[snappyHexMesh] About snappyHexMesh
Like Tree22Likes
Old   July 24, 2023, 05:01
Yann
Yann will become famous soon enoughYann will become famous soon enough
Hi Hossein,
Adding layers in multiregion cases is pretty straightforward in recent OpenCFD branch (openfoam.com), it's a bit trickier in the foundation branch (openfoam.org).
AFAIK, you need to mesh in 2 steps: running snappyHexMesh once without layers, then create baffles and run snappy a 2nd time only for the layers addition phase.
Have a look at the shellAndTubeHeatExchanger tutorial, especially the Allmesh.layers script which, I think, does what you are trying to achieve: https://github.com/OpenFOAM/OpenFOAM...eHeatExchanger
Hope this helps,
Yann
AtoHM and H_SheikhShoaie like this.
Yann is offline   Reply With Quote
Old   August 10, 2023, 04:22
Hossein Sheikhshoaie
H_SheikhShoaie is on a distinguished road
Hey Yann,
I really appreciate your guidance. Well I completely redefined my case, I have tried different methods , different stl files (created by salome and solidworks with various meshes).
Now there is a little problem, a few number (very low in compare to the whole number) of faces on an interface are named different from created interface's name (they get the name of their stl file and has been shown in attached picture), however there are in the correct region means there is no extra regions.
In my opinion this can be addressed can by defining BCs as same as interface for these faces. I had an unsuccessful effort to solve this problem by adjusting snappyHexMesh parameters but this arises from stl files (I've already changed all snappy's parameters). In addition It doesn't show a linear behavior by increasing or decreasing the resolution of slt's mesh. Unfortunately, it is weakly related to some mesh parameters too.
The snappyHexMesh containment has been brought below. In addition the faces has been illustrated in attached picture. surprisingly There is no problem with the more complex pipe which has five 180 degree bends.
I'm pressed for time to finish this project, I was wondering if you let me know how this faces can interfere the mesh quality and numerical solution. Because, My geometries will becoming more complicated. In addition, I will be grateful if I can have your Email address.
Regards,
Hossein
| \\ / O peration | Version: v1912 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
FoamFile
version 2;
format ascii;
class dictionary;
object snappyHexMeshDict;
castellatedMesh off;
snap off;
addLayers on;
geometry
burner
type triSurfaceMesh;
file "burner.stl";
regions
burnerinlet
name burnerinlet;
burneroutlet
name burneroutlet;
burnerwall
name burnerwall;
gas
file "gas.stl";
regions
gasinlet
name gasinlet;
gasoutlet
name gasoutlet;
gaswall
name gaswall;
shell
file "shell.stl";
regions
shellwall
name shellwall;
castellatedMeshControls
maxLocalCells 100000;
maxGlobalCells 100000000;
minRefinementCells 10;
maxLoadUnbalance 0.1;
nCellsBetweenLevels 1;
resolveFeatureAngle 15;
allowFreeStandingZoneFaces true;
features ( { file "shell.eMesh" ; level 2 ; } );
refinementSurfaces
burner
level ( 1 1 );
regions
burnerinlet
level ( 1 1 );
patchInfo
type patch;
burneroutlet
level ( 1 1 );
patchInfo
type patch;
burnerwall
level ( 1 1 );
patchInfo
type wall;
gas
level ( 1 1 );
regions
gasinlet
level ( 1 1 );
patchInfo
type patch;
gasoutlet
level ( 1 1 );
patchInfo
type patch;
gaswall
level ( 1 1 );
patchInfo
type wall;
shell
level ( 0 0 );
regions
shellwall
level ( 0 0 );
patchInfo
type wall;
refinementRegions
locationsInMesh ( ( ( 1 0.008 0.015 ) region1 ) ( ( 2.5 0.23 0.3 ) cellZone2 ) ( ( 1 -0.369 0.2 ) cellZone1 ) );
snapControls
nSmoothPatch 3;
tolerance 2;
nSolveIter 100;
nRelaxIter 5;
nFeatureSnapIter 10;
explicitFeatureSnap false;
multiRegionFeatureSnap false;
implicitFeatureSnap true;
addLayersControls
featureAngle 100;
slipFeatureAngle 30;
nLayerIter 50;
nRelaxedIter 20;
nRelaxIter 5;
nGrow 0;
nSmoothSurfaceNormals 1;
nSmoothNormals 3;
nSmoothThickness 10;
maxFaceThicknessRatio 0.5;
maxThicknessToMedialRatio 0.3;
minMedialAxisAngle 90;
nMedialAxisIter 10;
nBufferCellsNoExtrude 0;
additionalReporting false;
layers
relativeSizes true;
expansionRatio 1.2;
finalLayerThickness 0.5;
minThickness 0.2;
meshQualityControls
maxNonOrtho 65;
maxBoundarySkewness 20;
maxInternalSkewness 4;
maxConcave 80;
minVol 1e-13;
minTetQuality -1;
minArea -1;
minTwist 0.02;
minDeterminant 0.001;
minFaceWeight 0.05;
minVolRatio 0.01;
minTriangleTwist -1;
nSmoothScale 4;
errorReduction 0.75;
relaxed
debug 0;
mergeTolerance 1e-06;
File Type: jpg Screenshot from 2023-08-10 10-20-40.jpg (159.5 KB, 33 views)
H_SheikhShoaie is offline   Reply With Quote
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 07:01
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing peterhess OpenFOAM Meshing & Mesh Conversion 2 January 3, 2018 03:54
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. jasv OpenFOAM Meshing & Mesh Conversion 4 May 10, 2016 03:55
[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? klausb OpenFOAM Meshing & Mesh Conversion 1 March 7, 2015 12:55
[snappyHexMesh] stitchMesh and snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 03:09
