June 26, 2012, 05:22 |
ideasUnvToFoam with inner parts
Rep Power: 14 |
Hello All,
I have got a problem with my mesh and I hope, that you can help me. 1. I created a simple mesh with "Salome" and "Netgen 1D-2D-3D". 2. I exported it as *.unv (mesh_forum.unv.gz) 3. I tried to convert it with ideasUnvToFoam, but it fails (see the log-file) Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.0-0bc225064152 Exec : ideasUnvToFoam mesh_long_0626_0845.unv Date : Jun 26 2012 Time : 08:47:10 Host : "Hans" PID : 9674 Case : /home/paul/OpenFOAM/paul-2.1.0/run/mycases/fermenter_v18_forum nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Processing tag:2411 Starting reading points at line 3. Read 1996 points. Processing tag:2412 Starting reading cells at line 3998. First occurrence of element type 11 for cell 1 at line 3999 First occurrence of element type 41 for cell 213 at line 4635 First occurrence of element type 111 for cell 2502 at line 9213 Read 10226 cells and 2289 boundary faces. Processing tag:2467 Starting reading patches at line 29667. For group 3 named defaultFaces trying to read 241 patch face indices. For group 4 named wall trying to read 661 patch face indices. For group 5 named outerSlider trying to read 545 patch face indices. For group 6 named innerSlider trying to read 545 patch face indices. For group 7 named stirrer trying to read 842 patch face indices. Of 2289 so-called boundary faces 1387 belong to two cells and are therefore internal Sorting boundary faces according to group (patch) 0: defaultFaces is patch 1: wall is patch 2: outerSlider is faceZone 3: innerSlider is faceZone 4: stirrer is faceZone Constructing mesh with non-default patches of size: defaultFaces 241 wall 661 Adding cell and face zones Face Zone innerSlider 545 ideasUnvToFoam: ideasUnvToFoam.C:1269: int main(int, char**): Assertion `noveau > -1' failed. Thanks a lot! Picture: at the outside there is the "wall", the cylinder shuld be "innerSlider" and "outerSlider" and the block shuld be the "stirrer" Edit: I forgot to add the picture Last edited by anton_lias; June 26, 2012 at 09:35. Reason: add a picture |
July 3, 2012, 08:35 |
Rep Power: 14 |
Solved. If anybody has the same error:
To put all the geometries in one mesh, I used the operation "partition" instead of "cut". That was the mistake. |
November 2, 2012, 07:36 |
#3 | |
Rep Power: 15 |
Hi Anton / all I ran into a similar problem with internal faces. My example uses a cylinder with an internal face created with Salome 6.5 to calculate a heat transfer problem. The mesh was created after partition operation and groups created for all walls, the interface and the interior. Here is my geometry: http://www.file-upload.net/download-...forum.hdf.html Conversion with ideasUnvToFoam throws an error with internal faces: ... Create timeProcessing tag:164 Starting reading units at line 3. l:1 units:" SI: Meter (newton)" unitType:2 Unit factors: Length scale : 1 Force scale : 1 Temperature scale : 1 Temperature offset : 273.15 Processing tag:2420 Skipping tag 2420 on line 9 Skipping section at line 9. Processing tag:2411 Starting reading points at line 20. Read 527 points. Processing tag:2412 Starting reading cells at line 1077. First occurrence of element type 11 for cell 1 at line 1078 First occurrence of element type 41 for cell 57 at line 1246 First occurrence of element type 111 for cell 853 at line 2838 Read 1860 cells and 796 boundary faces. Processing tag:2467 Starting reading patches at line 6560. For group 1 named wall_lower trying to read 296 patch face indices. For group 2 named wall_upper trying to read 296 patch face indices. For group 3 named top trying to read 68 patch face indices. For group 4 named bottom trying to read 68 patch face indices. For group 5 named interior trying to read 1860 patch face indices. For group 6 named intersection trying to read 68 patch face indices. Of 796 so-called boundary faces 68 belong to two cells and are therefore internal Sorting boundary faces according to group (patch) 0: wall_lower is patch 1: wall_upper is patch 2: top is patch 3: bottom is patch 4: interior is cellZone 5: intersection is faceZone Constructing mesh with non-default patches of size: wall_lower 296 wall_upper 296 top 68 bottom 68 Adding cell and face zones Cell Zone interior 1860 Face Zone intersection 68 ideasUnvToFoam: ideasUnvToFoam.C:1269: int main(int, char**): Assertion `noveau > -1' failed. Aborted Could you update/renew/provide your attached mesh_forum.unv, which worked finally for you? The link to your mesh has expired, and I would like to identify where I am wrong in my procedure. Any help is appreciated, thanks! dirk |
November 5, 2012, 07:44 |
Rep Power: 14 |
1. You can download it at http://www.file-upload.net/download-...um.unv.gz.html
2. try NOT to use the operation "partition". I would make two cylinders and use the operation "fuse" to combine them. |
November 5, 2012, 12:19 |
#5 | |
Rep Power: 15 |
Thanks anton! I tried your mesh, but got the same error. maybe a bug in ideasUnvToFoam of this version?
