2.0.x on Mac OSX
Like Tree2Likes
Old   September 14, 2011, 05:40
Assistant Moderator
Bernhard Gschaider
Originally Posted by woodscn View Post
Perhaps unsurprisingly, the patch provided above doesn't work with ThirdParty-2.0.1, which is what's available now.
Is there a place I can find the old files? Is there a timeline for a new patch?
I wasn't aware of this problem (usually I don't touch ThirdParty). Can you tell me where it fails.
@old files: have you tried at the Sourceforge (the original foam project). Usually there is a history of all there is
@timeline: No. Once I know what the problem is I can assess how long it takes
Old   September 14, 2011, 10:56
Nathan Woods
woodscn is on a distinguished road
It fails on hunk 4 at 200.
I'd give you an exact quote, but I don't have the disk image ready anymore. The error wasn't really much more than that, anyway.
woodscn is offline   Reply With Quote
Old   September 14, 2011, 15:07
Assistant Moderator
Bernhard Gschaider
If I hadn't miscounted that would be Allwmake:
@@ -206,7 +217,10 @@
     # this needs generalizing
     makeFile=../../etc/wmakeFiles/scotch/Makefile.inc.i686_pc_linux2.shlib-OpenFOAM
+    if [ "$WM_ARCH_BASE" == "darwin" ]
+       then
+       makeFile=../../etc/wmakeFiles/scotch/Makefile.inc.i686_mac_darwin.shlib-OpenFOAM
+    fi
     if [ -f $makeFile -a ! -f Makefile.inc ]
     then
         rm -f Makefile.inc
I guess that the promise "this needs generalizing" was fulfilled in the new version and therefore the patch doesn't find its place.
I currently don't have time to look at Thirdparty-2.0.1 (let alone recompile it).
But if only this chunk fails things are not that bad: The Makefile for Darwin should have been produced by the patch. Have a look at Allwmake how makeFile is set now and point it to the darwin file.
Bernhard
Old   September 19, 2011, 09:04
Benjamin Stanke
xtphgu is on a distinguished road
Hi I'm new hire and first of all sorry for my bad english...
My problem is: I can not give openFOAM commands
-I installed OpenFOAM 2.0.1 with patches and Gcc46 on Lion 10.7.1, like sushant describes.
-After compile twice I had no error massage anymore.
-bashrc load if I start Terminal.
For example I tryed blockMesh in the tutorials but I always get the answer "command not found".
Do anyone have any idea?
Benny
xtphgu is offline   Reply With Quote
Old   September 19, 2011, 10:19
sushant's Avatar
sushant is on a distinguished road
Benny
Hi Benny, can you try these commands one at a time in a terminal (make sure bashrc is sourced in your ~/.profile) and share the output you get?
find $FOAM_INST_DIR/$WM_PROJECT-$WM_PROJECT_VERSION/platforms | grep -w blockMesh
echo $FOAM_APPBIN
echo $PATH
If you only have a hammer, you tend to see every problem as a nail.
sushant is offline   Reply With Quote
Old   September 19, 2011, 11:53
Benjamin Stanke
Thanks Sushant,
I added this in my ".profile":
hdiutil attach "$HOME/OpenFOAM/Mac-OF-2.0.dmg" -mountpoint "$HOME/OpenFOAM" > /dev/null
. ~/OpenFOAM/OpenFOAM-2.0.1/etc/bashrc
Locks like it works (no error message by starting Terminal)
The output from your Code:
bennyskiste:~ Benny$ find $FOAM_INST_DIR/$WM_PROJECT-$WM_PROJECT_VERSION/platforms | grep -w blockMesh
bennyskiste:~ Benny$ echo $FOAM_APPBIN
/Users/Benny/OpenFOAM/OpenFOAM-2.0.1/platforms/darwinIntel64GccDPOpt/bin
bennyskiste:~ Benny$ echo $PATH
/Users/Benny/OpenFOAM/ThirdParty-2.0.1/platforms/darwinIntel64Gcc/paraview-3.10.1/bin:/Users/Benny/OpenFOAM/ThirdParty-2.0.1/platforms/darwinIntel64Gcc/openmpi-1.5.3/bin:/Users/Benny/OpenFOAM/Benny-2.0.1/platforms/darwinIntel64GccDPOpt/bin:/Users/Benny/OpenFOAM/site/2.0.1/platforms/darwinIntel64GccDPOpt/bin:/Users/Benny/OpenFOAM/OpenFOAM-2.0.1/platforms/darwinIntel64GccDPOpt/bin:/Users/Benny/OpenFOAM/OpenFOAM-2.0.1/bin:/Users/Benny/OpenFOAM/OpenFOAM-2.0.1/wmake:/opt/local/bin:/opt/local/sbin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/X11/bin:/usr/texbin
Old   September 19, 2011, 11:54
Benjamin Stanke
double post because my internet made some problems...
