[snappyHexMesh] About snappyHexMesh
Like Tree22Likes
Old   November 28, 2022, 08:23
Yann
Yann will become famous soon enoughYann will become famous soon enough
In snappyHexMeshDict, you need to define the porous cylinder as a cellZone in the refinementSurfaces section:
refinementSurfaces
    yourCylinder
        level (0 0);
        faceZone cylinderFaces;
        cellZone cylinderVolume;
        cellZoneInside inside;
Regards,
Yann
Yann is offline   Reply With Quote
Old   November 28, 2022, 10:46
Rohit
Rohitsingh is on a distinguished road
Send a message via Skype™ to Rohitsingh
Originally Posted by Yann View Post
refinementSurfaces
    yourCylinder
        level (0 0);
Regards,
Yann
Dear Yann,
For your reference i am attaching my case set up. It would be great if you can tell me my mistake.
I have tried the approach suggested by you.
Regards
https://drive.google.com/drive/folde...usp=share_link
Rohitsingh is offline   Reply With Quote
Old   November 28, 2022, 11:39
Yann
You should have a stl file defined in geometry. I'm going to assume you stl file is named "poroussphere.stl":
geometry
    poroussphere.stl
        type triSurfaceMesh;
        name Interface;
    refinementBox
        type searchableBox;
        min (-4 -4 -4);
        max (4 4 4);
In geometry, you defined the name of the poroussphere.stl as "Interface", then you need to use this name is the following sections of snappyHexMeshDict:
Interface
	level (0 0);
	faceZone anyNameYouWant;
	cellZone anyOtherNameYouWant;
I hope this helps,
Yann
PS: as your question is pretty specific, you might want to create a dedicated thread to discuss it.
AtoHM and 865618910 like this.
Old   January 16, 2023, 06:42
Exclamation Problem with extrudeMesh
  #24
Giuseppe Dalla Vecchia
giuseppedalla is on a distinguished road
Hi, I'm new on this forum. I have to do an university exams and i have a problem with the function extrudeMesh. When I compile I have a FATALERROR:
Create time
--> FOAM Warning :
From virtual Foam::Istream &Foam::ISstream::read(Foam::word &)
in file db/IOstreams/Sstreams/ISstream.C at line 886
Reading "system/controlDict" at line 51
Missing 1 closing ')' while parsing
residuals(p,
--> FOAM Warning :
From static bool Foam::functionObjectList::readFunctionObject(const Foam::string &, Foam::dictionary &, HashSet<Foam::wordRe> &, const Foam::word &)
in file db/functionObjects/functionObjectList/functionObjectList.C at line 288
Cannot find functionObject file residuals
--> FOAM Warning :
Too many closing ')' ... was a ';' forgotten?
--> FOAM FATAL IO ERROR: (openfoam-2212)
Unexpected '}' while reading dictionary entry
file: system/controlDict at line 64.
From static bool Foam::entry::New(Foam::dictionary &, Foam::Istream &, const entry::inputMode, const int)
in file db/dictionary/entry/entryIO.C at line 156.
FOAM exiting
someone can help me?
Thanks
giuseppedalla is offline   Reply With Quote
Old   January 16, 2023, 07:12
Yann
There are likely typos in your controlDict:
Create time
--> FOAM Warning :
residuals(p,
--> FOAM Warning :
--> FOAM Warning :
Look for missing brackets in your controlDict file, and post it here if you cannot find the error.
Regards,
Yann
giuseppedalla likes this.
Old   January 16, 2023, 07:18
Yann, thanks for your help.
I needed to add a Func for WallShearStress so now i put that for controlDict:
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application simpleFoam;
startFrom latestTime;
startTime 0;
stopAt endTime;
endTime 3000;
deltaT 1;
writeControl runTime;
writeInterval 3000;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
functions
#includeFunc residuals(p, U, k, omega)
#includeFunc "wallShearStress"
forces
type forces;
libs ("libforces.so");
writeControl timeStep;
writeInterval 1;
log yes;
patches (wing);
rho rhoInf;
rhoInf 1;
CofR (0.4974612746 -0.01671895744 0.125);
and the error now is:
Create time
--> FOAM Warning :
residuals(p,
--> FOAM Warning :
--> FOAM Warning :
--> FOAM FATAL ERROR: (openfoam-2212)
Unknown functionEntry 'includeFunc' in "system/controlDict" near line 53
Valid functionEntries :
10(calc codeStream eval include includeEtc includeIfPresent message sinclude sincludeEtc word)
From static bool Foam::functionEntry::execute(const Foam::word &, const Foam::dictionary &, Foam:rimitiveEntry &, Foam::Istream &)
in file db/dictionary/functionEntries/functionEntry/functionEntry.C at line 161.
FOAM exiting
Maybe I have to tell you that last week this program worked with Openfoam v10 ... now I have Openfoam v2212 ... maybe it could be usefull for you.
