installed , stuck at bash file stage
Old   August 14, 2011, 05:13
Default installed , stuck at bash file stage
Tamilselvan K
selvan is on a distinguished road
I am trying to install openfoam.
I have downloaded files from openfoam from http://www.openfoam.com/ (source files page).
The files are installed in home/openfoam/OpenFoam-2.0.1 directory.
As said in doucumentation page I typed in ~/.bashrc file
/home$ source home/openfoam/OpenFOAM-2.0.1/etc/bashrc
saved and closed.
On typying in the terminal,
icoFoam -help
gives the message
icoFoam: command not found
What could be wrong? Can somebody help? Thanks in advance
selvan is offline   Reply With Quote
Old   August 14, 2011, 17:42
Retired Super Moderator
Bruno Santos
Greetings Tamilselvan and welcome to the forum!
saved and closed.
I think you didn't follow the instructions properly... Quoting what's on the official site:
if running bash or ksh (if in doubt type echo $SHELL), source the etc/bashrc file by adding the following line to the end of your $HOME/.bashrc file:
source $HOME/OpenFOAM/OpenFOAM-2.0.1/etc/bashrc
then type “source $HOME/.bashrc” in the current terminal window
You must do things exactly as it is described on the instructions! $HOME is not the same as $home !!
Best regards and good luck!
Bruno
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 10:50
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
gcc and executable file from Mac to Linux simone Marras Main CFD Forum 0 April 8, 2007 16:49
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 21:51
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
