OpenFOAM 1.7.x using intel compiler and MVAPICH2 |
May 21, 2011, 11:00 |
Kris
Rep Power: 16 |
Dear Foamers,
I've been searching the forum for days, but I cant seem to find a thread with the answer to my problem. I am trying to compile the latest OpenFOAM 1.7.x (git repository) using the Intel compiler and MVAPICH2. I have modified my bashrc to read: Code:
: ${WM_COMPILER:=Icc}; export WM_COMPILER : ${WM_MPLIB:=MPI-MVAPICH2}; export WM_MPLIB Code:
MPI-MVAPICH2) export MPI_HOME=/sw/comm/mvapich2/1.5.0-intel export MPI_ARCH_PATH=$MPI_HOME _foamAddPath $MPI_ARCH_PATH/bin _foamAddLib $MPI_ARCH_PATH/lib export FOAM_MPI_LIBBIN=$FOAM_LIBBIN/mvapich2 ;; Code:
PFLAGS = -DMPICH_SKIP_MPICXX PINC = -I$(MPI_ARCH_PATH)/include PLIBS = -L$(MPI_ARCH_PATH)/lib -lmpich -lrt Now, I have used intel.compiler (icc and ifort) version 12.0.0 and gcc 4.5.2. I get many warnings during compilation, all of them similar to this one: Code:
/home/kris/OpenFOAM/OpenFOAM-1.7.x/src/OpenFOAM/lnInclude/pTraits.H(71): warning #597: "Foam::pTraits<PrimitiveType>::operator Foam::symmTensor() const [with PrimitiveType=Foam::symmTensor]" will not be called for implicit or explicit conversions operator PrimitiveType() const ^ detected during: instantiation of class "Foam::pTraits<PrimitiveType> [with PrimitiveType=Foam::symmTensor]" at line 82 of "/home/kris/OpenFOAM/OpenFOAM-1.7.x/src/OpenFOAM/lnInclude/dimensionedType.H" instantiation of class "Foam::dimensioned<Type> [with Type=Foam::symmTensor]" at line 182 of "/home/kris/OpenFOAM/OpenFOAM-1.7.x/src/OpenFOAM/lnInclude/transform.H" Note that I have also compiled using GCC and MVAPICH2 and this worked perfectly. Thus, the problem must lie with the Intel compiler. Am I using the wrong version? Or is there something else I have missed? Any help would be greatly appreciated. Last edited by kpsl; May 21, 2011 at 11:19. |
May 22, 2011, 03:59 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Kris,
The error you are getting is very similar to this one: http://www.openfoam.com/mantisbt/view.php?id=98&nbn=3 A couple of solutions are listed there, so you might want to give it a try! Best regards, Bruno
May 22, 2011, 05:45 |
Kris
Rep Power: 16 |
Hi Bruno,
thank you for your reply I saw that post, in fact i copied and pasted the error from there since I don't have access to my log files from home. I noticed that the -xT warning no longer occurs in the latest 1.7.x release (it does occur a lot in 1.7.1). However, the compilation still gives the warning I originally posted many times. I am not sure where to apply -std=c++0x. Can I do it globally or do I need to go through all of the wmake files? Sorry, my compiling skills are not that developed. |
May 22, 2011, 05:57 |
Bruno Santos
Rep Power: 128 |
Hi Kris,
Mmm, I just remembered about a Japanese blog that has a few more instructions: http://www.geocities.co.jp/SiliconVa..._compiler.html You can try to use Google's hammer translator to sort out a few more details: http://translate.google.com/translat...n&hl=&ie=UTF-8 The interesting detail on that blog is that Icc 12 got beaten by gcc 4.5... Best regards, Bruno
May 22, 2011, 06:08 |
Kris
Rep Power: 16 |
Hi Bruno,
thank you for the great hint!! I will try this first thing tomorrow. Interesting that gcc beats icc. I guess will compare the two myself and post my results asap. Kind regards, Kris |
May 24, 2011, 05:14 |
Kris
Rep Power: 16 |
So, I managed to compile OpenFOAM without problems using the Intel compiler and MVAPICH2 thanks to Bruno's hint.
It runs fine in serial mode but it doesn't seem to work in parallel on the cluster I am using. Whenever I submit a job I get the message: Code:
mpiexec: Warning: tasks 0-63 exited before completing MPI startup I will ask my network admin to see if he knows a solution. The strange thing is that when compiling with gcc and MVAPICH2 using the exact same MPI setting, everthing works fine. |
May 24, 2011, 06:13 |
Kris
Rep Power: 16 |
Ok the results are in!
