[snappyHexMesh] Creating multiple unconnected solid elements with snappyHexMesh |
April 20, 2019, 12:09 |
Rep Power: 7 |
I want to do a FSI of multiple unconnected cylinders in 2D. Already managed to do it with one cylinder by using sHM. The next step would be to implement multiple unconnected cylinders with snappyHexMesh. Creating the fluid Mesh was no problem (grey mesh). But creating more than one solid element with one .stl file (containing the cylinders) proved to be tricky. As you can see in the picture sHM only generated the cylinder where locationinmesh was set (blue mesh). At researching the problem I didnīt find any solution. So before using blockMesh to create these solid elements I reach out to you guys Does anyone know a method to implement unconnected objects with snappyHexMesh by using one or more .stl files? snappyfail.png Last edited by Goddi; April 20, 2019 at 14:24. |
May 12, 2019, 09:12 |
solved :)
Rep Power: 7 |
special thanks to Philip and his proposal in another thread.
So for everyone facing the same problem in the future. A good source of information is page 14/30 in this pdf. By using mergeMeshes I was able to create this mesh: Last edited by Goddi; May 12, 2019 at 09:19. Reason: make it better ;) |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[snappyHexMesh] creating baffles using snappyHexMesh (for given random shaped surfaces) | ashish.svm | OpenFOAM Meshing & Mesh Conversion | 1 | January 17, 2018 01:24 |
[snappyHexMesh] snappyHexMesh on a multiple region blockMesh | blais.bruno | OpenFOAM Meshing & Mesh Conversion | 1 | February 17, 2015 05:40 |
multiple .stl in snappyHexMesh | jki | OpenFOAM Pre-Processing | 1 | August 2, 2014 13:07 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
