ParMetis Thirdparty Compilation error in OpenFoam-1.6-ext
Old   June 30, 2011, 07:20
Default ParMetis Thirdparty Compilation error in OpenFoam-1.6-ext
Julia Springer
juliasp is on a distinguished road
I got the following error in the ThirdParty Compilation of OpenFOAM-1.6-ext
Updating the ThirdParty environment variables before building package ParMetis-3.1.1
Download ParMetis-3.1.1.tar.gz from : http://glaros.dtc.umn.edu/gkhome/fetch/sw/parmetis/ParMetis-3.1.1.tar.gz
--2011-06-29 20:05:48--  http://glaros.dtc.umn.edu/gkhome/fetch/sw/parmetis/ParMetis-3.1.1.tar.gz
Resolving glaros.dtc.umn.edu... 160.94.77.162
Connecting to glaros.dtc.umn.edu|160.94.77.162|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2011-06-29 20:05:49 ERROR 404: Not Found.
Making package ParMetis-3.1.1 using RPM.
Building package ParMetis-3.1.1
error: File /home/juliasp/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/SOURCES/ParMetis-3.1.1.tar.gz: No such file or directory
Installing package: ParMetis-3.1.1
  Uninstalling ParMetis-3.1.1 using RPM: ParMetis-3.1.1-linux64GccDPOpt.x86_64
  Installing ParMetis-3.1.1 using RPM file: /home/juliasp/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/RPMS/x86_64/ParMetis-3.1.1-linux64GccDPOpt.x86_64.rpm
error: open of /home/juliasp/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/RPMS/x86_64/ParMetis-3.1.1-linux64GccDPOpt.x86_64.rpm failed: No such file or directory
Done installing package ParMetis-3.1.1
this happens because the link http://glaros.dtc.umn.edu/gkhome/fet...s-3.1.1.tar.gz does no longer exist, probably because of new updates. The link for ParMetis-3.1.1.tar.gz is now
The easiest way to overcome this error is to download this package to OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/SOURCES and start the Thirdparty compilation again. I hope this helps at least it worked well for me.
Regards,
Julia
juliasp is offline   Reply With Quote
Old   June 30, 2011, 11:14
Martin Beaudoin
mbeaudoin will become famous soon enough
Thank you Julia for the bug fix.
Looks like the Karypis Lab is moving stuff around on their Web site, so the URLs for downloading Metis and ParMetis get broken.
Your solution is also the right one. Downloading the package directly into the rpmBuild/SOURCES is the right solution until a proper fix makes it into the script and into the main git branch.
If you want to really be sure your bug reports and fixes will get noticed, please contribute them here:
http://sourceforge.net/apps/mantisbt..._view_page.php
Best,
Martin
Regards,
Julia
mbeaudoin is offline   Reply With Quote
Compilation error for openfoam - 1.6 misakagan OpenFOAM 19 February 21, 2012 11:36
Test directory missing in OpenFOAM 1.6 ext andrewryan OpenFOAM 2 March 20, 2011 16:41
OpenFOAM 1.6 and ThirdParty Software Paraview dunlopjp OpenFOAM Installation 0 February 24, 2010 12:35
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 7 January 19, 2010 16:39
OpenFOAM Version 1.6 Released opencfd OpenFOAM Announcements from ESI-OpenCFD 0 July 27, 2009 18:55
