[blockMesh] Creating an axisymmetric piston cylinder in blockMeshDict
Like Tree3Likes
  • 3 Post By simrego
Old   August 21, 2018, 19:05
Default Creating an axisymmetric piston cylinder in blockMeshDict
Foad
foadsf is on a distinguished road
I'm trying to follow this tutorial to create an axisymmetric cylinder and piston in blockMeshDict and this is my blockMeshDict file:
|  \\    /   O peration     | Version:  5                                     |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    root            "";
    case            "";
    instance        "";
    local           "";
    class       dictionary;
    object      blockMeshDict;
convertToMeters 0.001;
wa 5.0; // wedge angle must be 5 degrees
cr 10.0; // cylinder radius
pr 8.0; //piston radius
cl 50.0; // length of cylinder
px 20.0; // position of piston
pl 10.0; // length of piston
px2 #calc "$px+$pl"; // end of the piston
ms 50; //meshsize
vertices
    (0                      0                         0)    //00
    (#calc "$pr*cos($wa/2)" #calc "$pr*sin($wa/2)"    0)    //01
    (#calc "$pr*cos($wa/2)" #calc "-$pr*sin($wa/2)"   0)    //02
    (#calc "$pr*cos($wa/2)" #calc "-$pr*sin($wa/2)"   $px)  //03
    (#calc "$pr*cos($wa/2)" #calc "$pr*sin($wa/2)"    $px)  //04
    (0                      0                         $px)  //05
    (#calc "$cr*cos($wa/2)" #calc "$cr*sin($wa/2)"    $px)  //06
    (#calc "$cr*cos($wa/2)" #calc "$cr*sin($wa/2)"    0)    //07
    (#calc "$cr*cos($wa/2)" #calc "-$cr*sin($wa/2)"   0)    //08
    (#calc "$cr*cos($wa/2)" #calc "-$cr*sin($wa/2)"   $px)  //09
    (#calc "$cr*cos($wa/2)" #calc "-$cr*sin($wa/2)"   $px2) //10
    (#calc "$cr*cos($wa/2)" #calc "$cr*sin($wa/2)"    $px2) //11
    (#calc "$pr*cos($wa/2)" #calc "$pr*sin($wa/2)"    $px2) //12
    (#calc "$pr*cos($wa/2)" #calc "-$pr*sin($wa/2)"   $px2) //13
    (#calc "$pr*cos($wa/2)" #calc "-$pr*sin($wa/2)"   $cl)  //14
    (#calc "$pr*cos($wa/2)" #calc "$pr*sin($wa/2)"    $cl)  //15
    (#calc "$cr*cos($wa/2)" #calc "$cr*sin($wa/2)"    $cl)  //16
    (#calc "$cr*cos($wa/2)" #calc "-$cr*sin($wa/2)"   $cl)  //17
    (0                      0                         $cl)  //18
    (0                      0                         $px2) //19
blocks
    hex (0  1  2  0  5  4  3  5)         ($ms 1 $ms) simpleGrading (1 1 1)
    hex (1  7  8  2  1  4  6  9  3  4)   ($ms 1 $ms) simpleGrading (1 1 1)
    hex (4  6  9  3  4  12 11 10 13 12)  ($ms 1 $ms) simpleGrading (1 1 1)
    hex (12 11 10 13 12 15 16 17 14 15)  ($ms 1 $ms) simpleGrading (1 1 1)
    hex (19 12 13 19 18 15 14 18)        ($ms 1 $ms) simpleGrading (1 1 1)
edges
boundary
    inlet
        type patch;
        faces
            (0 1 2 0)
            (1 7 8 2)
    outlet
        type patch;
        faces
            (18 15 14 18)
            (15 16 17 14)
    walls
        type wall;
        faces
            (7  8  9  6)
            (6  9  10 11)
            (11 10 17 16)
    wedges
        type wedge;
        faces
            (0  1  4  5)
            (1  7  6  4)
            (4  6  11 12)
            (12 11 16 15)
            (19 12 15 18)
            (0  5  3  2)
            (2  3  9  8)
            (3  13 10 9)
            (13 14 17 10)
            (19 18 14 13)
    axis
           type empty;
           faces
               (0  5  5  0)
               (19 18 18 19)
mergePatchPairs
or here in this GitHub Gist.
