August 30, 2011, 06:04 |
gcc compiler path in make file
cfdkid
Rep Power: 17 |
I want to install OpenFOAM-1.7 on our big cluster. But i want to use system gcc i.e root gcc to compile. Where can i find gcc path in make file of OpenFOAM? I suppose i need to change that from default to my root gcc. Cheers, CFDkid |
August 30, 2011, 07:39 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings CFDkid,
Without knowing which OpenFOAM version you are talking about, then the simple answer is: check OpenFOAM's etc/settings.sh <2.0 or etc/config/settings.sh >=2.0 and see what the variable foamCompiler is set to. It should be comented just above it how to set it to use the system's compiler. Here are a few more links you might find helpful:
Bruno
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 17:02 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 18:18 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 14:43 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
