[snappyHexMesh] Edge/Surface snapping on thin geometry |
May 14, 2012, 06:06 |
Tom
Rep Power: 15 |
I am trying to mesh a simple diffuser using SHM. I created the diffuser geometry as an STL file and used the surfaceFeatureExtract command. However, I am struggling to get SHM to snap to my geometry. See attached image of the diffuser surface mesh, and with the STL file showing corner edges it has missed. I have also attached the SHM dict and stl file.
Previously I have used Gmsh so am unfamiliar with the settings I need in SHM to achieve suitable snapping. Any help/advice would be much appreciated. Regards Tom |
May 14, 2012, 06:30 |
#2 | |
Hi Tom;
have you run surfaceFeatureExtract? If you did, with which flags? Should be something like this: Quote:
May 14, 2012, 06:36 |
Tom
Rep Power: 15 |
Wow, thank you for your quick reply.
Yes I used that exact command and checked the resulting object file to see the edges that were extracted were correct, which they were. The problem seems to be with SHM in getting the mesh to snap to those edges. |
May 14, 2012, 07:23 |
#4 | |
Don't know exactly what's causing the issue here. I started sHM with the motorbike dictionary and I managed to get it working ok. If compared to your dictionary a lot of stuff is different…
To speed up the process I removed the layers and decreased the mesh refinement on the diffuser… You may want to run Quote:
Hope this helps… Regards |
May 14, 2012, 08:32 |
Tom
Rep Power: 15 |
Brilliant, thank you very much.
After increasing the refinement 1 more level all edges are snapped and well defined. After some playing I think the parameter that had the biggest effect was the 'resolveFeatureAngle'. Previously I had 90, but in your dictionary 30 and this improved the snapping a lot. Thanks again for your help, Tom |
edge, snapping, snappyhexmesh |
[snappyHexMesh] SnappyHexMesh : snapping not matching surface | Awak | OpenFOAM Meshing & Mesh Conversion | 4 | May 31, 2016 09:23 |
Import Deformed Geometry into Fluent | lgamble | FLUENT | 1 | February 25, 2016 14:59 |
[snappyHexMesh] SHM not snapping to some surfaces | Swift | OpenFOAM Meshing & Mesh Conversion | 13 | January 4, 2016 02:56 |
Problematic Geometry | fatb0y | CFX | 15 | October 13, 2010 18:17 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 05:31 |
