[blockMesh] error EOF in blockMesh
Old   May 6, 2012, 16:31
Default error EOF in blockMesh
Ahmed Khattab's Avatar
ahmed
Ahmed Khattab is on a distinguished road
Hi Foamers,
when i was working on a case using chtMultiRegionFoam, i found this error message while running blockMesh.
Create time
Creating block mesh from
"/home/khattab/ahmed.2.0.1/tutorials/heatTransfer/chtMultiRegionFoam/Graetz/constant/polyMesh/blockMeshDict"
Creating curved edges
Creating topology blocks
Creating topology patches
--> FOAM FATAL IO ERROR:
attempt to read beyond EOF
file: /home/khattab/ahmed.2.0.1/tutorials/heatTransfer/chtMultiRegionFoam/Graetz/constant/polyMesh/blockMeshDict::boundary at line 211.
From function ITstream::read(token&)
in file db/IOstreams/Tstreams/ITstream.C at line 83.
FOAM exiting
mentioned line 211 is the one containing ); before line of mergePatchPairs colored in red
outlet
type patch;
faces
(25 26 38 37)
(26 27 39 38)
(27 28 40 39)
(28 29 41 40)
(29 30 42 41)
(30 31 43 42)
(31 32 44 43)
(32 33 45 44)
(33 34 46 45)
(34 35 47 46)
(35 36 48 47)
(36 37 49 48)
mergePatchPairs
Ahmed Khattab is offline   Reply With Quote
Old   May 6, 2012, 19:05
Retired Super Moderator
Bruno Santos
Hi Ahmed,
Without seeing more of the file, I can only assume that you're missing this part of the file:
boundary
Best regards,
Bruno
Old   May 7, 2012, 03:33
ahmed
Originally Posted by wyldckat View Post
Hi Ahmed,
boundary
Best regards,
Bruno
Hi Bruno,
thanks for your reply but this part is exist in the file, i didn't show it to avoid large thread.
Old   May 7, 2012, 08:25
kid
cfdkid
kid is on a distinguished road
Hi
Please post complete blockMehDict.
Use dropbox to upload large file and to avoid long threads.
Generally we miss out braces and place the co-responding one correctly , and the compiler checks only for extra character i.e braces in this case.
________________________________________
Regards,
CFDkid
It never gets easier You just get Better
kid is offline   Reply With Quote
Old   May 9, 2012, 05:27
Question
ahmed
Originally Posted by kid View Post
Hi
HI CFDkid
thanks for your reply, i found problem in attaching file so i copy it in my reply. i added some line to my file so the problem became in line276 (red colored).
|  \\    /   O peration     | Version:  2.1.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 0.01;
vertices
    (0  11          11)        // point 0
    (0  11          1)         // point 01
    (0  16          2.3397459) // point 02
    (0  19.66025    6)         // point 03
    (0  21          11)        // point 04
    (0  19.66025    16)        // point 05
    (0  16          19.66025)  // point 06
    (0  11          21)        // point 07
    (0  6           19.66025)  // point 08
    (0  2.3397459   16)        // point 09
    (0  1           11)        // point 10
    (0  2.3397459   6)         // point 11
    (0  6           2.3397459) // point 12
    (0  11          0)       // point 13
    (0  16.5        1.47372) // point 14
    (0  20.52628    5.5)     // point 15
    (0  22          11)      // point 16
    (0  20.52628    16.5)    // point 17
    (0  16.5        20.52628)// point 18
    (0  11          22)      // point 19
    (0  5.5         2.052628)// point 20
    (0  1.47372     16.5)    // point 21
    (0  0           11)      // point 22
    (0  1.47372     5.5)     // point 23
    (0  5.5         1.47372) // point 24
    (100  11          1)         // point 25
    (100  16          2.3397459) // point 26
    (100  19.66025    6)         // point 27
    (100  21          11)        // point 28
    (100  19.66025    16)        // point 29
    (100  16          19.66025)  // point 30
    (100  11          21)        // point 31
    (100  6           19.66025)  // point 32
    (100  2.3397459   16)        // point 33
    (100  1           11)        // point 34
    (100  2.3397459   6)         // point 35
    (100  6           2.3397459) // point 36
    (100  11          0)       // point 37
    (100  16.5        1.47372) // point 38
    (100  20.52628    5.5)     // point 39
    (100  22          11)      // point 40
    (100  20.52628    16.5)    // point 41
    (100  16.5        20.52628)// point 42
    (100  11          22)      // point 43
    (100  5.5         2.052628)// point 44
    (100  1.47372     16.5)    // point 45
    (100  0           11)      // point 46
    (100  1.47372     5.5)     // point 47
    (100  5.5         1.47372) // point 48
    (0  11          11)        // point 49
    (100  11        11)        // point 50
    (100  11        11)        // point 51
blocks
  hex (1  13 14 2  26 38 37 25) (10 10 10) simpleGrading (1 1 1)
  hex (2  14 15 3  27 39 38 26) (10 10 10) simpleGrading (1 1 1)
  hex (3  15 16 4  28 40 39 27) (10 10 10) simpleGrading (1 1 1)
  hex (4  16 17 5  29 41 40 28) (10 10 10) simpleGrading (1 1 1)
  hex (5  17 18 6  30 42 41 29) (10 10 10) simpleGrading (1 1 1)
  hex (6  18 19 7  31 43 42 30) (10 10 10) simpleGrading (1 1 1)
  hex (7  19 20 8  32 44 43 31) (10 10 10) simpleGrading (1 1 1)
  hex (8  20 21 9  33 45 44 32) (10 10 10) simpleGrading (1 1 1)
