June 17, 2012, 18:16 |
Problem with 0012 simple case
Rep Power: 14 |
I'm teaching myself to use OpenFOAM, but I'm having a little trouble with getting started. Specifically, in this case, I'm trying to use a NACA 0012 airfoil at 0 degrees alpha, with icoFOAM. I've gotten it to mesh and run, but the results I'm getting suggest that the problem is with my mesh. I'm going to include the important parts of all the files in case that's not the problem.
Basically, what I think has happened is that I've made the inside of the airfoil a separate block, but for the outside it's as if it didn't exist. I don't know, really. I've attached the image I see in paraFoam at t=0.2s. The images are the x, y, and z components of velocity. The y and z components are both very very small, like 1.0e-11 or less. If anyone could point me to what I'm doing wrong, I'd be thankful. First, my blockMeshDict: Code:
convertToMeters 1; vertices ( (-3 -3 -1) (3 -3 -1) (3 3 -1) (-3 3 -1) (-3 -3 1) (3 -3 1) (3 3 1) (-3 3 1) (0.00273905 0.00911102 -1) (0.00273905 0.00911102 1) (0.00273905 -0.00911102 -1) (0.00273905 -0.00911102 1) (1.00000000 0.00000000 -1) (1.00000000 0.00000000 1) ); blocks ( hex (0 1 2 3 4 5 6 7) (500 500 1) simpleGrading (1 1 1) hex (8 10 12 12 9 11 13 13) (10 10 1) simpleGrading (1 1 1) ); edges ( arc 8 10 (0 0 -1) arc 9 11 (0 0 1) spline 12 8 ((0.99726095 0.00038712 -1) (0.98907380 0.00153653 -1) (0.97552826 0.00341331 -1) (0.95677273 0.00596209 -1) (0.93301270 0.00911073 -1) (0.90450850 0.01277464 -1) (0.87157241 0.01686084 -1) (0.83456530 0.02127128 -1) (0.79389263 0.02590486 -1) (0.75000000 0.03065806 -1) (0.70336832 0.03542434 -1) (0.65450850 0.04009273 -1) (0.60395585 0.04454642 -1) (0.55226423 0.04866201 -1) (0.50000000 0.05231025 -1) (0.44773577 0.05535862 -1) (0.39604415 0.05767604 -1) (0.34549150 0.05913940 -1) (0.29663168 0.05964120 -1) (0.25000000 0.05909742 -1) (0.20610737 0.05745444 -1) (0.16543470 0.05469379 -1) (0.12842759 0.05083398 -1) (0.09549150 0.04592861 -1) (0.06698730 0.04006079 -1) (0.04322727 0.03333431 -1) (0.02447174 0.02586248 -1) (0.01092620 0.01775595 -1)) spline 13 9 ((0.99726095 0.00038712 1) (0.98907380 0.00153653 1) (0.97552826 0.00341331 1) (0.95677273 0.00596209 1) (0.93301270 0.00911073 1) (0.90450850 0.01277464 1) (0.87157241 0.01686084 1) (0.83456530 0.02127128 1) (0.79389263 0.02590486 1) (0.75000000 0.03065806 1) (0.70336832 0.03542434 1) (0.65450850 0.04009273 1) (0.60395585 0.04454642 1) (0.55226423 0.04866201 1) (0.50000000 0.05231025 1) (0.44773577 0.05535862 1) (0.39604415 0.05767604 1) (0.34549150 0.05913940 1) (0.29663168 0.05964120 1) (0.25000000 0.05909742 1) (0.20610737 0.05745444 1) (0.16543470 0.05469379 1) (0.12842759 0.05083398 1) (0.09549150 0.04592861 1) (0.06698730 0.04006079 1) (0.04322727 0.03333431 1) (0.02447174 0.02586248 1) (0.01092620 0.01775595 1)) spline 12 10 ((0.99726095 -0.00038712 -1) (0.98907380 -0.00153653 -1) (0.97552826 -0.00341331 -1) (0.95677273 -0.00596209 -1) (0.93301270 -0.00911073 -1) (0.90450850 -0.01277464 -1) (0.87157241 -0.01686084 -1) (0.83456530 -0.02127128 -1) (0.79389263 -0.02590486 -1) (0.75000000 -0.03065806 -1) (0.70336832 -0.03542434 -1) (0.65450850 -0.04009273 -1) (0.60395585 -0.04454642 -1) (0.55226423 -0.04866201 -1) (0.50000000 -0.05231025 -1) (0.44773577 -0.05535862 -1) (0.39604415 -0.05767604 -1) (0.34549150 -0.05913940 -1) (0.29663168 -0.05964120 -1) (0.25000000 -0.05909742 -1) (0.20610737 -0.05745444 -1) (0.16543470 -0.05469379 -1) (0.12842759 -0.05083398 -1) (0.09549150 -0.04592861 -1) (0.06698730 -0.04006079 -1) (0.04322727 -0.03333431 -1) (0.02447174 -0.02586248 -1) (0.01092620 -0.01775595 -1)) spline 13 11 ((0.99726095 -0.00038712 1) (0.98907380 -0.00153653 1) (0.97552826 -0.00341331 1) (0.95677273 -0.00596209 1) (0.93301270 -0.00911073 