[Other] Sharp Edge
Old   May 9, 2012, 13:00
Default Sharp Edge
callahance is on a distinguished road
Hi all,
im having a problem in meshing a sharp edge. I used polydualmesh to convert a tet mesh. The case is 2D and polydualMesh creats automatically another cell layer in z-direction so that i had to remove this layer to get just one layer of cells using setSet. So far so good. everything worked , checkMesh looks good and everything is Ok. I just have one small problem near the edge when viewing the mesh with paraview... i dunno what this is (im not sure if its a cell). I attached a snapshot of the mesh .
Any help would be appreciated.
callahance is offline   Reply With Quote
Old   May 10, 2012, 17:20
nobody has any clue about this ?
Old   March 28, 2013, 02:11
Ilya
skeptik is on a distinguished road
it seems, that you should use bigger angle parameter.
For instance "polyDualMesh 120"
http://www.cfd-online.com/Forums/blo...r-than-90.html
practice makes perfect
skeptik is offline   Reply With Quote
[ICEM] Meshing Wing with low Y+ value and sharp trailing edge sonic109 ANSYS Meshing & Geometry 0 July 27, 2015 10:29
[ICEM] Hole near sharp trailing edge of airplane/wing geometry jlichtwa ANSYS Meshing & Geometry 2 September 21, 2010 16:19
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 02:07