Old   September 20, 2011, 06:15
Assistant Moderator
Bernhard Gschaider
Thanks Sushant,
Is there ANYTHING in FOAM_APPBIN or FOAM_LIBBIN (check with "ls $FOAM_APPBIN"). My suspicion is that one crucial library was not built in the beginning and everything that links to it was not built
Old   September 20, 2011, 07:55
Benjamin Stanke
Could be a problem that I built not just the Gcc46 but also Gcc45?
ls $FOAM_APPBIN
-> no answare
LS $FOAM_APPBIN
dummy libsolid.dylib
libODE.dylib libsolidMixtureProperties.dylib
libOSspecific.o libsolidProperties.dylib
libdistributionModels.dylib libspecie.dylib
libfileFormats.dylib libsurfMesh.dylib
libkineticTheoryModel.dylib libthermophysicalFunctions.dylib
libliquidMixtureProperties.dylib libtriSurface.dylib
libliquidProperties.dylib postCalc.o
libmolecularMeasurements.dylib
Old   September 20, 2011, 09:11
Assistant Moderator
Bernhard Gschaider
ls $FOAM_APPBIN
-> no answare
LS $FOAM_APPBIN
There are some very basic libraries missin (most notably libOpenFOAM.dylib). This means that ther is a problem at the beginning of the compilation. Try compiling with a log:
./Allwmake 2>&1 | tee compile.log
Then have a look at compile.log FROM THE TOP and report the first error you see (don't bother to post the whole log. I won't look at it)
Old   September 20, 2011, 09:33
Benjamin Stanke
my first errors:
configure: error: in `/Users/Benny/OpenFOAM/ThirdParty-2.0.1/openmpi-1.5.3':
configure: error: C compiler cannot create executables
You can get the whole compile.log file by using this link:
https://dataexchange.hs-bremen.de/exchange?g=3fsdnh
Old   September 20, 2011, 12:24
Assistant Moderator
Bernhard Gschaider
my first errors:
Are you sure that the compiler you configured exists? Or is in the path? Because it looks like the ThirdParty-stuff can't find it
Old   September 20, 2011, 14:03
Benjamin Stanke
The path exist. I`m doing all the compiling once again and I`m wondering why after I typed sudo port install openmpi +gcc46 I get
---> Building gcc44
A question about the patches:
I still use the path site/2.0.x for prefs.sh even though I'm unsung 2.0.1 ?
That's the result of the ThirdParty-patch:
patching file Allwmake
Hunk #3 succeeded at 199 with fuzz 1 (offset 3 lines).
Hunk #4 FAILED at 220.
1 out of 5 hunks FAILED -- saving rejects to file Allwmake.rej
patching file etc/wmakeFiles/scotch/Makefile.inc.i686_mac_darwin.shlib-OpenFOAM
Old   September 21, 2011, 06:44
Assistant Moderator
Bernhard Gschaider
---> Building gcc44
About OpenMPI. Why don't you use the one that comes with the system?
About the patch. I've been told that the patch doesn't work with 2.0.1 but I haven't got the time to look into it. I remembered discussing it elsewhere (I think even in this thread). Have a look
Old   September 21, 2011, 08:34
Smile
  #35
sushant's Avatar
---> Building gcc44
Last time I checked OpenMPI on MacPorts did not have a GCC46 variant. Are you sure there's one? The default variant depends on gcc44 and pulls it along. Since you're on Lion, you can easily build the openmpi-1.5.3 in ThirdParty (2.0.0!) and use it instead of the one from MacPorts.
As for your multiple compilers issue, I prefer to have ONE compiler, one text editor, one music player, one web browser, one girl, and so on and so forth; but I see that it makes sense for many people to need to have more than one. (compiler ). Sometimes it's easy to troubleshoot where there is only one possible culprit in each category, so if you don't really need it, you can do away with the multiple compilers.
