does OpenFoam take advantage of 64bit OS?
Old   March 21, 2012, 12:50
Default does OpenFoam take advantage of 64bit OS?
Mihai Pruna
mihaipruna is on a distinguished road
I installed the 64bit AMD Ubuntu 11.10.
Will OpenFoam, out of the box, take advantage of the extra power, or is there another version I need to install?
http://www.openfoam.org/download/ubuntu.php
Thanks!
Mihai Pruna's Bio
mihaipruna is offline   Reply With Quote
Old   March 21, 2012, 15:16
Retired Super Moderator
Bruno Santos
Hi Mihai,
Well, it depends. Technically it is indeed installed the OpenFOAM version for 64bit, because you are using the 64bit version of Ubuntu.
Nonetheless, the compiled version is usually not fully optimized for all processors. Which means that to take full advantage of your machine's CPU features, you should do your own build of OpenFOAM: http://www.openfoam.org/download/source.php
Last but not least: if you have Ubuntu 64bit installed inside a virtual machine, I don't think it will do much difference if you build your own version, because you'll always be missing out on your machine's true power
Best regards,
Bruno
Old   March 21, 2012, 17:10
Mihai Pruna
thanks Bruno!
Mihai Pruna's Bio
OpenFOAM 1.6.x - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 68 April 22, 2013 12:03
Problem on installing Openfoam on 64bit sgi station gregjunqua OpenFOAM Installation 4 October 12, 2011 17:28
openfoam 1.5-dev on opensuse10.3-64bit anon_c OpenFOAM 2 December 4, 2009 01:33
Problem installing OpenFOAM 1.5 installation on RHEL 4. vwsj84 OpenFOAM Installation 4 April 23, 2009 05:48
Problems installing OpenFoam on a 64bit machine jango OpenFOAM Installation 1 June 4, 2007 15:53