However when I try to compile the mesh I get the infamous error message:
--> FOAM FATAL ERROR:
face 1 in patch 1 does not have neighbour cell face: 4(15 16 17 14)
From function Foam::labelList Foam:: polyMesh::facePatchFaceCells(const faceList&, const labelListList&, const faceListList&, Foam::label) const
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 118.
FOAM aborting
#0 Foam::error:: printStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
#2 Foam:: polyMesh::facePatchFaceCells(Foam::List<Foam::face > const&, Foam::List<Foam::List<int> > const&, Foam::List<Foam::List<Foam::face> > const&, int) const at ??:?
#3 Foam:: polyMesh::setTopology(Foam::List<Foam::cellShape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::List<int>&, Foam::List<int>&, int&, int&, Foam::List<Foam::cell>&) at ??:?
#4 Foam:: polyMesh:: polyMesh(Foam::IOobject const&, Foam::Xfer<Foam::Field<Foam::Vector<double> > > const&, Foam::List<Foam::cellShape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::PtrList<Foam::dictionary> const&, Foam::word const&, Foam::word const&, bool) at ??:?
#5 Foam::blockMesh::createTopology(Foam::IOdictionary const&, Foam::word const&) at ??:?
#6 Foam::blockMesh::blockMesh(Foam::IOdictionary const&, Foam::word const&) at ??:?
#7 ? at ??:?
#8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#9 ? at ??:?
Aborted (core dumped)
I tried many different posts here in cfd-online or other forums, but none helped resolve the issue. I was wondering if you could:
  1. could help me find the issue in my blockMeshDict
  2. give me any examples of an axisymmetric system modeled directly in BlockMeshDict.
foadsf is offline   Reply With Quote
Old   August 22, 2018, 04:58
anonymous
simrego is on a distinguished road
Hi!
Your patch definition is bad.
So in patch 1 (outlet), the face 1 (15 16 17 14) is not valid.
But there are also some weird stuff going on. If you create a hex, how can you have 10 vertices for a hex???
Check your block and patch definitions!
Maybe this can help you a bit:
https://cfd.direct/openfoam/user-guide/v6-blockmesh/
simrego is offline   Reply With Quote
Old   August 22, 2018, 05:57
Foad
I changed the blocks section to:
blocks
    hex (1  7  8  2  4  6  9  3)         ($ms 1 $ms) simpleGrading (1 1 1)
    hex (4  6  9  3  12 11 10 13)        ($ms 1 $ms) simpleGrading (1 1 1)
    hex (12 11 10 13 15 16 17 14)        ($ms 1 $ms) simpleGrading (1 1 1)
and Now I get the error:
wedge wedges plane aligns with a coordinate plane.
The wedge plane should make a small angle (~2.5deg) with the coordinate plan e
and the the pair of wedge planes should be symmetric about the coordinate pl ane.
Normal of wedge plane is (0.598471 1.11022e-017 -1.92593e-035) , implied coo rdinate plane direction is (1 0 -0)
From function virtual void Foam::wedgePolyPatch::calcGeometry(Foam::PstreamB uffers&)
in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at lin e 110.
FOAM exiting
Also here you may see an image illustrating the points:
New Doc 2018-08-21.pdf
Old   August 22, 2018, 06:37
anonymous
Sorry now i'm a bit lost. I do not really understand this error message, but there is some problem with the wedge patch.
Maybe try to split the wedge patch into 2 patches: wedgeFront and wedgeBack. I'm not sure if they can be in the same patch.
If still not working, you can try with patchtype patch for the wegdes just to generate the mesh and at least you will see if your geometry is correct. (but it won't solve the problem since you will need a wedge type.)
