[OpenFOAM.org] paraview compilation error paraview-3.12.0
Like Tree4Likes
Old   April 10, 2012, 13:21
Illya Shevchuk
linch is on a distinguished road
I have the same problem with Debian 2.6.32-5-amd64. The post #9 solution worked in my case also and I could install cmake 2.8.3 and rebuild paraview 3.12. The error was still there:
FATAL ERROR: ParaView reader module libraries do not exist
Please build the reader module before continuing:
cd $FOAM_UTILITIES/postProcessing/graphics/PV3Readers
./Allwclean
./Allwmake
But then, after building the reader module, everything went fine.
Thank you Bruno.
linch is offline   Reply With Quote
Old   May 15, 2012, 14:15
Default ParaView Out-of-Source Build?
  #22
Edward Leonard
iamed18 is on a distinguished road
Originally Posted by wyldckat View Post
OK, then lets try building a custom CMake with a more recent version:
  1. Go into the ThirdParty folder, get a script for downloading the CMake source code and make it executable:
    foam3rdParty
    wget "http://www.openfoam.com/mantisbt/file_download.php?file_id=143&type=bug" -O getCmake
    chmod +x get*
  2. Build CMake:
    ./getCmake
    ./makeCmake > mkcmake.log 2>&1
  3. Update the shell environment:
    wmSET
  4. Confirm that you now have a different and more up-to-date version:
    cmake --version
  5. Try to build ParaView once again:
    ./makeParaView > makePV.log 2>&1
Hopefully this will fix the problem!
Good luck!
Bruno
I have a quick query about this. I'm working with ParaView 3.12.0 and when I follow these directions, all's well until the last step, during the actual cmake of ParaView. The make runs into the following error:
CMake Error at CMakeLists.txt:58 (MESSAGE):
  ParaView requires an out of source Build.  Please create a separate binary
  directory and run CMake there.
-- Configuring incomplete, errors occurred!
Should I be editing the make file to fix this or is there a different solution I should look for?
Thanks!
EDIT: This has been resolved; I had unintentionally copied over an incorrect file, leaving CMakeCache.txt in the ParaView-3.12.0 directory, causing the error. All's well now!
iamed18 is offline   Reply With Quote
Old   June 11, 2012, 05:53
Xiaoguang Yang
sunlight is on a distinguished road
Thank Bruno Santos. Your method help me a lot.
sunlight is offline   Reply With Quote
Old   October 29, 2015, 10:58
Default Followed steps but still not working
  #24
Lisandro Maders
Lisandro Maders is on a distinguished road
I am not being able to compile the ThirdParty properly. Here is soem information:
- OpenFoam 2.1.0 installed and working fine
- OS System: Linux debian 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt11-1+deb8u5 (2015-10-09) x86_64 GNU/Linux
After having OF installed and have download Third-Party and also the ParaView you suggested (in case the Third-Party itsel does not work). Here is my /opt/OpenFOAM/ folder listing:
OpenFOAM-2.1.0    ParaView-3.12.0  ParaView-3.12.0.tar.gz  ThirdParty-2.1.0.tgz
Then I did the following, with OpenFOAM already sourced:
tar xzf ThirdParty-2.1.0.tgz
cd $WM_THIRD_PARTY_DIR
It goes to the right directory -> /opt/OpenFOAM/ThirdParty-2.1.0, then:
The makePV.log is attached.
As you can see,it gave me a similar error than the guys above had. So I tried to follow the steps you suggested (step #9),by using the ParaView downloaded from the link you suggested.
First I removed the Paraview folder from ThirdParty folder, and copied the one downloaded from the link. Then, I followed the step #9 and the log result is also attached.
It did not work as well and when I try to run paraFoam it returns me the following message:
./Allwclean
./Allwmake
Whose commands I have already done. Then I found that the file Allwmake from such directory has a environment variable called $ParaView_DIR that should go to: /opt/OpenFOAM/ThirdParty-2.1.0/platforms/linux64Gcc/paraview-3.12.0
But actually, there is no paraview-3.12.0 folder in this directory.