1) (0.90450850 -0.01277464 1) (0.87157241 -0.01686084 1) (0.83456530 -0.02127128 1) (0.79389263 -0.02590486 1) (0.75000000 -0.03065806 1) (0.70336832 -0.03542434 1) (0.65450850 -0.04009273 1) (0.60395585 -0.04454642 1) (0.55226423 -0.04866201 1) (0.50000000 -0.05231025 1) (0.44773577 -0.05535862 1) (0.39604415 -0.05767604 1) (0.34549150 -0.05913940 1) (0.29663168 -0.05964120 1) (0.25000000 -0.05909742 1) (0.20610737 -0.05745444 1) (0.16543470 -0.05469379 1) (0.12842759 -0.05083398 1) (0.09549150 -0.04592861 1) (0.06698730 -0.04006079 1) (0.04322727 -0.03333431 1) (0.02447174 -0.02586248 1) (0.01092620 -0.01775595 1)) ); boundary ( movingWall { type wall; faces ( (0 4 7 3) (1 5 6 2) ); } fixedWalls { type wall; faces ( (8 9 11 10) (8 12 13 9) (10 12 13 11) ); } allAround { type empty; faces ( (3 7 6 2) (1 5 4 0) (0 3 2 1) (4 5 6 7) ); } ); mergePatchPairs ( ); Code:
application icoFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 0.2; deltaT 0.001; writeControl runTime; writeInterval 0.01; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; Code:
nu nu [ 0 2 -1 0 0 0 0 ] 0.01; Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (1 0 0); boundaryField { movingWall { type fixedValue; value uniform (1 0 0); } fixedWalls { type fixedValue; value uniform (0 0 0); } frontAndBack { type empty; } } |
June 19, 2012, 06:58 |
#2 | |
Rep Power: 19 |
Hey there,
did I get your idea right, that you are meshing inside the airfoil? Quote:
And this consequently mean you have to model everything except the inside. For that I used 6 blocks (also for an NACA 0012) one the goes from the symmetry line of the profile to the max extension upwards. This block is wrapping around the profile. The second one goes from the max extension to the end of the profile And the last one going along the symmetry line behind the profile. now you can use a symmetry plane for the other 3 blocks if you have 0 angle of attack to save time or as in my case model the other half like wise on the other side of the profile. Hint: Use offsets you can get from the internet and manipulate them with e.g. excell or open office and copy and paste them into the blockMesh file further details you find here: http://www.cfd-online.com/Forums/ope...-naca0012.html note that I suggested to use 8 blocks here which has to do with the fact that I used a submerged hydrofoil. but you should get an idea how it works. regards Colin |
June 19, 2012, 22:52 |
Rep Power: 14 |
So, if I understand what you mean me to do, there's no way to make a solid object? You just have to fit the edges of the air to the shape you want? Is there nothing like solidHex or something?
That's unfortunate. In the case I plan on getting to eventually, it would be so much easier to just map the solid object. |
June 20, 2012, 04:44 |
Rep Power: 19 |
Sure there is a way to make solids, but you don't have to mesh them.
That's what I tried to explain. If you want to see the flow around a foil you have to mesh the surroundings not the solid its self. All the patches connected then to the solid are then assigned as wall patches and this is then how you model a solid. For further understanding I recommend you the motorBike tutorial, which is basically the same, but the profile has been replaced by a motor bike. |
Problem in a simple case | donfrulli | STAR-CCM+ | 2 | December 9, 2016 09:01 |
[waves2Foam] very frustrating problem related to reconstructing a case | arieljeds | OpenFOAM Community Contributions | 0 | November 29, 2016 08:48 |
Simple heat transfer in tube case | Gimlas | OpenFOAM Running, Solving & CFD | 2 | July 2, 2013 15:05 |
NACA 0012 Case Will Not Converge | dancfd | OpenFOAM Running, Solving & CFD | 6 | November 14, 2011 20:09 |
? Simple CFD problem | Davy | Main CFD Forum | 0 | August 21, 1998 07:19 |
