Problem installing OpenFoam-version 1.7.1 on SuSE 11.3 using the RPM Pack
Old   April 2, 2011, 01:30
Default Problem installing OpenFoam-version 1.7.1 on SuSE 11.3 using the RPM Pack
lil_jam is on a distinguished road
Hey fellows, need some tiny thing here :
I followed instructions on http://www.openfoam.com/download/suse.php
apparently downloading OpenFOAM for SuSE 11.3 x86_64bit. But happened to have some error which I can't solve:
by icoFoam -help gives out error: icoFoam: error while loading shared libraries: libscotch-5.1.so: cannot open shared object file: No such file or directory
sudo rpm -q libscotch gives: package not installed
sudo rpm -q libscotch-dev gives: libscotch-dev-5.1.6.dfsg-4.x86_64
(installed)
but I repeat instruction 4. for installing the 64bit of the libscotch library version gives: Preparing packages for installation...
package libscotch-5.1-5.1.6.dfsg-4.x86_64 is already installed
why does this error happened? looking foward for the solution of this problem!
thanks!
lil_jam is offline   Reply With Quote
Old   April 2, 2011, 05:50
Retired Super Moderator
Bruno Santos
Greetings lil_jam and welcome to the forum!
Try this:
rpm -q libscotch-5.1
I've just tested to install this in openSUSE 11.3 and all went OK, although there is a step missing on the official page:
sudo zypper in libqt4 libQtWebKit4
Only afterwards will you be able to install the ParaView rpm.
Best regards,
Bruno
Old   April 2, 2011, 10:45
thank you Bruno for the speedy answer. I've repeated the step 4 and tried again downloading these 4 stuffs like below. All showed 'already installed' beside the 1st one.
sudo rpm -i --badreloc --relocate /usr/lib=/usr/lib64 \
http://www.openfoam.com/download/sus...g-4.x86_64.rpm
sudo rpm -i http://www.openfoam.com/download/sus...0-2.x86_64.rpm
sudo rpm -i --nodeps http://www.openfoam.com/download/sus...0-2.x86_64.rpm
As when I downloaded the 1st line, it appeared this :
rpm: relocations must begin with a /
I also tried opening icoFoam -help on 2nd terminal, and showed this error :
that was like previously, where when I checked it again for libscotch ie line 1.
best regards
Old   April 2, 2011, 12:05
Bruno Santos
Hi lil_jam,
OK, try this:
sudo -s
rpm -i --badreloc --relocate /usr/lib=/usr/lib64 http://www.openfoam.com/download/suse/11.3/x86_64/libscotch-5.1-5.1.6.dfsg-4.x86_64.rpm
#then finally exit root mode
exit
This way it's executed directly in root mode and there isn't any "\" that could damage the command.
Best regards,
Bruno
Old   April 26, 2011, 06:20
Hi Bruno!
sorry that I've been away lately. Sorry I really tried it again. but it didn't work either. Still the same result as my 1st post.
best regards
lil_jam
Old   April 28, 2011, 15:09
Bruno Santos
Hi lil_jam,
Mmm, then the only option that comes to mind is to:
  1. Launch yast2 and go to the "Software Management" option.
  2. Update/refresh the repositories.
  3. Request it to re-install libscotch, until it's properly installed.
  4. Then run the other instructions once again.
Hopefully this should solve the problem. I didn't give more detailed instructions because right now I don't have an openSUSE box at arms length
Best regards and good luck!
Bruno
My experiences about Installing OpenFOAM on OPENSUSE103 32bit coompressor OpenFOAM Installation 9 February 19, 2010 00:00
Problem in Paraview While installing OpenFOAM 15 in Suse 103 altranindia OpenFOAM Installation 1 February 20, 2009 10:20
Pls help last problem to be solved for installing OPENfoam daydayuper OpenFOAM Installation 5 November 9, 2008 05:59
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 15:25
Problem installing OpenFOAM 141 sachin OpenFOAM Installation 2 February 22, 2008 11:20
