Alletto - 2022 - Comparison of overset mesh with morphing mesh |
May 13, 2023, 13:42 |
#41 |
Manchester
Rep Power: 4 |
May 13, 2023, 15:02 |
#42 |
Michael Alletto
Rep Power: 16 |
Cubic should be 4th order accurate. So the dissipation is least. Which leads to the strongest vortexes and hence highest lift. Unfortunately I do not have an explanation why the frequency changes.
Best Michael |
May 15, 2023, 08:56 |
#43 | |
Manchester
Rep Power: 4 |
Best, Tianyang |
December 15, 2023, 18:46 |
#44 |
Amine Gorine
Can you please explain what's the purpose of each transformPoints command in Allrun.pre runApplication transformPoints -translate '(-10 0.0 0.0)' mv log.transformPoints log.transformPointsTranslate runApplication transformPoints -rotate '((0 1 0)(0 0 1))' mv log.transformPoints log.transformPointsrotate runApplication transformPoints -scale '(0.0016 1.2 0.0016)' mv log.transformPoints log.transformPointsscale runApplication transformPoints -translate '(0 0.06 0.0)' Thank you |
August 13, 2024, 15:20 |
#45 |
zink
Rep Power: 11 |
Just want to know why the gravity was activated in the y direction while the motion is simulated in the x and Z directions. Also, how can we understand the effect of added mass? As you have not included added mass in the frequency calculation. |
August 15, 2024, 09:50 |
#46 |
Michael Alletto
Rep Power: 16 |
Which test cases are you refering to. If the motion is in X and Z and Gravity in y It means it has no effect on the motion. Added mass is the work required to displace the fluid surrounding the cylinder
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" | GuiMagyar | OpenFOAM Meshing & Mesh Conversion | 3 | August 4, 2023 12:38 |
objects oscillate at high speed causing collapse in Dynamic mesh and overset mesh ca | insane | OpenFOAM Running, Solving & CFD | 0 | May 17, 2020 22:35 |
Overset: refine background mesh without resetting the mesh | JohnAB | STAR-CCM+ | 6 | May 19, 2014 13:48 |
Help in setting up an overset mesh | RKE | STAR-CCM+ | 1 | February 21, 2014 21:35 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