Regards,
Giuseppe
Old   January 16, 2023, 07:44
Yann
This line seems to be wrong:
Which OpenFOAM version are you using?
Old   January 16, 2023, 07:45
| \\ / O peration | Version: v1812 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
Old   January 16, 2023, 07:48
I chance this line with
#includeFunc residuals(p,U,k,omega)
and seems this one error is resolve but still this
Create time
--> FOAM Warning :
file: system/controlDict at line 67.
FOAM exiting
and i check every } missing ...
Old   January 16, 2023, 07:50
It's strange because when i run one line like "extrudeMesh" i see that:
| \\ / O peration | Version: 2212 |
| \\ / A nd | Website: www.openfoam.com |
So v2212, but when i open controlDict it's:
v1812 .... it could be this the error?
Old   January 16, 2023, 09:19
Yann
OK so first thing: you are using openFoam-v2212, as you can see here:
FOAM exiting
You can also see it in the terminal when running any command, or with this command: foamVersion
The files header not being up to date don't matter, but you might face issues if you try to run cases from an older version to a new one due to syntax or functionalities changes between versions.
This being said, the residuals function object has been replaced by solverInfo since v1906 so you should replace this:
with this
#includeFunc solverInfo
And it should be fine, at least for this error.
Regards,
Yann
Old   January 16, 2023, 10:03
Yann, you're a lifesaver.
So the problem was this line #includeFunc residuals(p, U, k, omega) that change with the new version of Openfoam.
I changed with the new line and now it work all well and print me all the dates that i need.
Thank you so much for the help.
Regards,
Giuseppe
Yann likes this.
Old   May 18, 2023, 04:23
Alexandros
AlexandrosVouros is on a distinguished road
Dear All,
Could you please provide some advice on better snapping the interface in the picture below!
It comes from a temperature probe that I need to put within the fluid pipe flow. All the procedure described by Tobi for a watertight etc. outline geometry has been followed -although meshing at the interface nodes is indeed compatible - it seems not so uniform enough I admit (please check salome file).
In the final output a small number of cells are included in opposite zones, e.g fluid/probeWall or probe/fluidWall.
I saw that in other versions (I am finally using OF 9 now in Ubunti 22.04 lts under wsl win 11) there are several tricks like "stealing" the problematic cells from one zone to another -so that boundary files are consistent with the supposed geometry the physical problem but I would be very happy to avoid it and have a better cell treatment.
My questions are summarized below:
1) How stiff should be a mesh produced by salome in order to avoid "bad or scratched" cells at the interface? Is it adequate that nodes "communicate" or the mesh just behind the interface play a role also?
2) How exactly the combination of the settings work in snappy?
(I have gone through Tobi's excellent video series with smoking pipe but I am still confused; perhaps this is my problem, but still some simple rules and guidelines would be very helpful
3) Does this problem has a solution or I am hitting my head to the wall?
Case files can be downloaded from here:
https://drive.google.com/file/d/1-DA...usp=share_link
I think the next step is the edge refinement example (available in Holzmann CFD page). But is there an accompanying pdf for this one? I still cannot undestand how that line was constructed (it does not appear but only in paraview in my case) and also, what is the logic behind this moderate number of steps before exporting the stl files. Finally, does someone needs the blender file as well in order to check how the refinement edge is produced?)
Thank you for your time and your awesome work!
Alex
AlexandrosVouros is offline   Reply With Quote
Old   May 18, 2023, 09:53
Alexandros
Before any response, I would like to post a link to another excellent video for mesh refinement.
https://holzmann-cfd.com/community/t...haust-manifold
Maybe I should look better before bothering you...
All the best !
Old   July 12, 2023, 05:39
Default Adding layers to interior stls of multiregion meshes in snappyHexMesh
  #35
Hossein Sheikhshoaie
H_SheikhShoaie is on a distinguished road
Dear Foamers,
I'm currently struggling with snappyHexMesh and creating layers on the interior boundary layers of a multiregion mesh, I need to set 30 < y+ < 300. I've tried adjusting various parameters, but so far, I haven't been successful. I was wondering if you could offer any suggestions.
