February 16, 2011, 13:20 |
OpenFOAM vs Ubuntu 10.10 64 bit
Vesselin Krastev
Rep Power: 20 |
Hi all, I really don't know what the hell is going on with the installation of OpenFOAM on my new Ubuntu 10.10 64 bit based machine, so any help would be really appreciated...A brief summary of the story so far:
- I usually work on a Fedora based server and on my old notebook (Ubuntu 8.10). I've installed successfully on both of them OpenFOAM-1.6 (64 bit version on the server and 32 bit version on the notebook). After the installation I've also compiled my own modifications and add-ons to the source code and they work perfectly. - Now I've changed my notebook and decided to install Ubuntu 10.10 64 bit and OpenFOAM 1.7.1 on it. Well, I've downloaded the source pack from the official OpenCFD site an built all (OpenFOAM and paraview) following the instructions: no errors, no strange messages, everything seemed ok, and in fact the tutorials worked perfectly. - After that, I've implemented the same additional source code as before (basically a new turbulence model and a new wall function) and compiled it: after fixing some errors (probably due to slight differences between the 1.6 and 1.7.1 versions), the compiling procedure of the incompressible/RAS turbulence models source folder (./Allwmake) was succesfull, but the tutorials now have some strange issues with the wall functions (also with those I didn't touch at all) and during the first iteration a segmentation fault error causes the exit from the run. - Well, maybe the problem was somewhere in the passage from 1.6 to 1.7.1, so ok, let's install the 1.6 64 bit version on the new machine! Again, downloading of the source pack and compiling, all seems good, the tutorials work. After that, compiling of the add-ons (this time with no errors at all) and....surprise! The same segmentation fault message! This is the error report form the airfoil2D tutorial (SpalartAllmaras model with nutSpalartAllmarasWallFunction at the wall, but the same is with other RAS models and wall functions): // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting RAS turbulence model SpalartAllmaras SpalartAllmarasCoeffs { sigmaNut 0.66666; kappa 0.41; Cb1 0.1355; Cb2 0.622; Cw2 0.3; Cw3 2; Cv1 7.1; Cv2 5; } Starting time loop Time = 1 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.00397212, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.00380162, No Iterations 2 GAMG: Solving for p, Initial residual = 1, Final residual = 0.0818354, No Iterations 9 time step continuity errors : sum local = 0.000200831, global = 1.65043e-17, cumulative = 1.65043e-17 smoothSolver: Solving for nuTilda, Initial residual = 1, Final residual = 0.0191146, No Iterations 2 #0 Foam::error:rintStack(Foam::Ostream&) in "/home/vesselin/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigSegv::sigSegvHandler(int) in "/home/vesselin/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #2 in "/lib/libc.so.6" #3 Foam::incompressible::RASModels::nutSpalartAllmara sWallFunctionFvPatchScalarField::calcUTau(Foam::Fi eld<double> const&) const in "/home/vesselin/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so" #4 Foam::incompressible::RASModels::nutSpalartAllmara sWallFunctionFvPatchScalarField::calcNut() const in "/home/vesselin/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so" #5 Foam::incompressible::RASModels::nutWallFunctionFv PatchScalarField::updateCoeffs() in "/home/vesselin/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so" #6 Foam::fvPatchField<double>::evaluate(Foam::Pstream ::commsTypes) in "/home/vesselin/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/simpleFoam" #7 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate() in "/home/vesselin/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/simpleFoam" #8 Foam::incompressible::RASModels::SpalartAllmaras:: correct() in "/home/vesselin/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so" #9 in "/home/vesselin/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/simpleFoam" #10 __libc_start_main in "/lib/libc.so.6" #11 at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116 Segmentation fault Please, HELP! V. ps - I have gcc 4.4.5 on my system, don't know if it makes some difference... Last edited by vkrastev; February 16, 2011 at 13:44. |
February 17, 2011, 07:23 |
Vesselin Krastev
Rep Power: 20 |
Well, I have rebuilt once again the 1.7.1 source packages, but this time changing the optimization level of the compiler from -O3 to -O1 (simply by editing the c++Opt and c++Prof files in the /wmake/rules/linux64Gcc/ folder). After that I have compiled also my own source code and now all seems to work perfectly...Does it mean that the 4.4.5 release of gcc has some optimization-level issues? I've read here http://www.cfd-online.com/Forums/ope...gcc-4-5-x.html that in the recent past there were some troubles between gcc 4.5.x and OpenFOAM 1.7.0/1.7.1: could I have found some analogous problem with gcc 4.4.5 and OF 1.7.1 compiled on 64 bit machines? Or maybe the problem is somewhere else (processor architecture, or the specific combination of Ubuntu 10.10 and gcc 4.4.5)? I think these issues are quite interesting to start a debate, so any contribution would be really appreciated
Thank you in advance V. |
February 17, 2011, 07:53 |
Laurence R. McGlashan
Rep Power: 23 |
What happens if you compile OpenFOAM with -O3 and your own code with -O1 or -O2? Have a look at the difference between the options here: http://gcc.gnu.org/onlinedocs/gcc/Optimize-Options.html
Laurence R. McGlashan :: Website |
February 17, 2011, 09:06 |
#4 | |
Vesselin Krastev
Rep Power: 20 |
V. |
February 19, 2011, 15:50 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to both!
