[mesh manipulation] extrudeMesh from STL Surface
Old   April 19, 2012, 16:32
Default extrudeMesh from STL Surface
TRT
TRT is on a distinguished road
EDIT: Solved below.
Hi everyone,
I'm having a problem when running extrudeMesh from an STL surface. I'm doing this because I'm having problems with running the tandem snappyHexMesh+extrudeMesh, but that is another whole story (that I may post about in the future). This is a test surface I wrote quickly in order to test:
./constant/triSurface/mesh.stl
solid mesh
  facet normal 0.0 0.0 1.0
    outer loop
      vertex 1.0 1.0 0.0
      vertex 0.0 1.0 0.0
      vertex 1.0 0.0 0.0
    endloop
  endfacet
    outer loop
      vertex 0.0 0.0 0.0
      vertex 0.0 1.0 0.0
      vertex 1.0 0.0 0.0
    endloop
  endfacet
    outer loop
      vertex 1.0 -1.0 0.0
      vertex 0.0 -1.0 0.0
      vertex 1.0 0.0 0.0
    endloop
  endfacet
    outer loop
      vertex 0.0 0.0 0.0
      vertex 0.0 -1.0 0.0
      vertex 1.0 0.0 0.0
    endloop
  endfacet
    outer loop
      vertex -1.0 1.0 0.0
      vertex 0.0 1.0 0.0
      vertex -1.0 0.0 0.0
    endloop
  endfacet
    outer loop
      vertex 0.0 0.0 0.0
      vertex 0.0 1.0 0.0
      vertex -1.0 0.0 0.0
    endloop
  endfacet
    outer loop
      vertex -1.0 -1.0 0.0
      vertex 0.0 -1.0 0.0
      vertex -1.0 0.0 0.0
    endloop
  endfacet
    outer loop
      vertex 0.0 0.0 0.0
      vertex 0.0 -1.0 0.0
      vertex -1.0 0.0 0.0
    endloop
  endfacet
endsolid mesh
This is my extrudeMeshDict file:
./system/extrudeMeshDict
|  \\    /   O peration     | Version:  1.6                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      extrudeProperties;
constructFrom       surface;
surface            "./constant/triSurface/mesh.stl";
flipNormals         false;
extrudeModel        linearNormal;
nLayers             1;
expansionRatio      1.0;
linearNormalCoeffs
    thickness       5.0;
mergeFaces          false;
After running extrudeMesh I get a mesh with no points, no faces and no cells. The output shows:
Extruding surface with :
    faces      : 8
    normals[0] : (0 0 1)
Mesh bounding box : (-1 -1 -5) (1 1 5)
        with span : (2 2 10)
Merge distance    : 0.0002
Collapsing edges < 0.0002 ...
Merging edge (3 12) since length 0 << 0.0002
Merging edge (1 10) since length 0 << 0.0002
Merging edge (2 11) since length 0 << 0.0002
Merging edge (5 14) since length 0 << 0.0002
Merging edge (7 16) since length 0 << 0.0002
Cell:1 uses faces:5(0 1 2 17 25) of which too many are marked for removal:
    0 1 2
Cell:3 uses faces:5(1 3 4 19 27) of which too many are marked for removal:
    1 3 4
Does anyone know why this is happening, how to avoid this, or how is this supposed to be done?
Thanks in advance.
EDIT: I noticed that the problem was caused because OpenFOAM calculates the normal by applying the right-hand rule to the vertices, and not with the facet normal entry. I should have taken this into account. By sorting the vertices accordingly the mesh is generated OK.
The .stl file should read:
solid mesh
    outer loop
      vertex 1.0 1.0 0.0
      vertex 0.0 1.0 0.0
      vertex 1.0 0.0 0.0
    endloop
  endfacet
    outer loop
      vertex 0.0 0.0 0.0
      vertex 1.0 0.0 0.0
      vertex 0.0 1.0 0.0
    endloop
  endfacet
    outer loop
      vertex 1.0 -1.0 0.0
      vertex 1.0 0.0 0.0
      vertex 0.0 -1.0 0.0
    endloop
  endfacet
    outer loop
      vertex 0.0 0.0 0.0
      vertex 0.0 -1.0 0.0
      vertex 1.0 0.0 0.0
    endloop
  endfacet
    outer loop
      vertex -1.0 1.0 0.0
      vertex -1.0 0.0 0.0
      vertex 0.0 1.0 0.0
    endloop
  endfacet
    outer loop
      vertex 0.0 0.0 0.0
      vertex 0.0 1.0 0.0
      vertex -1.0 0.0 0.0
    endloop
  endfacet
    outer loop
      vertex 0.0 -1.0 0.0
      vertex -1.0 0.0 0.0
    endloop
  endfacet
    outer loop
      vertex 0.0 0.0 0.0
      vertex 0.0 -1.0 0.0
      vertex -1.0 0.0 0.0
    endloop
  endfacet
endsolid mesh
Terrassa Rocket Team Blog: http://terrassarocketteam.blogspot.com/
TRT is offline   Reply With Quote
Old   March 26, 2018, 08:15
Luís Tiago Ferreira Fernandes
ltiago94 is on a distinguished road
hello,
what do you mean by changing the vertices? When you draw the geometry and later save in stl format, you have to draw each vertice in the same order as you drew the base block mesh?
Thanks
Tiago
ltiago94 is offline   Reply With Quote
extrudemesh, merging, stl, surface
[snappyHexMesh] Surface triangulation using snappyHexMesh shaileshbg OpenFOAM Meshing & Mesh Conversion 4 October 17, 2019 05:42
[ICEM] cannot set boundary after split STL surface guohf ANSYS Meshing & Geometry 0 June 11, 2018 01:33
[Gmsh] Extrude stl surface for building a prismatic layer KateEisenhower OpenFOAM Meshing & Mesh Conversion 12 April 21, 2016 17:54
[snappyHexMesh] STL surface ignored -snappyhexmesh Ananthakrishnan OpenFOAM Meshing & Mesh Conversion 4 July 9, 2015 06:31
[snappyHexMesh] Experimentally obtained STL file for internal Flow SnappyHexMesh Irish09 OpenFOAM Meshing & Mesh Conversion 9 April 7, 2012 09:50