Benchmark done using the following setup: 16 nodes using 4 cores each = 64 CPUs Mesh containing ~3.5 million cells rhoPimpleFoam Criteria: real time taken to reach 0.0002s in the simulation. Intel.Compiler/12.0.0 & MVAPICH2/1.5.0-intel Run1: ExecutionTime = 88.49 s ClockTime = 90 s Run2: ExecutionTime = 87.57 s ClockTime = 88 s Run3: ExecutionTime = 87.9 s ClockTime = 89 s Mean: Execution Time = 87.98 s ClockTime = 89 s Gcc/4.5.2 & MVAPICH2/1.5.0-gcc Run1: ExecutionTime = 83.33 s ClockTime = 87 s Run2: ExecutionTime = 83.14 s ClockTime = 85 s Run3: ExecutionTime = 82.78 s ClockTime = 84 s Mean: ExecutionTime = 83.08 s ClockTime = 85.33 s GCC clearly beats Intel's compiler! |
May 27, 2011, 16:05 |
Bruno Santos
Rep Power: 128 |
Hi Kris,
This is very nice indeed! But from both benchmarks, I still get the feeling that anything less than 10min isn't much of a benchmark with OpenFOAM, since what we save on computational power, might get otherwise get wasted on some other task, like file access and MPI and so on... But still, extrapolating a 24h00 run on icc gives a whooping 23h12 on gcc in the worst cases! That's easily a meal or two! Now the big question is: are both end results as correct as when built with the officially advised gcc 4.4 series? And how does a gcc 4.4 build take on those other two!? Oh well... some things are best left unknown Best regards, Bruno
August 12, 2011, 14:44 |
#9 |
Kris
Rep Power: 16 |
I took the liberty of benching the Intel Compiler against Gcc once again. This time using the new OpenFOAM-2.0.x.
Mesh containing ~1 million cells. rhoPimpleFoam First a rather short run on one node. Data is written once at the end of the computation: Intel.Compiler/12.0.4 & MVAPICH2/1.5.0-intel 1 Node, 8 CPUs, Intel Xeon Harpertown E5472 Run1: ExecutionTime = 3438.8 s ClockTime = 3449 s Run2: ExecutionTime = 3440.75 s ClockTime = 3450 s Run3: ExecutionTime = 3448.05 s ClockTime = 3458 s Gcc/4.5.2 & MVAPICH2/1.5.0-gcc 1 Node, 8 CPUs each, Intel Xeon Harpertown E5472 Run1: ExecutionTime = 3286.97 s ClockTime = 3297 s Run2: ExecutionTime = 3288.28 s ClockTime = 3297 s Run3: ExecutionTime = 3285.53 s ClockTime = 3294 s And the same run on 8 nodes: Intel.Compiler/12.0.4 & MVAPICH2/1.5.0-intel 8 Nodes, 4 CPUs each, Intel Xeon Gainestown X5570 Run1: ExecutionTime = 209.24 s ClockTime = 211 s Run2: ExecutionTime = 208.58 s ClockTime = 209 s Run3: ExecutionTime = 209.44 s ClockTime = 212 s Gcc/4.5.2 & MVAPICH2/1.5.0-gcc 8 Nodes, 4 CPUs each, Intel Xeon Gainestown X5570 Run1: ExecutionTime = 177.08 s ClockTime = 178 s Run2: ExecutionTime = 175.57 s ClockTime = 176 s Run3: ExecutionTime = 177.66 s ClockTime = 181 s Then i took Bruno's advice and let the computation run 5 times longer. Data is now written 5 times in total: Intel.Compiler/12.0.4 & MVAPICH2/1.5.0-intel 8 Nodes, 4 CPUs each, Intel Xeon Gainestown X5570 Run1: ExecutionTime = 1099.89 s ClockTime = 1105 s Run2: ExecutionTime = 1099.45 s ClockTime = 1103 s Run3: ExecutionTime = 1096.52 s ClockTime = 1100 s Gcc/4.5.2 & MVAPICH2/1.5.0-gcc 8 Nodes, 4 CPUs each, Intel Xeon Gainestown X5570 Run1: ExecutionTime = 931.13 s ClockTime = 936 s Run2: ExecutionTime = 932.93 s ClockTime = 938 s Run3: ExecutionTime = 930.48 s ClockTime = 936 s As you can see, Gcc beats Intel by about 15% everytime. This seems to be a lot more than with 1.7.x, although i must admit, the "smaller" mesh may have something to do with it. |