If you're wondering if the site/prefs.sh is doing its job, you can use this alternative: put these lines in ~/.profile before you source bashrc:
export WM_MPLIB=OPENMPI #only for Lion; for SL stick to SYSTEMOPENMPI
export WM_COMPILER=Gcc46
In any case, gcc-mp-4.6 is not working on your system (that's what your log seems to say), so you can check with the commands:
gcc-mp-4.6 -v
g++-mp-4.6 -v
and also maybe make sure your disk image isn't read-only?
Others: while we're on this subject, what is the simplest way to tell wmake to use clang instead of the stock gcc? Does OF-2.0.x build successfully with the stock clang on OS X?
Regards,
Sushant
Old   September 21, 2011, 13:30
Benjamin Stanke
I thought I need this compiler because Lion isn't shipping with one:
In ~/OpenFOAM/site/2.0.x/prefs.sh change Gcc45 to Gcc46. Comment out the WM_MPLIB line, or change SYSTEMOPENMPI to simply OPENMPI (have to build your own MPI, Lion isn't shipping with one)
How do I use openmpi-1.5.3 in ThirdParty? By comment out or using OPENMPI?
gcc-mp-4.6 -v
g++-mp-4.6 -v
You are right. During the compiling gcc46 I get this Error:
Error: Target org.macports.build returned: shell command failed (see log for details)
Log for gcc46 is at: /opt/local/var/macports/logs/_opt_local_var_macports_sources_rsync.macports.org _release_tarballs_ports_lang_gcc46/gcc46/main.log
Error: Status 1 encountered during processing.
To report a bug, see <http://guide.macports.org/#project.tickets>
Hier the whole Log:
https://dataexchange.hs-bremen.de/exchange?g=e5yr2l
It is a sparseimage.
Thanks a lot for all your help!!!!
Benny
One More question: Why do I need Xcode, Gcc46 and compiling it if I just want to use the program OpenFOAM?
Old   September 22, 2011, 02:23
Wink
  #37
sushant's Avatar
I'm so sorry -- I meant this about multiple versions from MacPorts. about having both 4.5 and 4.6, etc.
in the site/2.0.x/prefs.sh, or my nonstandard, possibly ugly way is to set that in ~/.profile itself. Either way, you can always 'echo $WM_MPLIB' before doing ./Allwmake to verify.
Error: Target org.macports.build returned: shell command failed (see log for details)...
Thats what happens with gcc44 and gcc45 on Lion but shouldn't happen with gcc46. To start afresh, do a 'sudo port uninstall installed' (use -force if need be) and start afresh. (assuming you don't use MacPorts for anything else)
Because there isn't a readily usable "binary" version for Lion. In fact OF is not written with Mac OS in mind at all: any possibility of using it is largely due to patches churned out by muscle man bernhard.
For OS X 10.6, see the link in my signature for a binary image.
Old   September 22, 2011, 11:27
Benjamin Stanke
Strange... I've got always error during compiling Gcc46. Now I tested gcc45 and I could compile it. Then I did 'sudo port install openmpi +gcc45'
I downloaded the image from http://sourceforge.net/projects/macopenfoam/files/
and OF works
unfortunately the command 'mpirun' can not find???
OK but if someone compile it (like in the link above), why I don't can I can just use this compiled version? Why do I need Xcode, gcc and openmpi on my system too?
Old   September 22, 2011, 13:40
sushant's Avatar
I've faced the same thing with the openmpi from MacPorts...
Binaries depend upon certain libraries to work (lookup 'dynamic linking' and/or 'dylib'). So you don't really need the compilers but just the libraries which are part of the development suite. If you want to free up some (a lot of!) space, just delete /Developer (yes, really). A copy of the basic dev tools is in / anyway: thats the useful one.
You need the newer gcc because stock apple gcc is too old to compile this.
Old   September 22, 2011, 14:58
Benjamin Stanke
Do you think that will change soon? You know CFD calculation needs a lot of computing resources
Thanks, that's great /opt (2.4GB) I still need? I'm asking because I've got a SSD and not much space...
fluent @ Mac OSx ignazio FLUENT 12 July 25, 2017 08:03
foamToTecplot360 on mac osx 10.6 SL mohanamuraly OpenFOAM 0 April 27, 2011 01:26
Mac OSX and Homebrew egp OpenFOAM Installation 1 February 15, 2011 11:21
OpenFOAM13 for Mac OSX Darwin 104 hjasak OpenFOAM Installation 70 September 24, 2010 06:06
OpenFOAM on mac OSX Nick Colam Main CFD Forum 3 January 27, 2009 01:06
