[snappyHexMesh] Calculation of number of faces sHM |
December 23, 2016, 13:55 |
Moritz
Rep Power: 10 |
Hi there,
I'm working on my Thesis and this forum already has been a huge help for me. Thanks to everyone who's contributing! I'm wondering how the number of faces is calculated. I expected it to be something like 6 times the number of cells, but it's more something around 3. For example I found this in the snappyHexMesh Logfile: Code:
After refinement surface refinement iteration 0 : cells: 43 708 500 faces: 132 352 117 points:44935475 During further refinement I get negative faces: Code:
After refinement gap refinement iteration 1 : cells: 888 490 165 faces: -1 563 835 164 points:952606417 Code:
*** Error in `snappyHexMesh': free(): corrupted unsorted chunks: 0x000000017a1176e0 *** Thanks for your help in advance! Moritz |
December 23, 2016, 14:49 |
Suffolk
Rep Power: 11 |
I am new to this and have become an OpenFOAM addict over the past month. Just want to say that before I give my thoughts on sHM.
The face calculation would not be 6 times the number of cells. Think about it this way: the cells share faces with each other and the shared faces don't count as 2 separate faces. Now imagine a perfect cube cell, completely surrounded by other cubes. Each face connects to another cell - thus these cell faces would not go towards the faces count! You are probably right with the error. I couldn't confirm as the largest mesh I have simulated is 100M. Sent from my iPhone using CFD Online Forum mobile app |
December 23, 2016, 15:23 |
Suffolk
Rep Power: 11 |
So the calculation for total face count would be (my first guess):
number of faces ( number of cells X 6) minus half the number of internal/shared faces. ?? Of course I am assuming I know the shape of each cell and the reasoning for half the shared faces is obvious. This calculation may be not 100% accurate (although it could be) but I am sure it will get you a very close figure. Sent from my iPhone using CFD Online Forum mobile app |
December 25, 2016, 15:58 |
Moritz
Rep Power: 10 |
Thanks for sharing your thoughts!
I checked, the formula doesn't work for me. But I took a look at a checkMesh logfile again. After the snapping process I get this for example: Code:
Mesh stats points: 121 499 837 faces: 287 925 286 internal faces: 230 639 221 cells: 83 115 144 faces per cell: 6.23911 boundary patches: 6 point zones: 0 face zones: 0 cell zones: 3 Code:
cells x faces per cell - internal faces = faces 83 115 144 x 6.23911 - 230 639 286 = 287 925 240 But the "faces per cell" depends on your geometry, and also with the same geometry but different parameters in the snappyHexMesh dict, "faces per cell" are different (for my case at least). It seems like it is not possible to calculate the number of faces just with the cell number or without checkMesh. Maybe someone can confirm my guess with the 32 Bit Integer Limit? Merry Christmas!! |
January 5, 2017, 09:55 |
Moritz
Rep Power: 10 |
I answered the question regarding the 32 Bit Integer Limit myself.
See this thread: maximum number of faces? |
January 7, 2017, 09:49 |
Suffolk
Rep Power: 11 |
Thank you for that sharing that - I am glad you solved the issue. How is the Thesis coming along ?
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' | BrendaEM | OpenFOAM Meshing & Mesh Conversion | 12 | April 3, 2022 19:32 |
parallel run OpenFoam | Srinath Reddy | OpenFOAM Running, Solving & CFD | 13 | February 27, 2019 10:15 |
[Other] Equal decomposition of cylindrical fluid domain | Sean95 | OpenFOAM Meshing & Mesh Conversion | 3 | February 12, 2019 04:34 |
[blockMesh] --> foam fatal error: | lillo763 | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2014 11:27 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 11:37 |
