangle in autoPatch tool? |
[snappyHexMesh] 2D Cylinder mesh problems with Snappy | ivan_cozza | OpenFOAM Meshing & Mesh Conversion | 37 | June 4, 2012 16:49 |
Extrudemesh | wikstrom | OpenFOAM Bugs | 2 | December 6, 2009 07:59 |
