[snappyHexMesh] snappyhexmesh refinement stops when? |
August 24, 2012, 14:18 |
Mihai Pruna
Rep Power: 16 |
Assuming I defined both surface shell based refinement and region - volumetric - refinement.
If the maximum number of cells is reached during surface based refinement, region refinement will not occur anymore, in essence leaving you with a mesh with large cells away from surfaces. Is that so? |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 09:12 |
[snappyHexMesh] SnappyHexMesh running killed! | Mark JIN | OpenFOAM Meshing & Mesh Conversion | 7 | June 14, 2022 01:37 |
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh | Elise | OpenFOAM Meshing & Mesh Conversion | 1 | April 22, 2013 02:32 |
killed "snappyHexMesh" | parkh32 | OpenFOAM Pre-Processing | 2 | April 8, 2012 17:12 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
