[mesh manipulation] Mesh refinement
Old   June 30, 2015, 14:31
Default Mesh refinement
Everton Santos
dumas is on a distinguished road
Hello users, I have a problem if I'm simulating the wall when there boundary layer concentration, I need to refine the mesh. In the case it would be in the top wall and outlet. I am OpenFOAM 2.3 user. If anyone can help me I will be very grateful. Attached'm leaving the mesh created.
Best regards.
dumas is offline   Reply With Quote
Old   December 13, 2016, 17:14
cutter is on a distinguished road
sorry for the late reply. Maybe it's still useful (either for you or for follow-up readers).
I believe this can be done with two rather simple steps:
1. define the cell region nearby the the desired patch using topoSet or setSet
2. refine the mesh regions defined in the previous step using refineMesh (usage of a refineMeshDict, see https://openfoamwiki.net/index.php/RefineMesh)
Cutter
cutter is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 11 February 20, 2024 10:12
y+ = 1 boundary layer mesh with snappyHexMesh Arzed23 OpenFOAM Running, Solving & CFD 6 November 23, 2022 16:15
[snappyHexMesh] Edge Refinement fracasce OpenFOAM Meshing & Mesh Conversion 3 December 2, 2017 14:30
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[snappyHexMesh] problems using snappyHexMesh 2.1.0 on a supercomputer Sunxing OpenFOAM Meshing & Mesh Conversion 9 September 20, 2014 10:30
