Old   July 13, 2011, 21:14
Arrow OpenFOAM Installation
Not ryan ; - )
rclprice is on a distinguished road
Today, I can see that my original post below was 3-4 questions all
smashed into one post. My first question is:
For OF2.0.0, what are the package requirements? On the
install from source webpage, scotch is missing from the
SUSE linux instructions? Is there any other package(s) that is
known to be missing?
The OF1.7.1 SUSE Linux installation instructions list even more
packages.
wmake runs for 3.5 hrs. I do not want to repeat that too
many times.
Thanks!
-Ryan
Hello OpenFOAM Guru (out there somewhere) ,
I am compiling OpenFOAM on a CrayXT6 ( ColoState University).
The cray uses a customized version of SUSE linux.
I cannot tell precisely which packages are needed for the full compilation.
Here is what I have learned from openfoam.org :
* the required packages for installation from source is a short list
( it is not the same as for 1.7.1 under openSUSE linux)
* the foamSystemCheck reports everything is okay, but SCOTCH
is not even installed. That list mentioned above does not seem
to be complete.
* I have to switch from the openmpi default to mpich2. I can do that
in the <foamhome>/etc/baschrc file. Is that all that is required?
I have a more general question. When will the OpenFOAM2.0.0 rpms
be available?
I would appreciate any guidance that may be out there. The OpenFOAM 1.7.1
rpms installed very well on my laptop. I can get started on the math
side of things.
Thank you,
-Ryan
Last edited by rclprice; July 15, 2011 at 18:58. Reason: Too many questions in original post.
rclprice is offline   Reply With Quote
Old   July 21, 2011, 17:31
Retired Super Moderator
Bruno Santos
Greetings Ryan and welcome to the forum!
You can check this blog post: OpenFOAM 2.0.x and openSUSE 11.4
As for building things faster, before running Allwmake, execute this command:
export WM_NCOMPROCS=8
8 is the number of parallel processes to be used for building OpenFOAM. This can trim down your build time down to 20-40 minutes! Well, only as long as you have that many processors/hyper-threads on your machine!
If you are using csh, then run instead this command:
setenv WM_NCOMPROCS 8
Best regards,
Bruno
installation of open foam
OpenFoam 2.0.0 installation Jan_Peters OpenFOAM Installation 86 April 27, 2012 06:32
Critical errors during OpenFoam installation in OpenSuse 11.0 amscosta OpenFOAM 5 May 1, 2009 15:06
Problem installing OpenFOAM 1.5 installation on RHEL 4. vwsj84 OpenFOAM Installation 4 April 23, 2009 05:48
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 15:25
