OpenFoam 2.0.1 --> 2.1.0
Old   January 2, 2012, 02:47
Default OpenFoam 2.0.1 --> 2.1.0
Soroush
SH_P is on a distinguished road
I have openFoam 2.0.1 installed and I want to install version 2.1.0.
could you please explain the steps to uninstall the previous version (is it necessary or it can overwrite the existing version?).
Thanks,
SH_P is offline   Reply With Quote
Old   January 2, 2012, 06:29
Assistant Moderator
Bernhard Gschaider
Originally Posted by SH_P View Post
Thanks,
Depends on how you installed OF
If you installed it from the sources then you can have multiple versions in parallel.
With the binary packages I think (I don't use them) you can only have one version at a time, but the package manager should take care of uninstalling the old version
Old   January 2, 2012, 06:58
Soroush
I installed it from the sources, how can I remove the older version after installing the new one. I have limited space available, so I have to do this!
Thanks
Old   January 2, 2012, 09:41
Retired Super Moderator
Bruno Santos
Greetings to all!
@Soroush: OK, assuming you have installed OpenFOAM in the usual folder at the home folder, it should be as easy as:
  1. Removing the folders "OpenFOAM-2.0.1" and "ThirdParty-2.0.1" from the folder "$HOME/OpenFOAM". To remove it directly on the command line, check first that you have these folders at "$HOME/OpenFOAM":
    ls -l $HOME/OpenFOAM
    If they are present there, then:
    cd $HOME/OpenFOAM
    rm -rf OpenFOAM-2.0.1 ThirdParty-2.0.1
  2. Remove the respective line in the file "$HOME/.bashrc". Edit it with your favourite text editor and remove the line that has a reference to "OpenFOAM-2.0.1".
  3. And that should be it! All done!
You can check the space available before and after by running:
df -h
Best regards,
Bruno
Old   January 2, 2012, 15:22
Soroush
Thanks Bruno...!
Old   January 4, 2012, 08:56
akidess's Avatar
Anton Kidess
Can 2.1.x run on ThirdParty-2.0.x? Can anybody report if there are major changes in the third party packages?
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   January 4, 2012, 10:07
Assistant Moderator
Bernhard Gschaider
Just do a symbolic link and adapt the version numbers of the packages in the settings file. That worked for me
Old   January 4, 2012, 17:19
Bruno Santos
Hi Anton and Bernhard,
To complement Bernhard's response, basically the changes were:
  • ParaView got upped from 3.10.1 to 3.12.0.
  • Some scripts got modified/fixed/updated, namely makeCGAL and makeParaView related.
  • There is a new makeGcc46 script.
  • And "Make/*" files for "libccmio" got removed... basically due a bug report by yours truly...
Scotch is still the same version.
Best regards,
Bruno
Old   January 5, 2012, 03:43
akidess's Avatar
Anton Kidess
Thanks to both of you!
[Salome] mesh conversion Salome --> OpenFoam vaina74 OpenFOAM Meshing & Mesh Conversion 42 March 4, 2022 21:41
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
OpenFoam 2.0.1 installation shailesh.nitk OpenFOAM Installation 4 October 4, 2011 09:50
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
CAD -> gMsh -> enGrid -> OpenFOAM Problem AlGates OpenFOAM 7 August 6, 2010 13:46