My output: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.0-0bc225064152 Exec : ideasUnvToFoam mesh_forum.unv Date : Nov 05 2012 Time : 16:46:51 Host : "simulation-HP" PID : 20950 Case : /home/dirk/OpenFOAM/dirk-2.1.0/run/cht/planeWall2DSalome2 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Processing tag:2411 Starting reading points at line 3. Read 1996 points. Processing tag:2412 Starting reading cells at line 3998. First occurrence of element type 11 for cell 1 at line 3999 First occurrence of element type 41 for cell 213 at line 4635 First occurrence of element type 111 for cell 2502 at line 9213 Read 10226 cells and 2289 boundary faces. Processing tag:2467 Starting reading patches at line 29667. For group 3 named defaultFaces trying to read 241 patch face indices. For group 4 named wall trying to read 661 patch face indices. For group 5 named outerSlider trying to read 545 patch face indices. For group 6 named innerSlider trying to read 545 patch face indices. For group 7 named stirrer trying to read 842 patch face indices. Of 2289 so-called boundary faces 1387 belong to two cells and are therefore internal Sorting boundary faces according to group (patch) 0: defaultFaces is patch 1: wall is patch 2: outerSlider is faceZone 3: innerSlider is faceZone 4: stirrer is faceZone Constructing mesh with non-default patches of size: defaultFaces 241 wall 661 Adding cell and face zones Face Zone innerSlider 545 ideasUnvToFoam: ideasUnvToFoam.C:1269: int main(int, char**): Assertion `noveau > -1' failed. Aborted I also tried to fuse two boxes instead of partitioning. After fusion also the interface has fused away and I cannot create a group in the meshing module from that face. Maybe somebody could provide a working a salome script (py) with an inner wall to start before generation of the unv. file. I also posted the same problem (2 cylinder) to a german forum: http://ww3.cad.de/foren/ubb/Forum527/HTML/000308.shtml Thanks all your for help! dirk Quote:
November 6, 2012, 07:03 |
Rep Power: 14 |
I am sorry, I gave you the old file. http://www.file-upload.net/download-...20702.unv.html <-- this should work.
If your geometry is only this pipe, you can use blockmesh. Or you could try to make two meshes and combine them with "mergeMeshes". |
November 9, 2012, 03:28 |
Laurent B
Rep Power: 17 |
Hi all,
I encounter the same problem with openfoam version 2.1.1 : ideasUnvToFoam: ideasUnvToFoam.C:1269: int main(int, char**): Assertion `noveau > -1' failed. But if i switch to the 2.0.1 version the ideasUnvToFoam utility works fine. Does anybody can explain this ? |
November 9, 2012, 04:24 |
#8 | |
Rep Power: 15 |
hi laurent,
maybe this helps, (expanding a line in the unv file about one column, although it is more salome related) http://www.openfoam.org/mantisbt/view.php?id=584 http://openfoamwiki.net/index.php/IdeasUnvToFoam good luck dirk Quote:
November 26, 2012, 20:58 |
#9 |
Darren
Rep Power: 14 |
No I cant explain it but more than that I cant replicate it.
I have a mesh with internal parts that fails conversion to openfoam from an ideasUnv format created with Salome that refuses to convert with the same error message :- ideasUnvToFoam: ideasUnvToFoam.C:1269: int main(int, char**): Assertion `noveau > -1' failed. This is driving me insane at 1.00am in the morning does anyone know the problem ? |
December 16, 2012, 12:27 |
#10 |
Joe Foster
Rep Power: 14 |
I am new to both Salome and OpenFOAM and I seem to have run into the same problem with ideasUnvToFoam. I am trying to simulate a simple model consisting of a box with a short inlet pipe at the bottom and short outlet pipe at the top. I created a face with a small hole in the center to act as an orifice in the middle of the box with hopes of learning to explore how flow is affected by different baffle designs. I used the Partition tool in Salome along with the face to create geometry that would allow me to include this "baffle" as a group in my mesh. After exporting to .unv and using ideasUnvToFoam I get the following output:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.1-221db2718bbb Exec : ideasUnvToFoam baffle.unv Date : Dec 16 2012 Time : 10:55:36 Host : "" PID : 30004 Case : /state/partition1/home/jfoster533/run/baffle nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Processing tag:164 Starting reading units at line 3. l:1 units:" SI: Meter (newton)" unitType:2 Unit factors: Length scale : 1 Force scale : 1 Temperature scale : 1 Temperature offset : 273.15 Processing tag:2420 Skipping tag 2420 on line 9 Skipping section at line 9. Processing tag:2411 Starting reading points at line 20. Read 15447 points. Processing tag:2412 Starting reading cells at line 30917. First occurrence of element type 11 for cell 1 at line 30918 First occurrence of element type 41 for cell 452 at line 32271 First occurrence of element type 111 for cell 15877 at line 63121 Read 69975 cells and 15425 boundary faces. Processing tag:2467 Starting reading patches at line 203073. For group 1 named baffle trying to read 1833 patch face indices. For group 2 named inlet trying to read 68 patch face indices. For group 3 named outlet trying to read 68 patch face indices. For group 4 named wall trying to read 13456 patch face indices. Of 15425 so-called boundary faces 1833 belong to two cells and are therefore internal Sorting boundary faces according to group (patch) 0: baffle is faceZone 1: inlet is patch 2: outlet is patch 3: wall is patch Constructing mesh with non-default patches of size: inlet 68 outlet 68 wall 13456 Adding cell and face zones Face Zone baffle 1833 ideasUnvToFoam: ideasUnvToFoam.C:1269: int main(int, char**): Assertion `noveau > -1' failed. Aborted I would greatly appreciate any advice as to how to work around this problem. I have also tried to seperate the model into two solids: one above the baffle and one below and build a compound solid from the two. I was able to export this to .unv as well with the very same failure as listed above. |
December 17, 2012, 06:00 |
#11 |
Rep Power: 14 |
December 24, 2012, 08:11 |
#12 |
Laurence R. McGlashan
Rep Power: 23 |
Apply this patch to ideasUnvToFoam.C
You should be able to view the baffle as a faceZone in paraview. You can then use createBaffles to make the baffle patch. There may be other issues though to do with internal faces, I'll have to think about it.