I have no idea anymore what to do, I do not have very good knowledge on this stuff, so I would be glad if someone could help me with this..
Regards,
Lisandro
Lisandro Maders is offline   Reply With Quote
Old   October 31, 2015, 08:15
Retired Super Moderator
Bruno Santos
Greetings Lisandro,
For the error in the first log file, the problem is the same as documented here:
Quick answer: http://openfoamwiki.net/index.php/In...u#Ubuntu_15.04 - step #9, sub-step #1, has the fix necessary for this problem.
In addition, this is documented at the end of the README file in the ThirdParty folder: https://github.com/OpenFOAM/ThirdPar...g-paraview-410
As for the second log file, if I remember correctly, it's because a few packages are missing that can be installed with this command:
sudo apt-get install libglu1-mesa-dev libqt4-opengl-dev
Best regards,
Bruno
Old   November 1, 2015, 20:44
Lisandro Maders
Well, it did not work. But I decided to check if it was everything really ok with OpenFOAM installation and it was not. So let's go step by step..
Here is the make.log from OF compilation, there are some errors I could not identify.. Just to be sure, is there a compatibilty between my Debian version and OF210, right? I am finding very weird it is giving me such errors, since I have already installed sometimes other versions of OF in Ubuntu systems without problems... Anyway, the make.log is attached and this is the log file after running ./Allwmake twice in order to get a summary from the previous compilation.
Thanks a lot for your help.
Regards,
LIsandro.
Old   November 2, 2015, 18:45
Bruno Santos
Hi Lisandro,
Mmm... OK, those errors you've gotten seem a bit strange:
/home/lmaders/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so: undefined reference to `Foam::Reaction<Foam::constTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > >::typeName'
collect2: error: ld returned 1 exit status
This usually either has to do with:
  • the original library not having been compiled with success, which does not seem to be the situation in this case;
  • or ld is not able to automatically load libraries that would otherwise find them missing.
Please run the following commands:
gcc --version
g++ --version
ld --version
You can find the compatible GCC version list here: http://openfoamwiki.net/index.php/In...ibility_Matrix
And ld should be of type "bfd" and not "gold".
Best regards,
Bruno
Old   June 10, 2021, 15:05
Default Same error but 10 years later
  #28
Jnana Bhaskar Rao
jnanabrao is on a distinguished road
I know this is a really old thread but I'm facing the exact same problem with OF-6 and Ubuntu 20.04. OpenFOAM builds fine but Paraview and Third-Party do not. As the log file exceeds the .txt attachment size limit, I am adding the error lines here.
[  5%] Built target QtTesting
make: *** [Makefile:152: all] Error 2
Command exited with non-zero status 2
315.00user 25.09system 0:43.66elapsed 778%CPU (0avgtext+0avgdata 251968maxresident)k
15360inputs+228448outputs (31major+9504290minor)pagefaults 0swaps
I believe the script described for building Cmake in post #9 is already part of the Third-Party folder now. So I didn't try that solution. Any help is most welcome.
JBR
jnanabrao is offline   Reply With Quote
installation, paraview 3.12
Error building ParaVIEW 3.12.0 in CentOS 6.5 wjm OpenFOAM Installation 8 February 17, 2014 11:17
Compiling ParaView 3.12.0 on SUSE Linux Enterprise bmikuz OpenFOAM Installation 1 November 9, 2012 19:55
Installation Problem with ParaView 3.12.0 on Scientific Linux 5.7 Wley OpenFOAM Installation 2 September 28, 2012 07:06
[OpenFOAM] [Critical] ParaView 3.12.0 breaks monitor signal in Ubuntu 11.04 v_mil ParaView 5 March 18, 2012 14:39
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 22:41
