[snappyHexMesh] SnappyHexMesh Internal Flow Example (Diesel Injector) |
July 7, 2013, 06:25 |
#21 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Danny,
Without an example STL file, there isn't much I can suggest You can try using OpenFOAM's commands surfaceCheck and surfaceClean. The other possibility is to use either Blender or Meshlab for repairing the STL file. Best regards, Bruno
July 8, 2013, 09:00 |
stl file example
#22 |
here is an example stl file
Danny |
July 13, 2013, 16:50 |
#23 |
Bruno Santos
Rep Power: 128 |
Hi Danny,
I renamed the file to "test.stl" (OpenFOAM dislikes spaces and special characters) and ran: Code:
surfaceCheck test.stl And there seems to be problems with connections between triangles, since this is indicated: Code:
Surface is not closed since not all edges connected to two faces: connected to one face : 12 connected to >2 faces : 0 Conflicting face labels:12 If I'm not mistaken, the best procedure is to export to Step or IGES format and then use Salome to convert the surface mesh to STL. This is because SolidWorks is doing a very lousy job on converting this to STL. The other possibility is to export the geometry to STL in binary form, so that you do not loose numerical precision. I say this because, for example from your file: Code:
vertex 3.125293e+000 3.067232e+000 8.410000e+000 Best regards, Bruno
July 15, 2013, 08:45 |
#24 |
Thank you Bruno for your help! that makes sense with the troubles I was having! I appreciate your help!
Danny |
snappyhexmesh, surfacefeatureextraction |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 06:36 |
Difference between External and Internal flow radiation problems | Kummi | FLUENT | 0 | April 10, 2018 04:06 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
[snappyHexMesh] snappyHexMesh and blockMesh for internal flow (leaking geometry?) | vaina74 | OpenFOAM Meshing & Mesh Conversion | 10 | November 20, 2014 10:14 |
Internal flow simulation BCs | SteveGoat | FLUENT | 0 | May 10, 2012 07:41 |