Laurence R. McGlashan :: Website |
December 29, 2012, 13:07 |
#13 |
Joe Foster
Rep Power: 14 |
Laurence,
Your patch did the trick. I was able to successfully produce the internal zero thickness walls that I was after. Thanks for you help! |
February 12, 2013, 19:11 |
#14 | |
Andrea Pisa
Rep Power: 13 |
the internal face is the error |
February 19, 2013, 22:27 |
#15 |
Joe Foster
Rep Power: 14 |
I am new at this as well, but I will try to help you. Copy the ideasUnvToFoam.patch file to the folder containing ideasUnvToFoam.C. In a terminal, enter the command 'patch ideasUnvToFoam.C ideasUnvToFoam.patch. The code will be patched and you can recompile the application. Worked for me anyway.
March 13, 2013, 16:15 |
#16 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
As Lenin said: "Patching is good. Reporting is better". Have you ever reported this patch as a bug at http://www.openfoam.org/bugs/ ? I'm asking because the error which it fixes still occurs in 2.2.x Please do so the next time. If not for everyone else then for your convenience: that way you won't have to patch your own installation once a new OF-version comes out Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
March 14, 2013, 06:01 |
#17 |
Rep Power: 23 |
I didn't add it before because I hadn't tested it and the code was hard to follow, but seeing as nobody has complained about the patch so far it has now been added to the repository.
June 12, 2013, 06:02 |
ideasUnvToFoam
#18 | |
Rep Power: 13 |
Hello JFoster, i would like to know: How to recompile the appication, i have alredy copied the ideasUnvToFoam into the directory containing ideasUnvToFoam.C The step with/in the terminal is also alredy done, but it does not change anything, i do not know how to "recompile" What is the next step afterthe step in the erminal? To find the Folder, i just searched from the root after ideasUnvToFoam and find the folder under: /opt/openfoam211/applications/utilities/mesh/conversion/ideasUnvToFoam Thank you very much for your patch and for any help Leden... |
June 13, 2013, 03:08 |
#19 |
Laurent B
Rep Power: 17 |
>cd /opt/openfoam211/applications/utilities/mesh/conversion/ideasUnvToFoam
>sudo su #source /opt/openfoam211/etc/bashrc #patch ideasUnvToFoam.c ideasUnvToFoam.patch #wmake Last edited by laurentb; June 24, 2013 at 06:39. |
October 5, 2013, 01:23 |
#20 |
Rep Power: 13 |
Thanks for the answers, I am having the same error.
I want to try and apply the patch but I don't have the privileges to access /opt.. I'm fairly new to linux and am trying to work out how to access that folder to apply the patch as described by the above post. Any help much appreciated Edit. Managed to apply the patch but still getting the error. Any ideas? Last edited by Matt_h; October 6, 2013 at 20:54. |
[Salome] ideasUnvToFoam Error: Assertion `nouveau > -1' failed | GerhardHolzinger | OpenFOAM Meshing & Mesh Conversion | 1 | November 7, 2024 07:49 |
Generate Parts Using Named Selection | jonasohlsson | ANSYS | 1 | March 14, 2016 05:32 |
[Salome] ideasUnvToFoam problem with internal groups | s.marcocalero | OpenFOAM Meshing & Mesh Conversion | 0 | May 31, 2013 12:48 |
[Salome] ideasUnvToFoam | Dazzler | OpenFOAM Meshing & Mesh Conversion | 0 | November 27, 2012 04:14 |
Creating 100 derived parts / Splitting derived parts for mass flux calculation | xamo | STAR-CCM+ | 8 | September 29, 2009 06:35 |