  hex (9  21 22 10 34 46 45 33) (10 10 10) simpleGrading (1 1 1)
  hex (10 22 23 11 35 47 46 34) (10 10 10) simpleGrading (1 1 1)
  hex (11 23 24 12 36 48 47 35) (10 10 10) simpleGrading (1 1 1)
  hex (12 24 13 1  25 37 48 36) (10 10 10) simpleGrading (1 1 1)
edges
arc 1  3  (0  16          2.3397459)
arc 2  4  (0  19.66025    6)
arc 3  5  (0  21          11)
arc 4  6  (0  19.66025    16)
arc 5  7  (0  16          19.66025)
arc 6  8  (0  11          21)        // point 07
arc 7  9  (0  6           19.66025)  // point 08
arc 8  10 (0  2.3397459   16)        // point 09
arc 9  11 (0  1           11)        // point 10
arc 10 12 (0  2.3397459   6)         // point 11
arc 11 1  (0  6           2.3397459) // point 12
arc 13 15 (0  16.5        1.47372)
arc 14 16 (0  20.52628    5.5)
arc 15 17 (0  22          11)
arc 16 18 (0  20.52628    16.5)
arc 17 19 (0  16.5        20.52628)
arc 18 20 (0  11          22)
arc 19 21 (0  5.5         2.052628)
arc 20 22 (0  1.47372     16.5)
arc 21 23 (0  0           11)
arc 22 24 (0  1.47372     5.5)
arc 23 13 (0  5.5         1.47372)
arc 25 27 (100  16          2.3397459) // point 26
arc 26 28 (100  19.66025    6)         // point 27
arc 27 29 (100  21          11)        // point 28
arc 28 30 (100  19.66025    16)        // point 29
arc 29 31 (100  16          19.66025)  // point 30
arc 30 32 (100  11          21)        // point 31
arc 31 33 (100  6           19.66025)  // point 32
arc 32 34 (100  2.3397459   16)        // point 33
arc 33 35 (100  1           11)        // point 34
arc 34 36 (100  2.3397459   6)         // point 35
arc 35 25 (100  6           2.3397459) // point 36
arc 37 39 (100  16.5        1.47372)
arc 38 40 (100  20.52628    5.5)
arc 39 41 (100  22          11)
arc 40 42 (100  20.52628    16.5)
arc 41 43 (100  16.5        20.52628)
arc 42 44 (100  11          22)
arc 43 45 (100  5.5         2.052628)
arc 44 46 (100  1.47372     16.5)
arc 45 47 (100  0           11)
arc 46 48 (100  1.47372     5.5)
arc 47 37 (100  5.5         1.47372)
boundary
    internal face
        type wall;
        faces
            (1  2  26  25)
            (2  3  27  26)
            (3  4  28  27)
            (4  5  29  28)
            (5  6  30  29)
            (6  7  31  30)
            (7  8  32  31)
            (8  9  33  32)
            (9  10 34  33)
            (10 11 35  34)
            (11 12 36  35)
            (12 1  25  36)
    outer face
        type wall;
        faces
            (13 37 38 14)
            (14 38 39 15)
            (15 39 40 16)
            (16 40 41 17)
            (17 41 42 18)
            (18 42 43 19)
            (19 43 44 20)
            (20 44 45 21)
            (21 45 46 22)
            (22 46 47 23)
            (23 47 48 24)
            (24 48 37 13)
    inlet
        type wall;
        faces
            (1  13 14 2)
            (2  14 15 3)
            (3  15 16 4)
            (4  16 17 5)
            (5  17 18 6)
            (6  18 19 7)
            (7  19 20 8)
            (8  20 21 9)
            (9  21 22 10)
            (10 22 23 11)
            (11 23 24 12)
            (12 24 13 1)
    outlet
        type wall;
        faces
            (25 26 38 37)
            (26 27 39 38)
            (27 28 40 39)
            (28 29 41 40)
            (29 30 42 41)
            (30 31 43 42)
            (31 32 44 43)
            (32 33 45 44)
            (33 34 46 45)
            (34 35 47 46)
            (35 36 48 47)
            (36 25 37 48)
    inlet_flow
    type wall;
    faces
       (0 1  2  49)
       (0 2  3  49)
       (0 3  4  49)
       (0 4  5  49)
       (0 5  6  49)
       (0 6  7  49)
       (0 7  8  49)
       (0 8  9  49)
       (0 9  10 49)
       (0 10 11 49)
       (0 11 12 49)
       (0 12 1  49)
    outlet_flow
    type wall;
    faces
       (50 26  25 51)
       (50 27  26 51)
       (50 28  27 51)
       (50 29  28 51)
       (50 30  29 51)
       (50 31  30 51)
       (50 32  31 51)
       (50 33  32 51)
       (50 34  33 51)
       (50 35  34 51)
       (50 36  35 51)
       (50 25  36 51)
mergePatchPairs
thanks in advance.
ahmed
Old   May 9, 2012, 05:37
kid
cfdkid
Could you please see the bold character below in your blockMeshDict.
"internal face" has to be one single word and not separated word ,which happens to be in your case so join them by using a underScore or something.
And same should be done for "outer face"
Hope this helps.
Regards,
CFDkid
Old   May 13, 2012, 07:02
ahmed
Hi Kid,
it worked. i also figured out some faults and solved it.
thank you very much.
Old   May 17, 2012, 01:37
kid
cfdkid
Your WelCome
Regards,
CFDkid
eof
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 bjdarrer OpenFOAM Installation 7 August 25, 2020 20:15
blockMesh wmake error for OpenFOAM5 on ubuntu on windows rclement OpenFOAM Programming & Development 2 March 5, 2018 17:57
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
[blockMesh] set of xyz data in blockMesh psk OpenFOAM Meshing & Mesh Conversion 12 August 27, 2013 09:37
Blockmesh cavity error message tonitoney OpenFOAM Installation 2 March 17, 2008 12:59