Vesselin, I've reported/accompanied the last two transitions in OpenFOAM 1.6.x to use gcc 4.4.x, as well as OpenFOAM 1.7.x to use gcc 4.5.x, as you have seen and can see here:
wclean all wmake all Best regards, Bruno
February 20, 2011, 11:06 |
#6 | |
Vesselin Krastev
Rep Power: 20 |
1) When I built OF-1.6 after OF-1.7.1 this should have been done with gcc 4.3.3 instead of 4.4.5, as the 4.3.3 version is automatically provided with the 1.6 release and set as default once the environmental variables are pointed to the OF-1.6/etc/bashrc file. Thus, probably between the two consequent compilation there was this kind of "contamination" you are talking about (and this could be an explanation of the identical segmentation fault error displayed for both the OF versions). 2) The first time I compiled OF-1.7.1, the contamination could not have been possible...In addition, I'm sure I have done it all with gcc 4.4.5, and before building my modifications (which are not brand new libraries, but new source and header files based on the same dependency lists of the original ones) I've also cleaned the dependencies concerning the folder of interest (turbulence models/incompressible/RAS/). However, as the cleaning was done only with wclean (and not wclean all), could this have been (in your opinion) a source of troubles? In any case, I'll try to make some additional tests following your advices as soon as possible... Thanks once again V. |
February 21, 2011, 06:07 |
#7 | |
Bruno Santos
Rep Power: 128 |
Hi Vesselin,
So, since "wclean" is almost the opposite of "wmake", it should have similar functionality, namely the clean up process will depend on whether it's an executable or a library. To make matters even more confusing, "wmake all" will call the local script "Allwmake" when it exists, since somethings are to be executed in different orders than usual. As for "wclean", it will call "Allclean". But usually only "Allwmake" exists in folders, while "Allclean" only exists sometimes. As for contamination, there are at least two possibilities:
Best regards, Bruno
February 21, 2011, 13:24 |
Problem solved
Vesselin Krastev
Rep Power: 20 |
Hi Bruno, I've just finishing rebuilding the code (1.7.1 release) and my modifications with the -O3 optimization level and now (finally) all works properly without strange error messages! I think that the issue was in the cleaning up of the dependency lists, because this time I've completed the cleaning/rebuilding procedure by using the combination wclean all/Allwmake. Thanks a lot for your comments and suggestions!
V. |
February 23, 2011, 07:09 |
#9 |
Bruno Santos
Rep Power: 128 |
Hi Vesselin,
I'm glad I was able to help and even happier that the issue you were having wasn't something related to a damaged CPU or RAM! Best regards, Bruno
April 12, 2011, 13:10 |
My two cents
#10 |
Adhiraj
Rep Power: 16 |
Hi all,
I seem to have a similar problem, and it seems that the problem the OP had is related-- segfaulting in OpenFOAM. I can confirm this kind of behavior on both 64 bit and 32 bit Ubuntu 10.10. And if that is any help. the debug version runs perfectly fine. |
April 13, 2011, 18:21 |
#11 | |
Bruno Santos
Rep Power: 128 |
Greetings Adhiraj,
Best regards, Bruno
April 22, 2011, 19:29 |
Solved that one
#12 |
Adhiraj
Rep Power: 16 |
Hi all,
sorry for the late reply; I've been simply swamped. I ran the wcleanall and recompiled everything, that seemed to help. |
April 23, 2011, 11:14 |
#13 |
Bruno Santos
Rep Power: 128 |
Hi Adhiraj,
OK, I'm glad it worked out well. I was worried that the instructions weren't clear enough, since I have a tendency to write too much Best regards, Bruno
openfoam-1.6-ext on Ubuntu 10.10 Maverick | rassilon | OpenFOAM Installation | 52 | February 6, 2013 18:30 |
Error in apt-get update for installation of OpenFoam 1.7.1 on Ubuntu 10.10 | StuntedChicken | OpenFOAM Installation | 1 | January 9, 2011 11:43 |
OpenFOAM Installation Errors on Ubuntu 10.04 | ozzythewise | OpenFOAM Installation | 1 | June 19, 2010 06:59 |
How to Install OpenFOAM on 64 Ubuntu 9.04 | hansel | OpenFOAM Installation | 62 | March 19, 2010 15:43 |
OpenFoam 1.6 Permissions in Ubuntu 9.04 | AlanR | OpenFOAM Installation | 14 | December 28, 2009 20:45 |
