[snappyHexMesh] snappyHexMesh with zero Thickness surface imported from a Geometry
Old   September 4, 2012, 12:41
Default snappyHexMesh with zero Thickness surface imported from a Geometry
hfs
hfs is on a distinguished road
Hello!
I have a Geometry of an Umbrella structure (in dwg format) [see the attached photo] and I need to do a wind simulation on it using OpenFOAM
As far as I know, I need to make an STL file.
The problem is that the membrane part of the Umbrella is surfaces (not a solid) so I could not make an STL file out of it.
One approch is to give the membrane a thickness (convert it to solid) I did that. but when asking autoCAD to export it as an STL the membrane is messed up!
My question is: Is there a way to make an STL file including zero Thickness surface?!
or
Is there a way to use snappyHexMesh without doing the STL step? if there is, how to deal with the internal faces in openFoam? Can I deal with them as patches and assign BC to them?
Thanks for your help!
hfs is offline   Reply With Quote
[snappyHexMesh] Problems meshing an impeller with snappyHexMesh kandelabr OpenFOAM Meshing & Mesh Conversion 13 June 9, 2017 07:18
[snappyHexMesh] problem with snappyHexMesh kanes OpenFOAM Meshing & Mesh Conversion 10 January 26, 2016 07:11
SnappyHexMesh... Domain boundaries are uneven Blue8655 OpenFOAM Pre-Processing 0 January 20, 2016 12:43
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 08:05
[snappyHexMesh] SnappyHexMesh AddLayer Control rdrr84 OpenFOAM Meshing & Mesh Conversion 28 May 30, 2014 06:32