Old   August 22, 2018, 07:01
Foad
I will try splitting patches.
Have you seen any working examples of using blockMeshDict to create an axisymmetric model?
Old   August 22, 2018, 07:58
anonymous
Yes I've also tried it a long time ago and it is working perfectly.
You can find tutorial blockMesh files containing wedge like:
find $FOAM_TUTORIALS -name blockMeshDict | xargs grep -l -i wedge
an example:
incompressible/pimplyDyMFoam/movingCone
oumnion, foadsf and sourav90 like this.
Old   August 22, 2018, 19:11
Foad
I divided the wedges boundary as suggested:
    wedgeBack
        type wedge;
        faces
            (0  1  4  5)
            (1  7  6  4)
            (4  6  11 12)
            (12 11 16 15)
            (19 12 15 18)
    wedgeFront
        type wedge;
        faces
            (0  5  3  2)
            (2  3  9  8)
            (3  13 10 9)
            (13 14 17 10)
            (19 18 14 13)
surprisingly there are no errors with the outlet face (15 16 17 14) anymore. however I get a bunch of warnings:
Creating block mesh topology
--> FOAM Warning :
    From function Foam::polyMesh::polyMesh(const Foam::IOobject&, const Foam::Xfer<Foam::Field<Foam::Vector<double> > >&, const cellShapeList&, const faceListList&, const wordList&, const Foam::PtrList<Foam::dictionary>&, const Foam::word&, const Foam::word&, bool)
    in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 871
    Found 3 undefined faces in mesh; adding to default patch.
--> FOAM Warning :
    From function virtual void Foam::wedgePolyPatch::calcGeometry(Foam::PstreamBuffers&)
    in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 70
    Wedge patch 'wedgeFront' is not planar.
At local face at (-3.20457 2.39389 10) the normal (0.598472 0.801143 0) differs from the average normal (0.598471 0.801144 1.11022e-18) by 2.72438e-12
Either correct the patch or split it into planar parts
--> FOAM Warning :
At local face at (-7.2103 5.38625 10) the normal (0.59847 0.801145 1.38778e-18) differs from the average normal (0.598471 0.801144 1.11022e-18) by 1.21084e-12
--> FOAM Warning :
At local face at (-7.2103 5.38625 25) the normal (0.59847 0.801145 2.77556e-18) differs from the average normal (0.598471 0.801144 1.11022e-18) by 1.21084e-12
--> FOAM Warning :
At local face at (-7.2103 5.38625 40) the normal (0.59847 0.801145 1.38778e-18) differs from the average normal (0.598471 0.801144 1.11022e-18) by 1.21084e-12
--> FOAM Warning :
At local face at (-3.20457 2.39389 40) the normal (0.598472 0.801143 0) differs from the average normal (0.598471 0.801144 1.11022e-18) by 2.72438e-12
--> FOAM Warning :
At local face at (-3.20457 -2.39389 10) the normal (0.598472 -0.801143 0) differs from the average normal (0.598471 -0.801144 -1.11022e-18) by 2.72438e-12
--> FOAM Warning :
At local face at (-7.2103 -5.38625 10) the normal (0.59847 -0.801145 -1.38778e-18) differs from the average normal (0.598471 -0.801144 -1.11022e-18) by 1.21084e-12
--> FOAM Warning :
At local face at (-7.2103 -5.38625 25) the normal (0.59847 -0.801145 -2.77556e-18) differs from the average normal (0.598471 -0.801144 -1.11022e-18) by 1.21084e-12
--> FOAM Warning :
At local face at (-7.2103 -5.38625 40) the normal (0.59847 -0.801145 -1.38778e-18) differs from the average normal (0.598471 -0.801144 -1.11022e-18) by 1.21084e-12
--> FOAM Warning :
At local face at (-3.20457 -2.39389 40) the normal (0.598472 -0.801143 0) differs from the average normal (0.598471 -0.801144 -1.11022e-18) by 2.72438e-12
and an error:
wedge wedgeFront centre plane does not align with a coordinate plane by 0.360319
    in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 98.