The snappyHexMeshDict is observable below:
FoamFile
version 2;
format ascii;
class dictionary;
object snappyHexMeshDict;
castellatedMesh on;
snap on;
addLayers on;
geometry
"burnerinlet.stl"
name burnerinlet;
"burneroutlet.stl"
name burneroutlet;
"surfaceburner.stl"
name surfaceburner;
"surfacegas.stl"
name surfacegas;
"gasinlet.stl"
name gasinlet;
"gasoutlet.stl"
name gasoutlet;
castellatedMeshControls
maxLocalCells 100000;
maxGlobalCells 100000000;
minRefinementCells 10;
maxLoadUnbalance 0.1;
nCellsBetweenLevels 2;
resolveFeatureAngle 15;
allowFreeStandingZoneFaces true;
features ( );
refinementSurfaces
surfaceburner
level ( 1 1 );
faceZone faceZone1;
cellZone cellZone1;
boundary internal;
surfacegas
level ( 1 1 );
faceZone faceZone2;
cellZone cellZone2;
boundary internal;
burnerinlet
level ( 1 1 );
patchInfo
type patch;
burneroutlet
level ( 1 1 );
patchInfo
type patch;
gasinlet
level ( 1 1 );
patchInfo
type patch;
gasoutlet
level ( 1 1 );
patchInfo
type patch;
refinementRegions
locationInMesh ( 1 0.008 0.015 );
snapControls
nSmoothPatch 3;
tolerance 2;
nSolveIter 100;
nRelaxIter 5;
nFeatureSnapIter 10;
explicitFeatureSnap false;
multiRegionFeatureSnap false;
implicitFeatureSnap true;
addLayersControls
featureAngle 100;
slipFeatureAngle 30;
nLayerIter 50;
nRelaxedIter 20;
nRelaxIter 5;
nGrow 0;
nSmoothSurfaceNormals 1;
nSmoothNormals 3;
nSmoothThickness 10;
maxFaceThicknessRatio 0.5;
maxThicknessToMedialRatio 0.3;
minMedialAxisAngle 90;
nMedialAxisIter 10;
nBufferCellsNoExtrude 0;
additionalReporting false;
layers
gasinlet
nSurfaceLayers 3;
mergeFaces true;
gasoutlet
nSurfaceLayers 3;
mergeFaces true;
surfaceburner
nSurfaceLayers 3;
mergeFaces true;
surfacegas
nSurfaceLayers 3;
mergeFaces true;
burnerinlet
nSurfaceLayers 3;
mergeFaces true;
burneroutlet
nSurfaceLayers 3;
mergeFaces true;
relativeSizes true;
expansionRatio 1.2;
finalLayerThickness 0.5;
minThickness 0.001;
meshQualityControls
maxNonOrtho 65;
maxBoundarySkewness 20;
maxInternalSkewness 4;
maxConcave 80;
minVol 1e-13;
minTetQuality -1;
minArea -1;
minTwist 0.02;
minDeterminant 0.001;
minFaceWeight 0.05;
minVolRatio 0.01;
minTriangleTwist -1;
nSmoothScale 4;
errorReduction 0.75;
relaxed
debug 0;
mergeTolerance 1e-06;
Also, I have attached a screenshot from Paraview.
Thank you in advance, and please let me know if you need any additional information.
File Type: jpg Screenshot from 2023-07-12 11-56-58.jpg (120.9 KB, 18 views)
H_SheikhShoaie is offline   Reply With Quote
Old   July 14, 2023, 05:45
Alexandros
I think that there is an openfoam tutorial withinh the folder tutorials snappy for meshing a pipe. You could start with that.
In addition, there is a (more complicated) pipe meshing tutorial in Tobias Holzmann page.
Old   July 15, 2023, 06:05
Thank you dear Alexander;
I've already checked samples. In my opinion this case is different because I can add layers to shell's wall. However, It's impossible to add layer to the interior walls of inner regions.
I think the picture was not as clear as enough. So I would like to explain the case further. It involves a shell that surrounds two pipe lines, one in a serpentine shape and the other in a U shape. The mesh used for the simulation is three-dimensional and consists of at least one million cells.
I have attached a picture of enclosed regions.
I would be grateful for any guidance you can provide.
File Type: jpg Screenshot from 2023-07-15 12-33-41.jpg (100.1 KB, 19 views)
File Type: jpg Screenshot from 2023-07-15 12-33-33.jpg (101.4 KB, 14 views)
Old   July 22, 2023, 20:04
Dear Formers,
Finding a way to add a boundary layer mesh to the interior STLs mentioned above is crucial to me. Please let me know if it is impossible to create such parts with snappyHexMesh. I would appreciate it if someone could introduce a better solution, even if it involves using other meshing tools.
Thank you in advance.
Old   July 23, 2023, 06:24
Yann
The answer depends on the OpenFOAM version you are using.
(if you are not sure, you can type the foamVersion command in a terminal)
Regards,
Yann
Old   July 23, 2023, 18:33
Dear Yann, I'm grateful for your prompt response. The mesh has been generated through OpenFOAM 7.
I appreciate your help. Thank you again.
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 07:01
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing peterhess OpenFOAM Meshing & Mesh Conversion 2 January 3, 2018 03:54
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. jasv OpenFOAM Meshing & Mesh Conversion 4 May 10, 2016 03:55
[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? klausb OpenFOAM Meshing & Mesh Conversion 1 March 7, 2015 12:55
[snappyHexMesh] stitchMesh and snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 03:09