FOAM exiting
I also posted this error here in StachOverflow.
Old   August 23, 2018, 07:21
Foad
with the help of StackOverflow I managed to get most of I want:
//following this: https://openfoamwiki.net/index.php/Main_ContribExamples/AxiSymmetric
//  /cygdrive/c/Users/sojoodif/surfdrive/sync/MyPhD/simulation/OpenFOAM/20180131_2
FoamFile
    version     2.0;
    format      ascii;
    root            "";
    case            "";
    instance        "";
    local           "";
    class       dictionary;
wa 5.0*constant::mathematical::pi/180; // wedge angle must be smaller than 5 degrees
ms 50; //meshsize
vertices
    (0                      0                         0)    //00
    (0                      0                         $px)  //05
    (0                      0                         $cl)  //18
    (0                      0                         $px2) //19
blocks
    hex (0  2  1  0  5  3  4  5)         ($ms 1 $ms) simpleGrading (1 1 1)
    hex (1  2  8  7  4  3  9  6)         (1 1 $ms) simpleGrading (1 1 1)
    hex (4  3  9  6  12 13 10 11)        (1 1 $ms) simpleGrading (1 1 1)
    hex (12 13 10 11 15 14 17 16)        (1 1 $ms) simpleGrading (1 1 1)
    hex (19 13 12 19 18 14 15 18)        ($ms 1 $ms) simpleGrading (1 1 1)
edges
boundary
    inlet
        type patch;
        faces
            (0 2 1 0)
            (1 2 8 7)
    outlet
        type patch;
        faces
            (18 15 14 18)
            (15 16 17 14)
    walls
        type wall;
        faces
            (7  8  9  6)
            (6  9  10 11)
            (11 10 17 16)
            (5  4  3  5)
            (12 13 3  4)
            (19 13 12 19)
    wedgeFront
        type wedge;
        faces
            (0  1  4  5)
            (1  7  6  4)
            (4  6  11 12)
            (12 11 16 15)
            (19 12 15 18)
    wedgeBack
        type wedge;
        faces
            (0  2  3  5)
            (2  8  9  3)
            (3  9  10 13)
            (13 10 17 14)
            (19 13 14 18)
    axis
           type empty;
           faces
               (0  5  5  0)
               (19 18 18 19)
mergePatchPairs
however now I'm not able to divide hex blocks 2 ,3 and 4 in x direction
Old   August 23, 2018, 07:55
Foad
I was able to generate what I need. please read the comments of this post
Old   August 23, 2018, 08:54
anonymous
If you do what i suggested earlier, you could be done a long time ago...
( Use patch instead of wedge for troubleshooting and then just swap back to wedge.. )
In openFoam warnings tell you a LOT! So if you have an error, first read it!
That long warning what you posted only tell you that you missed 3 boundary patches from the definition so they are in the defaultFaces patch, and the others tell you that your wedge patches are not planar...
For the first time these errors looks weird, but they help you a lot! (in this case exactly tells you what was your mistake)
If you have 2 neighboring blocks, the spacing on the same face must be identical and you will have no error...
You really have to read that cfd.direct link what I sent you because all of your mistakes could be avoided if you know the basics of blockMesh
axisymmetric, blockmeshdict, openfoam
[blockMesh] Creating a tapered cylinder tanveerfathima OpenFOAM Meshing & Mesh Conversion 1 December 4, 2018 07:22
Moving piston inside cylinder Hope2010 STAR-CCM+ 4 November 13, 2013 00:48
Fuel film on piston and cylinder kri321shna STAR-CD 4 April 19, 2012 11:58
simulation of piston motion inside a hydraulic cylinder mosman FLUENT 0 August 6, 2011 16:44
Creating cylinder in STAR-CD Sachin Siemens 2 March 6, 2008 03:53
